RG-S7808C Thiết bị chuyển mạch - 1
RG-S7808C Thiết bị chuyển mạch - 2
RG-S7808C Thiết bị chuyển mạch - 3
RG-S7808C Thiết bị chuyển mạch - 4
RG-S7808C Thiết bị chuyển mạch - 5
RG-S7808C Thiết bị chuyển mạch - 6
RG-S7808C Thiết bị chuyển mạch - 7
RG-S7808C Thiết bị chuyển mạch - 8
RG-S7808C Thiết bị chuyển mạch - 9
RG-S7808C Thiết bị chuyển mạch - 10
RG-S7808C 10 RU Modular Campus Core Switch
Thông số chính
Modular Core Switch RG-S7808C
Compact chassis design with a height of 10 RU improves cabinet space utilization. A single card supports up to 52 non-combo ports, meeting the networking requirements of small and medium-sized core networks or medium-sized network aggregation scenarios.
Dual-Boot Redundancy
N+M Power Supply Redundancy
1+1 Fan Module Redundancy
Thông số kỹ thuật
RG-S7805C
RG-S7808C
RG-S7810C
2 x supervisor module slots
3 x line card slots
1 x fan module slot
6 x line card slots
4 x power module slots
Supervisor module
M7805C-CM II
M7808C-CM II
M7810C-CM
M7810C-CM-F
Switch fabric module
line card
● M7800C-32XS4QXS-DA
● M7800C-24GT24SFP4XS-EB
● M7800C-24SFP/12GT4XS-EB
● M7800C-48GT4XS-EB
● M7800C-48SFP4XS-EB
● M7800C-48GT-FA
● M7800C-48SFP-FA
● M7800C-48XS-FB
● M7800C-8CQ-FB
*1
● M7800C-48GT4XS-EB
● M7800C-48GT-FA
● M7800C-48SFP-FA
● M7800C-48XS-FB
● M7800C-8CQ-FB
*1
● M7800C-48GT4XS-EB
● M7800C-48GT-FA
● M7800C-48SFP-FA
● M7800C-48XS-FB
● M7800C-8CQ-FB
*1
RG-PA300I-F
RG-PA460I-F
RG-PA1000I-F
RG-PA600I-F
RG-PA1600I-F
RG-PA600I
RG-PA1600I
M05C-FAN (pre-installed 1)
M08-FAN (pre-installed 2)
M10C-FAN (pre-installed 2)
Module management port
M7805C-CM II:
● 1 x RJ45 console port
● 1 x RJ45 MGMT port
M7808C-CM II:
M7810C-CM:
M7810C-CM-F:
● 1 x RJ45 console port *2
● 1 x mini USB console port *2
M7810C-CM: 1 x USB 2.0 port
M7810C-CM-F: 1 x USB 2.0 port
*1 Note: FA/FB series cannot be used with EB series or DA series.
RG-S7805C
RG-S7808C
RG-S7810C
4500 Mpps
9000 Mpps
12000 Mpps
System switching capacity *4
6000 Gbps
12000 Gbps
16000 Gbps
Supervisor module:
● M7805C-CM II: quad-core CPU, each core with the clock speed of 1.0 GHz
Line card
● EB card: quad-core CPU, each core with the clock speed of 1.0 GHz
● DA/FA/FB card: quad-core CPU, each core with the clock speed of 1.5 GHz
Supervisor module:
● M7808C-CM II: quad-core CPU, each core with the clock speed of 1.5 GHz
Line card
Supervisor module:
● M7810C-CM, M7810C-CM-F: quad-core CPU, each core with the clock speed of 1.5 GHz
Line card
● M7810C-FE-D I, M7810C-FE-F I: quad-core CPU, each core with the clock speed of 1.5 GHz
M7805C-CM II: supported
M7808C-CM II: supported
M7805C-CM II:8 MB
EB card: 8 MB
DA/FA/FB card: 16 MB
M7808C-CM II: 16 MB
EB card: 8 MB
M7810C-CM/M7810C-CM-F: 16 MB
EB card: 8 MB
M7805C-CM II: 1 GB
EB card: 512 MB
DA/FA/FB card: 8 GB
M7808C-CM II: 8 GB
EB card: 512 MB
DA/FA/FB card: 8 GB
M7810C-CM/M7810C-CM-F: 8 GB
EB card: 512 MB
DA/FA/FB card: 8 GB
M7805C-CM II: 4 GB DDR3
EB card: 1 GB DDR3
DA card: 1 GB DDR4
FA/FB card: 2 GB DDR4
M7808C-CM II: 4 GB DDR4
EB card: 1 GB DDR3
DA card: 1 GB DDR4
EB card: 1 GB DDR3
DA card: 1 GB DDR4
M7810C-FE-D I: 1 GB DDR4
M7810C-FE-F I: 2 GB DDR4
EB: 4 MB
FB: 32 MB
FA: 8 MB
DA: 16 MB
EB: 4 MB
FB: 32 MB
FA: 8 MB
DA: 16 MB
EB: 4 MB
FB: 32 MB
FA: 8 MB
DA: 16 MB
*3 means the system's packet forwarding rate.
*4 means the system's switching capacity.
RG-S7805C
RG-S7808C
RG-S7810C
4 x pluggable power modules
RG-PA300I-F (AC input):
● Rated input voltage: 100 V AC to 240 V AC; 50/60 Hz
● Maximum input voltage: 90 V AC to 264 V AC; 47 Hz to 63 Hz
● Maximum input current: 5 A
RG-PA460I-F (AC input):
● Maximum input voltage: 90 V AC to 290 V AC; 45 Hz to 63 Hz
● Maximum input current: 6 A
RG-PA1000I-F (AC input):
● Maximum input current: 10 A
RG-PA600I-F (AC input):
RG-PA1600I-F (AC input):
● Maximum input current: 16 A
RG-PA600I (AC input):
● Maximum input current: 8 A
RG-PA1600I (AC input):
RG-PA300I-F: 300 W
RG-PA460I-F: 460 W
RG-PA1000I-F:
● 100 V AC to 176 V AC: 800 W
● 176 V AC to 240 V AC: 1000 W
RG-PA600I-F: 600 W
RG-PA1600I-F:
● 100 V AC to 176 V AC: 1200 W
● 176 V AC to 240 V AC: 1600 W
RG-PA600I: 600 W
RG-PA1600I:
M05C-FAN: < 80 W
M7805C-CM II: < 21 W
M08-FAN: < 88 W
M7808C-CM II: < 50 W
M10C-FAN: < 216 W
M7810C-CM: < 50 W
M7810C-CM-F: < 110 W
M7800C-32XS4QXS-DA: < 210 W
M7800C-48GT4XS-EB: < 70 W
M7800C-48SFP4XS-EB: < 101 W
M7800C-48GT-FA: < 75 W
M7800C-48SFP-FA: < 95 W
M7800C-48XS-FB: < 160 W
M7800C-8CQ-FB: < 130 W
RG-S7805C
RG-S7808C
RG-S7810C
4 RU
10 RU
10 RU
28.05 kg (61.84 lbs)
43.93 kg (96.85 lbs)
68.30 kg (150.58 lbs)
RG-S7805C
RG-S7808C
RG-S7810C
27°C (80.6°F): 70 dB
Max Noise: 77 dB
Max Noise: 77 dB
Max Noise: 77 dB
Supervisor module redundancy
1+1 redundancy (same model)
N+M redundancy (same model)
Over-temperature alarming
Service port: 4 kV
Power port: 6 kV
RG-S7805C
RG-S7808C
RG-S7810C
RG-S7805C
RG-S7808C
RG-S7810C-X
3 x line card slots
1 x fan module slot
6 x line card slots
8 x line card slots
Supervisor module
M7805C-CM-X
M7808C-CM-X
M7810C-CM-X
M7810C-FE-X I
M7810C-FE-X II
line card
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-24GT8SFP8XS-XA
M7800C-32XS-XA
M7800C-52XS-XB
M7800C-12CQ-XB
M7800C-48XT-P-XB
M7800C-32XS-XE
M7800C-52XS-XE
M7800C-12CQ-XE
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-32XS-XA
M7800C-52XS-XB
M7800C-12CQ-XB
M7800C-48XT-P-XB
M7800C-8SFG-XB
M7800C-8SFX-XB
M7800C-32XS-XE
M7800C-52XS-XE
M7800C-12CQ-XE
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-32XS-XA
M7800C-52XS-XB
M7800C-12CQ-XB
M7800C-48XT-P-XB
M7800C-8SFG-XB
M7800C-8SFX-XB
M7800C-32XS-XE
M7800C-52XS-XE
M7800C-12CQ-XE
RG-PA300I-F
RG-PA460I-F
RG-PA1000I-F
RG-PA600I-F
RG-PA1600I-F
RG-PA600I
RG-PA1600I
RG-PD600I
M7805C-CM-X:
M7808C-CM-X:
M7810C-CM-X:
M7810C-FE-X I/II:
RG-S7805C
RG-S7808C
RG-S7810C-X
4500 Mpps
9000 Mpps
14300 Mpps
6000 Gbps
12000 Gbps
19200 Gbps
Supervisor module:
● M7805C-CM-X: quad-core processor, each core 2.2 GHz
Line card:
● XA/XB series line card: quad-core processor, each core 2.2 GHz
● XE: quad-core processor, 2 x 2.0 GHz + 2 x 1.5 GHz
Supervisor module:
● M7808C-CM-X: quad-core processor, each core 2.2 GHz
Line card:
Supervisor module:
● M7810C-CM-X: quad-core processor, each core 2.2 GHz
Line card:
M7805C-CM-X: supported
M7808C-CM-X: supported
M7810C-CM-X: supported
M7805C-CM-X: 16 MB
XA/XB/XE card: 16 MB
M7808C-CM-X: 16 MB
M7810C-CM-X: 16 MB
M7810C-FE-X I/II: 16 MB
M7805C-CM-X: 8 GB
XA/XB/XE card: 8 GB
M7808C-CM-X: 8 GB
XA/XB/XE card: 8 GB
M7810C-CM-X: 8 GB
M7810C-FE-X I/II: 8 GB
XA/XB/XE card: 8 GB
M7805C-CM-X: 4 GB DDR4
XA/XB/XE card: 4 GB DDR4
M7808C-CM-X: 4 GB DDR4
M7810C-CM-X: 4 GB DDR4
M7810C-FE-X I: 1 GB DDR4
M7810C-FE-X II: 4 GB DDR4
XB series line card: 35 MB
M7800C-32XS-XA: 35 MB
XE card: 14 MB
XE card: 14 MB
XE card: 14 MB
RG-S7805C
RG-S7808C
RG-S7810C-X
RG-PD600I (DC input):
● Rated input voltage: –48 V DC
● Maximum input voltage: –40 V DC to –75 V DC
● Maximum input current: 20 A
RG-PA300I-F: 300 W
RG-PA460I-F: 460 W
RG-PA1000I-F:
RG-PA600I-F: 600 W
RG-PA1600I-F:
RG-PA600I: 600 W
RG-PA1600I:
RG-PD600I: 600 W
M05C-FAN: < 80 W
M7805C-CM-X: < 40 W
M08-FAN: < 88 W
M7808C-CM-X: < 62 W
M7800C-8SFG-XB: < 250 W
M7800C-8SFX-XB: < 250 W
M10C-FAN: < 216 W
M7810C-CM-X: < 60 W
M7810C-FE-X I: < 50 W
M7810C-FE-X II: < 160 W
M7800C-48GT4XS-XA: < 85 W
M7800C-48SFP4XS-XA: < 117 W
M7800C-24GT8SFP8XS-XA: < 95 W
M7800C-32XS-XA: < 149 W
M7800C-52XS-XB: < 250 W
M7800C-12CQ-XB: < 240 W
M7800C-48XT-P-XB: < 300 W
M7800C-32XS-XE: <110 W
M7800C-52XS-XE: <140 W
M7800C-12CQ-XE: <160 W
M78-PSE-X
2 x PoE out ports
RG-PA1600I-PL
RG-PA1600I-PL (AC input):
RG-PA1600I-PL
Each PoE out port provides up to 1,440 W of power
5.0 kg (11.02 lbs)
RG-S7805C
RG-S7808C
RG-S7810C-X
4 RU
10 RU
10 RU
RG-S7805C
RG-S7808C
RG-S7810C-X
Max Noise: 77 dB
Max Noise: 77 dB
Max Noise: 77 dB
Over-temperature warning
Service port: 4 kV
Power port: 6 kV
RG-S7805C
RG-S7808C
RG-S7810C-X
RG-S7800C Series
S7805C: 2,400 Gbps
S7808C: 3,200 Gbps
S7810C: 3,200 Gbps
EB card: 64,000
FA card: 80,000
FB card: 96,000
EB card: 10,000
EB card: 10,000
DA card: 45,000
FA card: 16,000
FB card: 32,000
EB card: 8,000
DA card: 16,000
FA card: 8,000
FB card: 16,000
EB card: 4,000
DA card: 8,000
FA card: 4,000
FB card: 8,000
EB card: 1,000
DA card: 1,000
FA card: 2,000
FB card: 2,000
● EB card
In: 3,500 Out: 1,000
● DA card
In: 8,000 Out: 1,000
● FA card
In: 5,000 Out: 1,000
● FB card
In: 4,500 Out: 2,000
RG-S7800C Series
GRE tunnel
IPv4/IPv6 IS-IS
EVPN
Policy-based routing (PBR)
IPv4 and IPv6 ECMP
IGMP v1/v2/v3
IGMP snooping v1/v2/v3
IGMP proxy
MLDv1 and MLDv2
Multicast static routing
MLD v1/v2 snooping
MPLS IPv6
MPLS 6VPE
MPLS MIB (RFC 1273, RFC 4265, and RFC 4382)
ACL80 and IPv6 ACL
Port-based rate limiting
802.1p
CAR
RADIUS authorization and accounting
ICMP
uRPF
Rapid Ethernet Uplink Protection (REUP)
VRRP for the super-VLAN
RG-S7805C, RG-S7808C , RG-S7810C: 1+1 redundancy for supervisor modules
RG-S7805C: 1+1 redundancy for power supply
RG-S7808C , RG-S7810C: N+M redundancy for power supply
RG-S7805C: fan redundancy is not supported
RG-S7808C , RG-S7810C: 1+1 fan redundancy
Hot swapping of components
GR for OSPF/IS-IS/BGP
SPAN, RSPAN, and ERSPAN
NTP
SNTP
FTP, TFTP, and Xmodem
Web-based NMS
RG-S7800C-X Series
S7805C-X: 3,200 Gbps
S7808C-X: 3,200 Gbps
S7810C-X: 3,200 Gbps
M7800C-8SFX-XB: 256,000
M7800C-8SFG-XB: 256,000
XA card: 96,000
XB card: 256,000
XE card: 256,000
M7800C-8SFX-XB: 96,000
M7800C-8SFG-XB: 96,000
XA card: 40,000
XB card: 96,000
XE card: 90,000
M7800C-8SFX-XB: 80,000
M7800C-8SFG-XB: 80,000
XA card: 40,000
XB card: 80,000
XE card: 54,000
M7800C-8SFX-XB: 350,000 (shared with IPv6 routes)
M7800C-8SFG-XB:350,000 (shared with IPv6 routes)
XA card:64,000 (shared with IPv6 routes)
XB card: 350,000 (shared with IPv6 routes)
XE card: 192,000 (shared with IPv6 routes)
M7800C-8SFX-XB: 65,000 (shared with IPv4 routes)
M7800C-8SFG-XB:65,000 (shared with IPv4 routes)
XA card: 15,000 (shared with IPv4 routes)
XB card: 65,000 (shared with IPv4 routes)
XE card: 30,000 (shared with IPv4 routes)
● M7800C-8SFX-XB
In: 28,000 Out:4,000
● M7800C-8SFG-XB
● XA card
In: 7,500 Out:1,500
● XB card
● XE card
In: 21,000 Out:8,000
RG-S7800C-X Series
IP subnet-based VLAN
MAC VLAN
Port-based VLAN
protocol-based VLAN
Super-VLAN
STP (IEEE 802.1.d)
RSTP (IEEE 802.1w)
MSTP (IEEE 802.1s)
Device Virtualization
SDN
OpenFlow 1.3
DHCPv6 client
DHCPv6 relay
FTP Server
FTP Client
NTP server
NTP Client
SNTP Client
TFTP Client
TFTP Server
BGP4
BGP4+
IS-ISv4
IS-ISv6
OSPFv2
OSPFv3
RIP
RIPng
Routing Policy
IGMP v1/v2/v3
IGMP snooping v1/v2
IGMP proxy
PIM-DM
PIM-SM
MLDv1 and MLDv2
MLD v1/v2 snooping
MPLS 6VPE
MPLS IPv6
MPLS forwarding
LDP
LSP
VXLAN Layer 2 bridge
VXLAN Layer 3 gateway
EVPN VXLAN
Standard IP ACL
extended IP ACL
extended MAC ACL
Layer 2 and Layer 3 port ACL
VLAN ACL
Expert-level ACL
ACL 80
Applying ACLs globally
ACL COUNTER
ACL LOGGING
ACL REMARK
802.1P
SP
WRR
SP+WFR
RED/WRED
MPLS QOS
RG-S7805C, RG-S7808C , RG-S7810C-X: 1+1 redundancy for supervisor modules
RG-S7808C , RG-S7810C-X: N+M redundancy for power supply
RG-S7808C , RG-S7810C-X: 1+1 fan redundancy
VRRP+
Faulty optical port isolation
port security
802.1X authentication
RADIUS
uRPF
SSHv2
IPv6 SAVI
SNMP V1/V2c/V3
RMON
GRPC
Fault alarm and auto-recovery
SPAN
RSPAN
ERSPAN
VLAN mirroring
Web-based NMS
Energy-Saving Design
Tài nguyên
Thông tin đặt hàng
Switch Chassis
RG-S7805C
RG-S7808C
RG-S7810C
RG-S7810C-X
Supervisor Modules
M7805C-CM II
M7808C-CM II
M7810C-CM
M7810C-CM-F
M7805C-CM-X
M7808C-CM-X
M7810C-CM-X
Notes:
● Different models cannot be interchanged.
● Mandatory item, 1+1 redundancy supported, and at least one supervisor module must be configured.
Switch Fabric Modules
M7810C-FE-D I
M7810C-FE-F I
M7810C-FE-X I
M7810C-FE-X II
Line Cards
M7800C-32XS4QXS-DA
M7800C-48GT4XS-EB
M7800C-48SFP4XS-EB
M7800C-48GT-FA
M7800C-48SFP-FA
M7800C-48XS-FB
48 x 1GE/10GE SFP+ ports (LC)
M7800C-8CQ-FB
Notes:
EB series line cards only interchanged with DA series line cards.
DA series line cards only interchanged with EB series line cards.
FA/FB series line cards cannot be interchanged with EB/DA series line cards.
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-32XS-XA
M7800C-52XS-XB
52 x 1GE/10GE SFP+ ports (LC)
M7800C-12CQ-XB
M7800C-48XT-P-XB
M7800C-8SFG-XB
M7800C-8SFX-XB
M7800C-32XS-XE
32 x 10GE optical ports (SFP+, LC)
M7800C-52XS-XE
52 x 10GE optical ports (SFP+, LC)
M7800C-12CQ-XE
12 x 100G/40G optical ports (QSFP+, MPO/LC)
Power Chassis and Modules
RG-PA300I-F
RG-PA460I-F
RG-PA600I
RG-PA600I-F
RG-PA1000I-F
RG-PA1600I
RG-PA1600I-F
M78-PSE-X
PoE power chassis. 2 x PoE out ports can power two PoE line cards through specialized PoE cables. 2 x power module slots, used together with RG-PA1600I-PL (working with -X series supervisor module)
RG-PA1600I-PL
RG-PD600I
XG-SFP-T
10GBASE-T, SFP+ to RJ45 transceiver, 70 m
SFM-LR-SM
Câu hỏi thường gặp
