RG-PF2920U-4GT1MS-P Коммутаторы - 1
RG-PF2920U-4GT1MS-P Коммутаторы - 2
RG-PF2920U-4GT1MS-P Коммутаторы - 3
RG-PF2920U-4GT1MS-P Коммутаторы - 4
RG-PF2920U-4GT1MS-P Коммутаторы - 5
RG-PF2920U-4GT1MS-P, 4-Port Gigabit Enterprise-Class Indoor PoE Switch for Hybrid Cable Connection over All-Optical Ethernet, with 2.5GE Uplink
Indoor hybrid cable connection, flexible installation, simplified O&M, fit for office, production, device, and warehouse networks in campus scenarios
  • Hybrid cable connection for power and optical transmission, supporting Ruijie Networks PoF Solution for simplified network deployment
  • Compact size and flexible installation, adapting to various scenarios
  • Fanless design, low noise and energy consumption
  • Built-in temperature sensor chip for intelligent temperature control and over-temperature protection, guaranteeing device stability and security
  • INC-based intelligent O&M, enabling efficient management and secure, reliable networks
Функции
RG-PF2920U-4GT1MS-P
The switch supports hybrid cable connections. The simple networking and SDN technology provide campus services with a high-bandwidth, low-latency, highly flexible infrastructure that features simplified O&M.
Compact Size Compact Size
Fanless Design Fanless Design
Intelligent Temperature Control Intelligent Temperature Control
Integrated Power and Optical Transmission
Hybrid cable connection enables integrated power and optical transmission.
Cables are pre-buried on a cable tray under the workbench, offering tidy and clear cabling.
Find out details >>
Fast onboarding Fast onboarding
Zero Touch Replacement Zero Touch Replacement
Технические характеристики
RG-PF2920U-4GT1MS-P
RG-PF2920-DPBOX-P
Fixed ports
4 x 10M/100M/1000M auto-negotiation electrical ports
1 x 1000M/2.5G SFP port
1 x 10M/100M/1000M auto-negotiation electrical port
1 x GE SFP port
13 Gbps
9.7 Mpps
SFP port
2500Base-X and 1000Base-X supported
Powered by a hybrid cable from the PoF switch
Maximum voltage range: 42 V DC to 57 V DC
Rated voltage range: 44 V DC to 56 V DC
Rated current: 1.3 A
Rated voltage: 44 V DC to 57 V DC
Rated current: 0.75 A
Leakage current to ground
≤ 3.5 mA
EEE
Ethernet electrical ports 1–4 support PoE.
Max. overall PoE output power: 60 W
The maximum number of PoE devices supported by the switch is determined by the PoE output power of the switch and the actual power of the PoE devices.
1 x downlink POE/POE+ port
Overall power consumption
Without PoE load: ≤ 15 W
With PoE full load: ≤ 75 W
Without PoE load: ≤ 3 W
Overall power (PoE+) ≤ 33 W
Installed in a rack or unconfined space: 0ºC to 45ºC (32ºF to 113ºF) at a height below 1,800 m (1.12 miles) above the sea level
Installed on a workbench or in an ELV box: 0ºC to 40ºC (32ºF to 104ºF) at a height below 1,800 m (1.12 miles) above the sea level
Note: At a height ranging from 1800 m (1.12 miles) to 5000 m (3.11 miles) above the sea level, the maximum operating temperature decreases by 1°C (1.8°F) for every increase in altitude of 220 m (721.78 ft.).
–40°C to +70°C (–40ºF to +158ºF)
10% to 90% RH
10% to 90% RH
5% to 90% RH
5% to 95% RH
Intelligent temperature control
The temperature alarm and overheat protection functions are supported.
Electromagnetic compatibility (EMC)
GB/T9254.1
GB/T9254.1
Safety standard
GB 4943.1
GB 4943.1
Dimension (W x D x H)
120 mm x 25 mm x 40 mm (4.72 in. x 0.98 in. x 1.57 in.)
1.5 kg (3.30 lbs, including the package)
0.2 kg (0.44 lbs, including the package)
RG-PF2920U-4GT1MS-P
RG-PF2920-DPBOX-P
802.1Q VLAN
4K IEEE 802.1Q VLANs
Port-based VLAN
DHCP
Password protection
EEE
APD port sleeping
CLI-based configuration and management not required, visualized Web management
IoT MQTT
Syslog/Debug and SNTP
Информация для заказа
RG-PF2920U-4GT1MS-P
The 4-port PoE/PoE+ switch provides 1 x uplink GE optical port and 4 x downlink 10M/100M/1000M auto-negotiation electrical ports, and is connected to the hybrid cable (1 x GE/2.5GE SFP port and a round DC plug). The switch supports PoE/POE+ power supply of 4 x 15 W (or 2 x 30 W). A fanless design is adopted, and an optical link fault LED is provided.
RG-PF2920-DPBOX-P
The single-port media converter is connected to a hybrid cable in the uplink direction (GE SFP port + circular DC socket) and provides a PoE/PoE+ port in the downlink direction.
Technical Support
Technical Support
Get in Touch
Get in Touch
