RG-S5000-10GT2MS-P-E Thiết bị chuyển mạch - 1
RG-S5000-10GT2MS-P-E Thiết bị chuyển mạch - 2
RG-S5000-10GT2MS-P-E Thiết bị chuyển mạch - 3
RG-S5000-10GT2MS-P-E Thiết bị chuyển mạch - 4
RG-S5000-10GT2MS-P-E Thiết bị chuyển mạch - 5
RG-S5000-10GT2MS-P-E Thiết bị chuyển mạch - 6
RG-S5000-10GT2MS-P-E Thiết bị chuyển mạch - 7
RG-S5000-10GT2MS-P-E Thiết bị chuyển mạch - 8
RG-S5000-10GT2MS-P-E Thiết bị chuyển mạch - 9
RG-S5000-10GT2MS-P-E Thiết bị chuyển mạch - 10
RG-S5000-10GT2MS-P-E Thiết bị chuyển mạch - 11
RG-S5000-10GT2MS-P-E 10-Port Gigabit Layer 2+ Managed PoE+ Switch with Two 2.5GE Uplink SFP Ports
Thông số chính
Applications
and Wider Coverage
10 kV Surge Protection
and WIS Cloud-based Solutions
Local & Cloud O&M
Visualized Management
Alarm Processing
Thông số kỹ thuật
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
RG-S5000-24GT4MS-P-E
10 x 10/100/1000BASE-T ports
2 x 1GE/2.5GE SFP ports
4 x 1GE/2.5GE SFP ports
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
27 Mpps
61 Mpps
104 Mpps
27 Mpps
61 Mpps
82 Gbps
139 Gbps
82 Gbps
64 MB
64 MB
64 MB
64 MB
64 MB
512 MB DDR4
512 MB DDR4
512 MB DDR4
512 MB DDR4
512 MB DDR4
512 KB
512 KB
512 KB
512 KB
512 KB
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
2.0 kg (4.41 lbs)
2.5 kg (5.51 lbs)
2.8 kg (6.17 lbs)
2.5 kg (5.51 lbs)
2.8 kg (6.17 lbs)
2.40 kg (5.25 lbs)
3.70 kg (8.15 lbs)
3.60 kg (7.94 lbs)
3.18 kg (7.01 lbs)
4.13 kg (9.11 lbs)
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
Fixed power supply: 16 W
Fixed power supply: 15.6 W
Fixed power supply: 30 W
Fixed power supply: 141 W
Fixed power supply: 430 W
16 W
15.6 W
30 W
16 W (without PoE load)
141 W (full PoE load)
33 W (without PoE load)
403 W (full PoE load)
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
Forced air cooling
Forced air cooling
Forced air cooling
27℃ (80.6°F): 40 dB
27℃ (80.6°F): 40 dB
27℃ (80.6°F): 40 dB
Air discharge: 8 kV/15 kV
Contact discharge: 6 kV/8 kV
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
RG-S5000-E Series
31 (shared with routed ports)
In: 500 Out: Not Supported
RG-S5000-E Series
Port-based VLAN assignment
Basic QinQ and selective QinQ
DNS client
Neighbor Discovery (ND)
OSPFv2
IGMP snooping v1/v2
Expert ACLs
ACL 80
Port rate limiting
IEEE 802.1X authentication
SSHv1.5 and SSHv2.0
Proxy ARP and ARP entry aging
Hardware CPP and NFPP
LACP
Load balancing modes
RSPAN
TFTP (TFTP client)
SSH v1.5/v2.0
● IEEE 802.3af and 802.3at
● Port priority
Cloud
WIS
Tài nguyên
Thông tin đặt hàng
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
Câu hỏi thường gặp
