404
RG-CS86-20XS4VS2QXS-D Сети малого и среднего бизнеса - 1
RG-CS86-20XS4VS2QXS-D Сети малого и среднего бизнеса - 2
RG-CS86-20XS4VS2QXS-D Сети малого и среднего бизнеса - 3
RG-CS86-20XS4VS2QXS-D Сети малого и среднего бизнеса - 4
RG-CS86-20XS4VS2QXS-D Сети малого и среднего бизнеса - 5
RG-CS86-20XS4VS2QXS-D Сети малого и среднего бизнеса - 6
RG-CS86-20XS4VS2QXS-D Сети малого и среднего бизнеса - 7
RG-CS86-20XS4VS2QXS-D Сети малого и среднего бизнеса - 8
RG-CS86-20XS4VS2QXS-D Сети малого и среднего бизнеса - 9
RG-CS86-20XS4VS2QXS-D Сети малого и среднего бизнеса - 10
RG-CS86-20XS4VS2QXS-D 20-Port 10/2.5GE(SFP+), Layer 3 Ruijie Core/Aggregation Switch with Cloud Management, 4-Port 25/10GE(SFP28), 2-Port 40GE
Suitable for small & medium enterprise core, or large-scale campus network aggregation switch
  • 20 x 10GE SFP+ ports (Compatible with 2.5GE), 4 x 25GE SFP28 ports, and 2 x 40GE QSFP+ ports for uplink
  • Comprehensive QoS policies for flexible network resource allocation and stable services
Cost-effective Full 10GE Layer 3 Core/Aggregation Switch
Suitable for SME network core and large-scale network aggregation, 20 x 10GE ports and 4 x 25GE ports for flexible access, 2 x 40GE ports for high-performance uplink
and Network Connectivity
Optical Port Fault Isolation
multi-plane flow classification and control policy based on MAC flow, IP flow and application flow,
accurate resource allocation for multi-service traffic makes congestion a thing of the past, delivering high-quality networks.
Flexible management modes
Характеристики
20 x 1GE/2.5GE/10GE SFP+ ports
4 x 10GE/25GE SFP28 ports
Note: One switch provides a maximum of 32 x 10GE ports.
2 x fan power module slots
Fan module
M1SFAN I-F (pre-installed 2)
570 Mpps
760 Gbps
32,768
In: 2,500
Out: 1,000
440 mm x 330 mm x 43.6 mm (17.32 in. x 12.99 in. x 1.72 in.)
545 mm x 500 mm x 232 mm (21.46 in. x 19.69 in. x 9.13 in.)
4.6 kg (10.14 lbs) (empty chassis with 2 fan modules)
6.40 kg (14.11 lbs) (empty chassis with 2 fan modules)
1+1 power redundancy
● Rated input voltage: 100 V AC to 240 V AC, 50 Hz to 60 Hz
85 W
2 x pluggable fan modules
≤ 78 dB
Fan speed regulating and alarm function
Temperature alarming
Ethernet Switching
Super VLAN, private VLAN
MAC VLAN, port-based VLAN, protocol-based VLAN, IP subnet-based VLAN
IP Routing
IGMP filtering, IGMP immediate leave
Telnet
Ресурсы
Информация о заказе
Switch and Power Module
20 x 1GE/2.5GE/10GE SFP+ ports, 4 x 10GE/25GE SFP28 ports, 2 x 40GE QSFP+ ports, supporting up to 32 x 10GE ports
2 x slots for power supply modules, requiring at least one RG-PA150IB-F power module
2 x slots for fan modules, 2 x pre-installed fans (Purchase at least one RG-PA150IB-F module.)
150 W AC power module
  • 20 x 1GE/2.5GE/10GE SFP+ ports support 1GE SFP transceivers, 2.5GE SFP transceiversand 10GE SFP+ transceivers.
25GE
VG-SFP-AOC7M(M)
40G-AOC-10M
40GBASE, QSFP+ active optical cable (AOC), 10 m, including one cable and two optical transceivers
Часто задаваемые вопросы
404
