RG-MUX-8LC/LC Коммутаторы - 1
RG-MUX-8LC/LC Коммутаторы - 2
RG-MUX-8LC/LC Коммутаторы - 3
RG-MUX-8LC/LC Коммутаторы - 4
RG-MUX-8LC/LC Коммутаторы - 5
RG-MUX-8LC/LC Коммутаторы - 6
RG-MUX-8LC/LC Коммутаторы - 7
RG-MUX-8LC/LC Коммутаторы - 8
RG-MUX-8LC/LC Коммутаторы - 9
RG-MUX-8LC/LC Коммутаторы - 10
RG-MUX-8LC/LC All-Optical Modular 8-Port Transparent Distribution Device
Modular transparent distribution device supporting flexible configuration and realizing passive distribution nodes and exclusive FTTR bandwidth of 10 Gbps/1 Gbps
RG-MUX-8LC/LC 8-Port Transparent Distribution All-Optical Network Passive Device
An 8-port transparent distribution device on the building side supports both 10 Gbps and 1 Gbps per port, and can accommodate up to 48 ports when fully loaded.
The device integrates WDM technology, which allows for a network architecture reduced from three layers to two layers. With WDM, services from the core side to the access side are transparently transmitted, realizing passive distribution nodes.
Характеристики
Product Specifications
RG-MUX-8LC/LC
RG-MUX-8LC/LC-H
RG-MUX-EXT
1 x multiplexing port
Wavelength range
1271 nm to 1571 nm (CWDM)
Channel spacing
20 nm
20 nm
20 nm
Channel bandwidth
±6 nm
±6 nm
±6 nm
Insertion loss
< 3.7 dB
< 2.6 dB
< 4.2 dB
Return loss
> 45 dB
> 45 dB
> 45 dB
Polarization loss
< 0.3 dB
< 0.3 dB
< 0.3 dB
Adjacent channel isolation
> 25 dB
> 25 dB
> 35 dB
> 35 dB
LC/UPC
LC/UPC
LC/UPC
0.25 kg (0.55 lbs)
0.25 kg (0.55 lbs)
0.15 kg (0.33 lbs)
4.53 kg (9.99 lbs)
Communication standard
GR-1221-Core and GR-1209-Core
RG-MUX-BOX
0.9 kg (1.98 lbs)
11.5 kg (25.35 lbs)
Ресурсы
Информация о заказе
RG-MUX-8LC/LC
RG-MUX-8LC/LC-H
RG-MUX-EXT
RG-MUX-BOX
Часто задаваемые вопросы
