Recommended as an egress router for networks of public sector commission offices, government at the district and county levels.
| Hardware Specifications |
RG-RSR30-XA-24 |
| Port Specifications |
| Fixed service port |
16 x 10/100/1000BASE-T ports 8 x 10GE SFP+ ports |
| Fixed management port |
1 x RJ45 console port |
| USB |
1 x USB 2.0 port (Type-A connector) |
| Module slot |
4 x expansion module slots 2 x power module slots |
| System Specifications |
| Switching capacity |
272 Gbps |
| Packet forwarding rate |
4 Mpps |
| ARP table size |
24,000 |
| Number of IPv4 unicast routes |
300,000 |
| Number of IPv4 multicast routes |
2,048 |
| Number of IPv6 unicast routes |
300,000 |
| Number of IPv6 multicast routes |
1,024 |
| Number of IGMP groups |
1,000 |
| Number of MLD groups |
1,000 |
| Number of ACEs |
16,000 |
| Dimensions and Weight |
440 mm x 420 mm x 44 mm (17.32 inch. x 16.56 in. x 1.73 in.) |
| Rack height |
1 RU |
| Unit weight |
< 7.8 kg (17.19 lbs, full configuration without packaging materials, with the nameplate at the bottom) |
| Power supply and consumption |
| Maximum power consumption |
150 W |
| Power module redundancy |
1+1 redundancy |
| Power input |
RG-PA150IB-F (AC input): ● Rated input voltage: 100 V AC to 240 V AC, 50 Hz to 60 Hz ● Maximum input voltage: 90 V AC to 264 V AC, 47 Hz to 63 Hz ● Maximum input current: 3 A RG-PD150IB-F (DC input): ● Rated input voltage: -48V~-60V DC ● Maximum input voltage: -36V~-75V DC ● Maximum input current: 5 A |
| Power output |
RG-PA150IB-F (AC input): ● Output voltage: 12 V ● Maximum output corrent: 12.5 A RG-PD150IB-F (DC input): ● Output voltage: 12 V ● Maximum output corrent: 12.5 A |
| Maximum output power |
RG-PA150IB-F: 150 W RG-PD150IB-F: 150 W |
| Temperature |
Operating temperature: 0°C to 50°C (32°F to 122°F) Storage temperature: –40°C to 70°C (–40°F to +158°F) |
| Humidity |
| Altitude |
Operating altitude: 0 m to 5,000 m (0 ft. to 16,404.20 ft.) Storage altitude: 0 m to 5,000 m (0 ft. to 16,404.20 ft.) |
| Surge protection |
6 kV |
| RG-RSR30-XA Series |
| Model |
Description |
| Ethernet switching |
Jumbo frame length: 2,000 bytes |
| 802.3az EEE |
| LLDP/LLDP-MED |
| IP service |
Static and dynamic ARP |
| DHCP server, DHCP relay, and DHCP client |
| FTP, TFTP, FTPv6, and TFTPv6 |
| NTP, SNTP, and NTPv6 |
| NAT |
| Strict and loose RPF uRPF ignoring default routes |
| ND |
| DNS |
| IPv4/IPv6 VRF |
| DHCP server, DHCPv6 client, and DHCPv6 relay |
| ND and ND snooping |
| IPv6 GRE tunnel |
| IP routing |
IPv4 and IPv6 static routing, and static blackhole routes |
| RIP v1/v2 and RIPng |
| OSPFv2 and OSPFv3 |
| IS-ISv4 and IS-ISv6 |
| BGP and BGP4+ |
| Routing policies |
| BGP4, BGP4+, and MP-BGP |
| IPv4 VRRP v2/v3 and IPv6 VRRP v3 |
| IPv4 and IPv6 PBR |
| Multicast |
IGMP v1/v2/v3 |
| Static multicast routing |
| PIM-DM, PIM-SM, PIM-SSM, PIM-SSMv6, PIM-SMv6, and other multicast routing protocols |
| MSDP for inter-domain multicast |
| MLDv1/v2 |
| MPLS |
Basic MPLS functions |
| MPLS forwarding |
| 6PE/6VPE interconnection with IPv4/IPv6 MPLS backbone network |
| MPLS MIB (RFC 1273, 4265, 4382) |
| L3VPN |
| LSP |
| LDP |
| ACL and QoS |
Standard IP ACLs |
| Extended IP ACLs |
| Extended MAC ACLs |
| IPv6 ACLs |
| Applying ACLs to interfaces |
| MPLS QoS |
| Security |
Multiple AAA modes |
| RADIUS authentication, authorization, and accounting |
| TACACS+ |
| Attack defense |
| Password security |
| RNFP |
| CPP |
| FPM |
| PKI |
| IPsec VPN(AES-128,AES-256) |
| VPDN |
| SSHv1 and SSHv2 |
| Global IP-MAC binding |
| Login authentication and password security |
| Reliability |
BFD |
| GR |
| DLDP |
| ECMP |
| Hot swapping |
| NMS and maintenance |
SPAN and ERSPAN |
| SNMP v1/v2c/v3 |
| System operation logging |
| IPFIX |
| Command line configuration through console, AUX Modem, Telnet, and SSH |
| RMON (1, 2, 3, 9) |
| NETCONF |
| CWMP |
| gRPC |
| Interface |
Ethernet interface |
| Model |
Description |
| RG-RSR30-XA-24 |
RG-RSR30-XA-24 chassis, 8 x 10GE SFP+ WAN ports and 16 x 10/100/1000BASE-T WAN ports, 4 x Expansion module slots, 1 x USB 2.0 port (Type-A connector), 1 x RJ45 console port |
Power Modules
| Model |
Description |
| RG-PA150IB-F |
150 W AC power module |
| RG-PD150IB-F |
150 W DC power module |
