RG-S5300-24GT4XS-E 24-Port GE Electrical Layer 3 Managed Access Switch, 10G Uplink
Full-gigabit access switch for large-sized enterprise and campus LANs, gigabit access switch for business applications such as hospitals, libraries, convention and exhibition centers, and websites
  • Rich port types, 24 x 1000 Mbps Ethernet ports, 4 x 10G optical ports for uplink
  • Abundant QoS policies for flexible resource allocation, making congestion a thing of the past
Thông số chi tiết chính View More
Layer 3 GE Managed Access Switch RG-S5300-24GT4XS-E
Gigabit access switch for large-sized enterprise and campus LANs, with four 10G uplink optical ports for high-speed data transmission 24 x 1000 Mbps Ethernet ports,
providing high-speed network access for short-distance services and flexible networking
Enhanced Network Robustness
With multi-plane flow classification and control capabilities for MAC flow, IP flow and application flow, accurate resource allocation for multi-service traffic makes
congestion a thing of the past, delivering high-quality networks.
achieving automatic O&M.
RG-S5300-24GT4XS-E
RG-S5300-24GT4XS-P-E
RG-S5300-48GT4XS-E
Interface Specifications
Fixed port
24 x 10/100/1000M auto-negotiation electrical ports, 4 x 1G/10G SFP+ ports
48 x 10/100/1000M auto-negotiation electrical ports, 4 x 1G/10G SFP+ ports
Built-in power module
1 x MGMT port, 1 x console port, and 1 x USB port
96 Mpps
96 Mpps
132 Mpps
System switching capacity
128 Gbps
128 Gbps
176 Gbps
32,000
ND table size
2,500
1,200
Ingress: 3,500
Egress: 1,500
Number of IGMP groups
2,500
Number of MLD groups
Number of VRFs
512
442 mm x 220 mm x 43.6 mm (17.40 in. x 8.66 in. x 1.72 in.), 1 RU
Weight (full load)
2.7 kg (5.95 lbs)
3 kg (6.61 lbs)
3 kg (6.61 lbs)
CPU and Storage
1.2 GHz dual-core processor
Storage
Flash memory: 2 GB
SDRAM: 1 GB
Power and Consumption
< 40 W
System power consumption (without PoE load) < 65 W
System power consumption (with PoE load) < 410 W
< 55 W
Rated input voltage
AC input: 100 V to 240 V
Frequency: 50/60 Hz
Maximum input voltage
AC input: 90 V to 264 V
> 200,000 hours
Primary airflow
Front-to-rear airflow
0°C to 45°C (32°F to 113°F) at an altitude in the range of 0 m to 1,800 m (5905.51 ft.)
Altitude 1,800 m (5905.51 ft.) to 5,000 m (16404.20 ft.): The maximum temperature decreases by 1°C (1.8°F) each time the altitude increases by 220 m (721.78 ft.).
5% to 90% RH (non-condensing)
Operating altitude
0 m to 5,000 m (16404.20 ft.)
Operating noise
40.9 dB at the temperature of 27°C (80.6°F)
48.8 dB at the temperature of 45°C (113°F)
33.5 dB at the temperature of 27°C (80.6°F)
53.9 dB at the temperature of 45°C (113°F)
40.3 dB at the temperature of 27°C (80.6°F)
53.1dB at the temperature of 45°C (113°F)
Interface surge protection
Communication port: 10 kV (common mode) (MGMT port: 4 kV)
Power port: 6 kV (common/differential mode)
RG-S5300-E Series
Super VLAN and private VLAN
Auto errdisable recovery
BPDU filter
Port fast
Root guard
ERPS (G.8032 v1/v2), sing ring, tangent ring, intersecting ring, and load balancing
MAC address filtering
IPv6 addressing, IPv6 ping, and IPv6 tracert
GRE tunnel
IPv4 and IPv6 static routing
Routing policy
IPv4/VRF
IPv4/IPv6 PBR
IGMPv1/v2 snooping
PIM-DM, PIM-SM, PIM-SSM, PIM SMv6, and PIM-SSMv6
MLDv1/v2 and MLD proxy
MLDv1/v2 snooping
Time based ACLs, ACL 80, and IPv6 ACL
RADIUS
ICMP
Port- and MAC address-based 802.1X authentication
MAB authentication
IPv4 VRRP v2/v3, IPv6 VRRP, and super-VLAN for VRRP
Local and remote stacking
SPAN, RSPAN, and ERSPAN
SNTP
CLI (Telnet/Console)
SNMP v1/v2c/c3
Web
Syslog/Debugging
MACC
RG-S5300-24GT4XS-P-E:
RG-S5300-24GT4XS-E
24 x 10/100/1000M auto-negotiation electrical ports, 4 x 1G/10G SFP+ ports, supporting PoE and a maximum PoE output power of 370 W
RG-S5300-48GT4XS-E
1000BASE-TX, SFP Transceiver (100 m)
Mini-GBIC-SX-MM850
1000BASE-SX, SFP Transceiver, SM (850 nm, 500 m, LC)
Mini-GBIC-LX-SM1310
1000BASE-LX, SFP Transceiver, SM (1310 nm, 10 km, LC)
Mini-GBIC-LH40-SM1310
1000BASE-LH, SFP Transceiver, SM (1310 nm, 40 km, LC)
Mini-GBIC-ZX100-SM1550
1000BASE-ZX100, SFP Transceiver, SM (1550 nm, 100 km, LC)
10GBASE-SR, SFP+ Transceiver, MM (850 nm, 300 m, LC)
10GBASE-SR, SFP+ Transceiver (1310nm, 10 km, LC)
10GBASE-SR, SFP+ Transceiver (1550nm, 40 km, LC)
Technical Support
Technical Support
Get in Touch
Get in Touch
