RG-S6150-24VS8CQ-X Коммутаторы - 1
RG-S6150-24VS8CQ-X Коммутаторы - 2
RG-S6150-24VS8CQ-X Коммутаторы - 3
RG-S6150-24VS8CQ-X Коммутаторы - 4
RG-S6150-24VS8CQ-X Коммутаторы - 5
RG-S6150-24VS8CQ-X Коммутаторы - 6
RG-S6150-24VS8CQ-X Коммутаторы - 7
RG-S6150-24VS8CQ-X Коммутаторы - 8
RG-S6150-24VS8CQ-X Коммутаторы - 9
RG-S6150-24VS8CQ-X Коммутаторы - 10
RG-S6150-24VS8CQ-X Коммутаторы - 11
RG-S6150-24VS8CQ-X 24-Port 25GE All-Optical Layer 3 Managed Core & Aggregation Switch, 100G Uplink
  • Rich port types, 24 x 1GE/10GE/25GE SFP28 ports, and 8 x 40GE/100GE QSFP28 ports for uplink
Основные характеристики
RG-S6150-24VS8CQ-X
Core switch for small and medium-sized networks, or aggregation switch for large networks, with 24 x 25G service ports and eight 100G uplink ports
and Network Connectivity
Optical Port Fault Isolation
Guaranteed Data Transmission
Abundant Multicast Protocols
Enhanced Network Robustness
achieving automatic O&M.
Характеристики
RG-S6150-24VS8CQ-X
RG-S6150-48VS8CQ-X
4 x fan module slots
RG-PA550I II-F
RG-PA550I II-F
M1EFAN II-F (pre-installed 4)
1 x RJ45 MGMT port
RG-S6150-24VS8CQ-X
RG-S6150-48VS8CQ-X
1011.84 Mpps
1011.84 Mpps
2.8 Tbps
4 Tbps
8 GB
8 GB
4 GB DDR4
4 GB DDR4
35 MB
35 MB
RG-S6150-24VS8CQ-X
RG-S6150-48VS8CQ-X
RG-PA550I II-F (AC input):
RG-PA550I II-F: 550 W
270W
300 W
RG-S6150-24VS8CQ-X
RG-S6150-48VS8CQ-X
9.65 kg (21.27 lbs)
9.91 kg (21.85 lbs)
RG-S6150-24VS8CQ-X
RG-S6150-48VS8CQ-X
4 x pluggable fan modules
Maximum value: < 73 dB
3+1 redundancy
Automatic speed adjustment
MGMT Port: 4kV
RG-S6150-24VS8CQ-X
RG-S6150-48VS8CQ-X
Software Specifications
RG-S6150-X Series
800 Gbps
160,000
9,600
80,000
In: 28,000 Out:4000
RG-S6150-X Series
Basic QinQ and selective QinQ
Non blocking
GRE tunnel
IP routing
SVI: 4k supported
MCE
Stateless auto configuration
IPv4/IPv6 VRF
IPv4/IPv6 PBR
IGMPv1/v2/v3 and IGMP proxy
MLD snooping
ACL80 and IPv6 ACL
ACL redirection
Multi-AAA
Global IP-MAC binding
MAB authentication
SSH
Loose and strict RPF
uRPF ignoring default routes
M-LAG
IPv4 VRRP v2/v3 and IPv6 VRRP
Hot swapping of fan modules
NTP an SNTP
FTP and TFTP
SNMP v1/v2/c3
Ruijie Could-based management
LAN access to VXLAN
IPv4 over IPv4
Distributed gateway
IPv6 over IPv4
EVPN VXLAN
VXLAN static route
Anycast gateway
VXLAN bridging mode
VXLAN routing mode
Static VXLAN tunnel creation
Ресурсы
Информация о заказе
RG-S6150-24VS8CQ-X
RG-S6150-48VS8CQ-X
RG-PA550I II-F
RG-24VS-LIC
RG-48VS-LIC
25GE
VG-SFP-AOC7M(M)
Часто задаваемые вопросы
