RG-S5350-24GT4SFP-P-E Thiết bị chuyển mạch - 1
RG-S5350-24GT4SFP-P-E Thiết bị chuyển mạch - 2
RG-S5350-24GT4SFP-P-E Thiết bị chuyển mạch - 3
RG-S5350-24GT4SFP-P-E Thiết bị chuyển mạch - 4
RG-S5350-24GT4SFP-P-E Thiết bị chuyển mạch - 5
RG-S5350-24GT4SFP-P-E Thiết bị chuyển mạch - 6
RG-S5350-24GT4SFP-P-E Thiết bị chuyển mạch - 7
RG-S5350-24GT4SFP-P-E 24-Port GE Layer 3 Managed Access Switch with PoE+, 4-Port 1GE Uplink
  • PoE+ supported, powering various terminal devices
Layer 3 Compact Access Switch for 1GE Uplink RG-S5350-24GT4SFP-P-E
PoE+ Supported, Powering Various Terminal Devices
The switch automatically detects and supplies the required power for devices, meeting the needs of common PoE applications such as security surveillance, teleconferencing, and wireless coverage.
Passed anti-corrosion tests, with the proven capability to withstand exposure to moisture, ensuring durability in severe environments.
Virtual Switching Unit (VSU) ensures flexible networking and high performance.
Thông số kỹ thuật
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
RG-S5350-12GT4XS-P-E
RG-S5350-24GT4XS-P-E
RG-S5350-48GT4XS-P-E
Fixed service ports
4 x 1GE/2.5GE/10GE SFP+ ports
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
RG-S5350-48GT4SFP-P-E
Fixed service ports
4 x 1GE SFP ports
4 x 1GE SFP ports
4 x 1GE SFP ports
4 x 1GE SFP ports
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
115 Mpps
158 Mpps
94 Mpps
115 Mpps
158 Mpps
Switching capacity *2
128 Gbps / 336 Gbps
176 Gbps / 336 Gbps
104 Gbps / 336 Gbps
128 Gbps / 336 Gbps
176 Gbps / 336 Gbps
512 MB
DDR4 1GB
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
50 Mpps
94 Mpps
50 Mpps
94 Mpps
56 Gbps / 336 Gbps
104 Gbps / 336 Gbps
56 Gbps / 336 Gbps
104 Gbps / 336 Gbps
512 MB
DDR4 1GB
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
3.25 kg (7.17 lbs)
3.3 kg (7.28 lbs)
3.4 kg (7.50 lbs)
4.0 kg (8.82 lbs)
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
3.25 kg (7.17 lbs)
3.4 kg (7.50 lbs)
4.0 kg (8.82 lbs)
Power supply and Consumption
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Fixed power supply: 25 W
Fixed power supply: 40 W
Leakage current
≤ 3.5 mA
● Maximum input current: 6 A
Built-in power supply: 409 W
Built-in power supply: 460 W
35 W (without PoE load)
405 W (full PoE load)
52 W (without PoE load)
460 W (full PoE load)
Leakage current
≤ 3.5 mA
The maximum power is 370 W.
The maximum power is 405 W.
supported
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
Built-in power supply: 40 W
Leakage current
≤ 3.5 mA
●AC input
Fixed power supply: 409 W
Fixed power supply: 460 W
Leakage current
≤ 3.5 mA
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
No fan
Fanless, quiet, < 20 dB
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
RG-S5350-E Series
S5350-24GT4XS-E: 40 Gbps
S5350-24GT4XS-P-E: 40 Gbps
S5350-48GT4XS-E: 40 Gbps
S5350-48GT4XS-P-E: 40 Gbps
S5350-12GT4XS-P-E: 40 Gbps
S5350-24GT4SFP-E: 4 Gbps
S5350-24GT4SFP-P-E: 4 Gbps
S5350-48GT4SFP-E: 4 Gbps
S5350-48GT4SFP-P-E: 4 Gbps
990
750
750
255
In: 1,750 Out: 800
RG-S5350-E Series
IPv4 and IPv6 VRF
IGMP v1/v2 snooping
PIM SMv6, and PIM-SSMv6
MLDv1/v2 and MLD proxy
Extended IP (hardware ACLs
IPv6 ACLon IP addresses)
RADIUS and TACAS+
BFD, NSR, VRRR, VRRP+
Basic LACP
Dual-Boot Redundancy
SPAN, RSPAN
CLI (Telnet/Console)
Web
Syslog/Debug
1:1 mirroring
N:1 mirroring
1:N mirroring
Warm start
Tài nguyên
Thông tin đặt hàng
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
