404
RG-S6980-64QC Сети центров обработки данных - 1
RG-S6980-64QC Сети центров обработки данных - 2
RG-S6980-64QC Сети центров обработки данных - 3
RG-S6980-64QC Сети центров обработки данных - 4
RG-S6980-64QC Сети центров обработки данных - 5
RG-S6980-64QC Сети центров обработки данных - 6
RG-S6980-64QC Сети центров обработки данных - 7
RG-S6980-64QC Сети центров обработки данных - 8
RG-S6980-64QC Сети центров обработки данных - 9
RG-S6980-64QC Сети центров обработки данных - 10
RG-S6980-64QC – 64-Port 400GE Data Center Core Switch, 4 RU
High-density 400GE Fixed Switch with 400GE ZR/ZR+ Optical Modules, Supporting Long-Distance Interconnection
  • High-density 400GE switch with 64 x 400GE QSFP-DD ports in the 4-RU space
  • 400GE QSFP-DD ports, interconnection at the distance of up to 120 km, and smooth and rapid data communication
Основные характеристики
Data Center 400GE Core Switch RG-S6980-64QC
High-speed and high-density core switch in a data center with 64 x 400GE QSFP-DD ports in the 4 RU space, delivering scalable,
high-performance and high-bandwidth services and coping with interconnection on a large data center network
IPv4/IPv6 Host Routing Entries
1000K/640K
Buffer
113.66MB
400GE ZR/ZR+ optical modules are used for interconnection reducing intermediate transmission devices and helping a cloud or hyper-scale
data center network to adapt to growing high-bandwidth services.
and Zero Packet Loss
Характеристики
RG-S6980-64QC
Dimensions (W × D × H)
4 RU
32.8 kg (72.31 lbs., empty chassis)
42 kg (92.59 lbs., a chassis with four power modules and eight fan modules)
51.2 Tbps
10300 Mpps
Service port
64 x 100GE/200GE/400GE QSFP-DD ports
Management port
4 x power module slots
8 x fan module slots
Maximum power consumption: 2400 W
Typical power consumption: 1760 W
Static power consumption: 500 W
RG-PA1200I-F (AC input)
8.5 A (200 V AC to 240 V AC)
Power port type: C14
RG-PA1200I-F (HVDC input):
Rated input voltage: 240 V DC
Rated current: 6.5 A
RG-S6980-64QC
Layer 2 Protocols
IEEE 802.3ae (10GBase), IEEE 802.3ak, IEEE 802.3an, IEEE 802.3x, IEEE 802.3ad (Link Aggregation Control Protocol)), IEEE 802.1p, IEEE 802.1Q, IEEE 802.1D (STP), IEEE 802.1w (RSTP), IEEE 802.1s (MSTP), Jumbo Frame (9 KB)
Layer 3 Protocols (IPv4)
IPv6 Basic Protocols
IPv6 Features
Data Center Features
RDMA
VXLAN, BGP-EVPN
PFC deadlock prevention
RALB, AILB
Visualization
sFLOW sampling
Priority marking/remarking
HA Design
Security Features
Network foundation protection policy (NFPP), CPP, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, broadcast packet suppression, hierarchical user management
Management Mode
SNMP v1/v2c/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, Syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm, and temperature alarm
Other Protocols
Ресурсы
Информация о заказе
RG-S6980-64QC
Fixed 64 × 400GE ports, four power supply module slots, and eight fan slots
RG-PA1200I-F
M2EFAN II-F
Fan module, supporting 7+1 redundancy, hot swapping, and front-to-rear ventilation design
100G Optical Transceivers
400G Optical Transceivers
400G-QDD-SR8-MM850
400G-QDD-FR4-SM1310
400G-QDD-DR4-SM1310
Часто задаваемые вопросы
404
