RG-S5310-24SFP4XS-E 스위치 - 1
RG-S5310-24SFP4XS-E 스위치 - 2
RG-S5310-24SFP4XS-E 스위치 - 3
RG-S5310-24SFP4XS-E 스위치 - 4
RG-S5310-24SFP4XS-E 스위치 - 5
RG-S5310-24SFP4XS-E 스위치 - 6
RG-S5310-24SFP4XS-E 스위치 - 7
RG-S5310-24SFP4XS-E 스위치 - 8
RG-S5310-24SFP4XS-E 스위치 - 9
RG-S5310-24SFP4XS-E 스위치 - 10
RG-S5310-24SFP4XS-E, 24포트 GE 광 레이어 3 관리형 액세스 스위치
RG-S5310-24SFP4XS-E
24 x 1GE SPF ports, providing high-speed network experience for short-distance services
Enhanced Network Robustness
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
24 x 1GE SPF ports
48 x 1GE SPF ports
RG-PD150IB-F
RG-PA70IB
RG-PD150IB-F
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
115 Mpps
158 Mpps
154 Gbps
211 Gbps
3 MB
32,000
4,000/16,000 (authorized)
ND table size
2,000/8,000 (authorized)
8,000/12,000 (authorized)
2,500
1,200
Ingress: 3,500
Egress: 1,500
Number of IGMP groups
2,500
Number of MLD groups
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
4.2 kg
(9.26 lbs)
4.5 kg
(9.92 lbs)
6.38 kg (14.07 lbs)
6.58 kg (14.51 lbs)
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
RG-PA150IB-F (AC input)
  • Rated input voltage: 100 V AC to 240 V AC, 50/60 Hz
  • Maximum input voltage: 90 V AV to 264 V AC, 47 Hz to 63 Hz
  • Maximum input current: 3 A
RG-PD150IB-F (DC input):
  • Rated input voltage: –48 V DC to –60 V DC
  • Maximum input voltage: –36 V DC to –75 V DC
  • Maximum input current: 5 A
RG-PA70IB (AC input):
  • Maximum input voltage: 90 V AC to 264 V AC, 47 Hz to 63 Hz
Maximum input current: 2 A
RG-PA70IB: 70 W
RG-PD150IB-F: 150 W
RG-PD150IB-F: 150 W
85 W
108 W
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
27°C (80.6°F): 38.9 dB
45°C (113°F): 53.7 dB
Air discharge: 8 kV
Contact discharge: 6 kV
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
RG-S5310-E Series
Ethernet Switching
Super VLAN and private VLAN
Basic QinQ and selective QinQ
Auto errdisable recovery
BPDU filter
Port fast
Root guard
LLDP/LLDP-MED and LLDP IPv6
MAC address filtering
GRE tunnel
IP Routing
IPv4 and IPv6 static routing
OSPFv2, OSPFv3, and GR
IPv4/IPv6 PBR
IGMPv1/v2 snooping
MLDv1/v2 and MLD proxy
MLDv1/v2 snooping
Global IP-MAC binding
MAB authentication
Basic LACP
Inter-VSU AP
Hot swapping of power modules
Local and remote stacking
SPAN, RSPAN and ERSPAN
SNTP
CLI (Telnet/Console)
SNMP v1/v2/c3
Web
Syslog/Debug
MACC
VXLAN (authorized)
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
RG-S5310-24GT4XS-P-E
RG-S5310-48GT4XS-P-E
Power Module
RG-PA70IB
70 W AC power module
RG-PD150IB-F
150W DC power module
License
RG-VXLAN-MPLS-ENTRY-LIC
Optical Transceivers
