RG-S2910-48GT4XS-E, 48-Port Gigabit L2+ Managed Switch with SFP+
Full gigabit access to LANs in large enterprise parks, gigabit access to commercial systems
  • Green energy saving, saving 40% power consumption compared to products in the same class.
  • Equipped with Ruijie Network's self-developed multi-process modular RGOS11.X operating system.
  • Support SDN features and comply with the Openflow 1.3 protocol standard.
  • Support TR069 zero configuration online; A wide variety of port form factors.
RG-S2910XS-E Series New-Generation Efficient and Energy-Saving Switches
Power consumption reduced by 40% compared with similar products
Multi-process modular OS RGOS 11.X developed by Ruijie Networks
SDN features and compliance with OpenFlow 1.3
Switch zero-configuration via TR069
Diverse ports
Secure and Reliable Hardware
and Software
Strict component selection
3-month reliability testing
(concerning high and low temperature tolerance, vibration, electromagnetic interference, power surge, signal tests, etc.)
Hardware and software-level CPU Protection Policy (CPP)
Accurate traffic statistics
Unified management and control of 9 virtualized devices
Multiple Modes Ensuring Easy Management
Creating New Green and Energy-saving Devices
Compared with the RG-S5750-S products with the same configuration, the S2910XS-E reduces power consumption by more than 40% .
Compared with the RG-S2900G-E products with lower configuration, the S2910XS-E reduces power consumption by about 10% .
RG-S2910-24GT4XS-E
RG-S2910-48GT4XS-E
Interface Specifications
24 x 10/100/1000 BASE-T ports
4 x 1G/10G BASE-X SFP+ ports (non- combo)
48 10/100/1000 BASE-T ports
Fans modules
Fixed fans
Fixed fans
1 console port
1 console port
128Gbps
176Gbps
96Mpps
132Mpps
Port Buffer
1.5MB
RAM
512MB
ARP Table
MAC Address
16K
500 (IPv4/IPv6)
ACL Entries
In: 1,500
Out: 500
Lightning
Protection on
Power Port
Common Mode
6KV/Differential
Mode 6KV
Lightening
Protection on
Communication
Common Mode 6KV
440 × 260 × 43.6
440 × 260 × 43.6
≤3.5kg
≤4kg
Rack Height
1RU
1RU
Power and Consumption
Rated input voltage
AC input: 100V to 240V AC
HVDC input: 192V to 290V DC
Maximum input voltage
90V to 264V AC
90V to 264V AC
Input current
0.5A to 0.1A
0.8A to 0.5A
Power Consumption
24W
50W
MTBF (hours)
>200K
Auto fan speed adjustment; Fan malfunction alerts; Fan status check
0°C to 50°C
-40°C to 70°C
10% to 90%RH
5% to 95%RH
Operating altitude
-500m to 5,000m
Safety Standards
IEC 60950-1, EN 60950-1
Emission
Standards
EN 300 386, EN 55022/55032, EN 61000-3-2, EN 61000-3-3, EN 55024, EN 61000-4-2, EN 61000-4-3, EN 61000-4-4, EN 61000-4-5, EN 61000-4-6, EN 61000-4-8, EN 61000-4-11
RG-S2910-24GT4XS-E
RG-S2910-48GT4XS-E
4K 802.1q VLANs
Port-based VLAN
MAC-based VLAN
Protocol-based VLAN
QinQ
IP subnet-based VLAN
Guest VLAN
QinQ
Flexible QinQ
N:1 VLAN switching
1:1 VLAN switching
Link Aggregation
AP, LACP (maximum 8 ports can be aggregated), Cross devices AP, Flow balance
Standard/Extended/Expert ACL
Extended MAC ACL
ACL 80
ACL logging
ACL counter
ACL remark
Global ACL
ACL redirect
Time-based ACL
Router ACL
VLAN ACL
Port-Based ACL
802.1p/DSCP/TOS traffic classification;
Multiple queue scheduling mechanisms, such as SP, WRR, DRR,       SP+WFQ, SP+WRR, SP+DRR
Input / output port-based speed limit
Port-based traffic recognition
Layer 4 prioritization based on TCP/UDP port numbers
Each port supports 8 queue priorities
Flow-based rate limiting with the minimum granularity of 8Kbps
Dynamic QoS
Mirroring
Over devices mirroring
VLAN-based mirroring
VLAN-filtering mirroring
AP-port mirroring, RSPAN
ERSPAN
Note: RG-S2910-10GT2SFP-P-E supports Many-to-one mirroring, One-to-many mirroring, Flow-based mirroring
Spanning Tree
Protocols
IEEE802.1d STP, IEEE802.1w RSTP, Standard 802.1s MSTP, Port fast, BPDU filter, BPDU guard, TC guard, TC protection, ROOT guard, Spanning Tree Root Guard (STRG)
DHCP
IPv6 DHCP snooping
IPv6 DHCP relay
DHCP Snooping Option 82
Multiple Spanning Tree Protocol       (MSTP) Instances
Layer 2 protocols
IEEE802.3, IEEE802.3u, IEEE802.3z, IEEE802.3x, IEEE802.3ad, IEEE802.1p, IEEE802.1x, IEEE802.3ab, IEEE802.1Q (GVRP), IEEE802.1d, IEEE802.1w, IEEE802.1s
Maximum Aggregation Port (AP)
128
SDN
OpenFlow 1.0 & 1.3
VSU (Virtual
Switch Unit)
Support (up to 9 stack members to ensure the effectiveness of the use, 4 members are recommended), Local and distant stacking, Cross-chassis link aggregation in the stack, Stacking via 10G Ethernet ports
 # All models support the features above except RG-S2910-10GT2SFP-P-E
Zero Configuration
CWMP(TR069)
IEEE 802.3az-compliant EEE: When EEE is enabled, power consumption of interfaces is significantly reduced.
L2 Features
MAC, EEE, ARP, VLAN, Basic QinQ, Felix QinQ, Link aggregation, Mirroring, STP, RSTP, MSTP, Broadcast/ Multicast/Unknown unicast storm control, IGMP v1/v2/v3 snooping, IPv6 MLD Snooping v1/v2, IGMP SGVL/ IVGL, IGMP querier, IGMP filter, IGMP fast leave, DHCP, Jumbo frame, RLDP, LLDP, REUP, G.8032 ERPS, Layer 2 protocol tunnel
IPv4/ IPv6 static route
RIP, RIPng, OSPFv2, and OSPFv3 Routing policy
Basic protocols
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, IPv6 Ping and IPv6 Tracert
Other Protocols
FTP, TFTP, DNS client, DNS static
IPv4 Features
Ping, Traceroute
IPv6 Features
ICMPv6, IPv6 Ping, IPv6 Tracert, Manually configure local address, Automatically create local address
VSU features
VSU (virtualization technology for virtualizing multiple devices into 1); RIP GR; ERPS (G.8032);
REUP dual-link fast switching technology; RLDP (Rapid Link Detection Protocol)
Management features
CLI (Telnet / Console)
SSH
Syslog/Debug
NTP/SNTP, FTP, TFTP
Web
HTTP or HTTPS
Note: RG-S2910-10GT2SFP-P-E supports SNMPv2c, CLI (Telnet / Console), Syslog, RMON (1, 2, 3, 9), Web
EEE Format
Support IEEE 802.3az standard
Hot Patch
Support
RG-S2910-24GT4XS-E
24 10/100/1000BASE-T Ports, 4 1G/10GBASE-X SFP+ Ports (non-combo), AC
RG-S2910-48GT4XS-E
48 10/100/1000BASE-T Ports, 4 1G/10GBASE-X SFP+ Ports (non-combo), AC
10 10/100/1000BASE-T Ports, 2 100/1000BASE-X SFP Ports (non-combo), Port 1-8 support PoE/PoE+, AC
RG-S2910C-24GT2XS-HP-E
24 10/100/1000BASE-T Ports (PoE/PoE+), 2 100/1000BASE-X SFP Ports (combo), 2 1G/10GBASE-X SFP+ Ports (non-combo), 1 USB, 2 Expansion Slots, 2 Modular Power Slots, AC/DC
RG-S2910C-48GT2XS-HP-E
48 10/100/1000BASE-T Ports (PoE/PoE+), 2 100/1000BASE-X SFP Ports (combo), 2 1G/10GBASE-X SFP+ Ports (non-combo), 1 USB, 2 Expansion Slots, 2 Modular Power Slots, AC/DC
Optional Accessories
M2910-01XS
1-Port 10G SFP+ Interface Module, for S2910XS PoE models
M2910-02XS
2-Port 10G SFP+ Interface Module, only for RG-S2910C-24GT2XS-P-E
RG-M5000E-AC500P
AC Power Module, 370W Power Budget for PoE, up to 24 PoE ports or 12 PoE+ ports (only for RG-S2910C-24GT2XS-HP-E and RG-S2910C-48GT2XS-HP-E)
RG-M5000E-DC500P
DC Power Module, -32V to -72V DC input voltage, 370W Power Budget for PoE, up to 24 PoE ports or 12 PoE+ ports (only for RG-S2910C-24GT2XS-HP-E and RG-S2910C-48GT2XS-HP-E)
RG-PA1150P-F
AC Power Module, 740W Power Budget for PoE, up to 48 PoE ports or 24 PoE+ ports (only for RG-S2910C-24GT2XS-HP-E and RG-S2910C-48GT2XS-HP-E)
Mini-GBIC-SX-MM850
1000BASE-SX mini GBIC Transceiver (850nm)
Mini-GBIC-LX-SM1310
1000BASE-LX mini GBIC Transceiver (1310nm)
Mini-GBIC-LH40-SM1310
1000BASE-LH mini GBIC Transceiver (1310nm, 40km)
Mini-GBIC-ZX50-SM1550
1000BASE-ZX mini GBIC Transceiver (1550nm, 50km)
Mini-GBIC-ZX80-SM1550
1000BASE-ZX mini GBIC Transceiver (1550nm, 80km)
Mini-GBIC-ZX100-SM1550
1000BASE-ZX mini GBIC Transceiver (1550nm, 100km)
10GBASE-SR, SFP+ Transceiver, MM (850nm, 300m, LC)
10GBASE-SR, SFP+ Transceiver (1550nm, 40km, LC)
Gigabit SFP BIDI Transceiver (TX1310/RX1550, 20km, LC)
Gigabit SFP BIDI Transceiver (TX1550/RX1310, 20km, LC)
Gigabit SFP BIDI Transceiver (TX1310/RX1550, 40km, LC)
Gigabit SFP BIDI Transceiver (TX1550/RX1310, 40km, LC)
10GBASE SFP+ Optical Stack Cable (included both side transceivers) for S2910 and S5750-H Series Switches, 1m
10GBASE SFP+ Optical Stack Cable (included both side transceivers) for S2910 and S5750-H Series Switches, 3m
10GBASE SFP+ Optical Stack Cable (included both side transceivers) for S2910 and S5750-H Series Switches, 5m
