RG-S5315-24MG6XS-UP-E 스위치 - 1
RG-S5315-24MG6XS-UP-E 스위치 - 2
RG-S5315-24MG6XS-UP-E 스위치 - 3
RG-S5315-24MG6XS-UP-E 스위치 - 4
RG-S5315-24MG6XS-UP-E 스위치 - 5
RG-S5315-24MG6XS-UP-E 스위치 - 6
RG-S5315-24MG6XS-UP-E Next-Generation 24-Port 2.5GE Multi-GE Access Switches with 10GE Uplinks, Supporting up to 90 W (PoE++) Power Output per Port
Featuring high security, efficiency, energy conservation, and independent innovation and delivering faster hardware processing performance and more convenient operation experience.
2.5GE Bandwidth Effortlessly Handles Wi-Fi 7 or Later APs, Beyond Gigabit Limits
Supports PoE++, Delivering Up to 90 W per Port to Power a Variety of Terminal Devices
Hot-Swappable Power Modules, Supporting 1+1 Power Supply Redundancy
RG-UNC Unified Networking Central – Simplified Management, Automated and Effortless Operations
2.5GE Multi-GE Switch RG-S5315-24MG6XS-UP-E
The RG-S5315-E series switch provides 24 100/1000/2500BASE-T ports for access and six 1G/2.5G/10G SFP+ ports for uplink communication, which can better adapt to terminals and deliver faster hardware processing performance and more convenient operation experience.
Upgrade from 1GE to 2.5GE, 2.5X faster without changing cables, ideal for Wi-Fi 6E/7 or Later APs and enabling smoother 4K/8K video/streaming media, High-definition video conferencing and AR/VR applications.
The switch automatically detects and supplies the optimal power for connected PoE devices. With each port supporting up to 90 W (PoE++) and a total PoE budget of 1,600 W, it meets the demands of high-power applications such as security surveillance, teleconferencing systems, and Wi-Fi 6E/7 access points.
2 power modules slots supports hot-swappable and 1+1 redundancy, realizing failover within seconds and service continuity during power replacement, ensuring link reliability.
Unified platform management, real-time monitoring of network status, comprehensive insight into the user experience chain, intelligent analysis and diagnosis, and comprehensive protection of the business experience.
Supports end-to-end operation and maintenance of optical links, and makes optical networks visible, manageable, and controllable.
Port Specifications RG-S5315-24MG6XS-UP-E
Fixed service port 24 x 100/1000/2500BASE-T ports, supporting PoE/PoE+/ PoE++
6 x 1GE/2.5GE/10GE SFP+ ports
Module slot 2 x power module slots
Power module RG-PA1000I-P-F
Fixed management port 1 x RJ45 console port
USB port 1 x USB port
System Specifications RG-S5315-24MG6XS-UP-E
System packet forwarding rate *1 180 Mpps
System switching capacity *2 240 Gbps
CPU Dual-core CPU built-in MAC processor, each core with the clock speed of 1.0 GHz
Real-time clock (RTC) Supported
BootROM 16 MB
Flash memory 256 MB
Memory 1 GB
Switch buffer 2 MB
Dimensions and Weight RG-S5315-24MG6XS-UP-E
Unit dimensions (W x D x H) 442 mm × 420 mm × 43.6 mm (17.40 in. x 16.54 in. x 1.72 in.)
Shipping dimensions (W x D x H) 575 mm × 568 mm × 185 mm (22.64 in. x 22.36 in. x 7.28 in.)
Rack height 1 RU
Unit weight 4.1 kg (9.04 lbs)
Shipping weight 6.8 kg (14.99 lbs)
Power Supply and Consumption RG-S5315-24MG6XS-UP-E
Power supply 2 x pluggable power modules
Power module redundancy Dual IEEE 802.3at or IEEE 802.3af power supplies are supported, and power supplies can work in hot standby mode.
Power input RG-PA600I-P-F (AC input):
- Rated input voltage: 100 V AC to 240 V AC, 50 Hz to 60 Hz
- Maximum input current: 8 A
- Rated input voltage: 100 V AC to 130 V AC, 50 Hz to 60 Hz
- Maximum input current: 12 A
- Rated input voltage: 200 V AC to 240 V AC, 50 Hz to 60 Hz
Maximum output power RG-PA600I-P-F: 600 W
- 100 V AC to 130 V AC: 930 W;
- 200 V AC to 240 V AC: 1000 W;
PoE port All RJ45 ports support PoE/PoE+/PoE++ (IEEE802.3af/at/bt) power supply.
PoE cable pairs Four pairs (1--2, 3--6, 4--5 and 7--8 pairs)
PoE output power Each PoE port provides up to 90 W of power.
- 1 x RG-PA600I-P-F: 470 W
- 2 x RG-PA600I-P-F: 940 W;
- 1 x RG-PA1000I-P-F: 800 W
- 2 x RG-PA1000I-P-F: 1600 W;
a maximum output of 1600 W over 24 ports
Maximum power consumption ≤ 75 W (without PoE load)
< 1675 W (with PoE full load)
Environment and Reliability RG-S5315-24MG6XS-UP-E
Temperature Operating temperature: 0°C to 45°C (32°F to 113°F)
Humidity Operating humidity: 10% to 90% RH (non-condensing)
Altitude Operating altitude: 0--5,000 m (0--16,404 ft.)
Storage altitude: 0--5,000 m (0--16,404 ft.)
Mean time between failure (MTBF) > 200,000 hours
Fan 2 x fixed fan modules
Heat Dissipation Air intake from the left and front panel, air exhaust from the rear panel
Acoustic noise SPL at ambient temperature of 27°C (80.6°F):
31.9 dB (30% PoE load, 2 RG- PA600I-P-F power modules, adjusted fan speed), 32.3 dB (30% PoE load, 2 RG-PA1000I-P-F power modules, adjusted fan speed)
Power module hot swapping Supported
USB hot swapping Supported
Cable hot swapping Supported by all ports
Power Supply Monitoring Obtaining the power supply model: supported
Obtaining the in-place status: supported
Fault alarm: supported
Fan monitoring Automatic fan speed regulation
Fan failure alarm
Temperature monitoring Temperature monitoring: supported
Temperature alarm: supported
Overtemperature protection: supported
ESD ESD contact/air discharge: 6 kV/8 kV
Surge protection Service port: common mode 10 kV
Certification and Regulatory Compliance RG-S5315-24MG6XS-UP-E
Safety regulations IEC 62368-1, EN 62368-1, BS EN 62368-1
EMC regulations EN 300386, EN 55032 Class A, EN 55035, EN IEC 61000-3-2, EN 61000-3-3, EN 61000-4-2, EN 61000-4-3, EN 61000-4-4, EN 61000-4-5, EN 61000-4-6, EN 61000-4-11
RoHS European RoHS Directive 2011/65/EU & Amendment(EU) 2015/863
Performance and Capacity RG-S5315-24MG6XS-UP-E
Maximum number of VSU members 4
VSU bandwidth 40 Gbps
Maximum number of SVIs 990
Maximum number of MAC address entries 32,000
Maximum number of ARP address entries 6,000
Maximum number of ND entries 4,000
Maximum number of IPv4 unicast routes 12,000
Maximum number of IPv6 unicast routes 3,000
Maximum number of VRF instances 255
Maximum number of ACEs In:750 Out:400
Model RG-S5315-24MG6XS-UP-E
IEEE 802.1Q VLAN A maximum of 4,000 IEEE 802.1Q VLANs
Port-based VLAN
MAC-based VLAN
GARP VLAN Registration Protocol (GVRP)
QinQ Basic QinQ
ACL Standard IP ACLs (IP-based hardware ACLs)
Extended IP ACLs (hardware ACLs based on IP addresses or TCP/UDP port IDs)
Expert ACLs (hardware ACLs based on flexible combinations of the VLAN ID, Ethernet type, MAC address, IP address, TCP/UDP port ID, protocol type, and time)
ACL 80
Global ACL
QoS Port traffic identification
Rate limiting on port traffic
802.1p/differentiated services code point (DSCP)/type of service (ToS) traffic classification
Strict priority (SP), Weighted Round Robin (WRR), and SP+WRR queue scheduling
Mirroring One-to-one mirroring, many-to-one mirroring, one-to-many mirroring
Switched port analyzer (SPAN) and remote SPAN
DHCP DHCP server
IPv6 DHCP snooping
IPv6 DHCP relay
Security feature 3-tuple binding (IP address, MAC address, and port)
Port- and MAC-based 802.1X authentication
MAC Authentication Bypass (MAB)
Dynamic ARP Inspection (DAI)
RADIUS and TACAS+
Secure Shell (SSH) and SSH V2.0
Bridge Protocol Data Unit (BPDU) guard
Ring network protocol In compliance with the G.8032 international standard ring network protocol Ethernet Ring Protection Switching (ERPS), well compatible with other products that support this protocol
PoE IEEE 802.3af/at/bt-compliant power supply
Automatic and energy-efficient power supply management modes
Uninterruptible power supply upon warm start
Scheduled power-on and power-off of PoE ports based on the time policy
IP routing IPv4/IPv6 static routing
Routing Information Protocol (RIP), RIP next generation (RIPng), Open Shortest Path First Version 2 (OSPFv2), and OSPFv3
Routing policy
Basic IPv6 protocols IPv6 addressing, Neighbor Discovery (ND), ICMPv6, IPv6 ping, IPv6 tracert, and other IPv6 protocols
SAVI Neighbor Solicitation (NS), Neighbor Advertisement (NA), Router Solicitation (RS), and Router Advertisement (RA) packet attack defense
Preventing an unauthorized DHCPv6 server from allocating IPv6 addresses
Cache of invalid terminal information
VSU VSU
Local stacking and remote stacking
Cross-chassis link bundling within the stack
Virtualization through standard service ports
Reliability 1+1 power redundancy
Bidirectional Forwarding Detection (BFD)
IPv6-based gateway hot backup protocol (Virtual Router Redundancy Protocol Version 3 [VRRPv3])
ZTP CWMP (TR-069)
Management feature SNMPv1/v2c/v3, CLI (Telnet/console), RMON (1, 2, 3, 9), Web, SSH, syslog/debugging, Network Time Protocol (NTP)/Simple Network Time Protocol (SNTP), File Transfer Protocol (FTP), Trivial File Transfer Protocol (TFTP), and sFlow
Switch and Power Module
Model Description
RG-S5315-24MG6XS-UP-E 24 x 100/1000/2500BASE-T ports with auto-negotiation, supporting PoE/PoE+/PoE++ and the maximum PoE output power of 1600 W, 6 x 1GE/2.5GE/10GE SFP+ ports, 2 modular power supply slots (at least one power module needs to be configured, only when the PoE load of the whole device is less than PoE output power of single power supply and dual power supplies are used, redundancy is supported)
Note: 6 x 1GE/2.5GE /10GE SFP+ ports support 1GE SFP transceivers, 2.5GE SFP transceivers and 10GE SFP+ transceivers.
Power Module
Model Description
RG-PA600I-P-F 600 W AC power module, PoE power module
RG-PA1000I-P-F 1,000 W AC power module, PoE power module
GE Optical Transceivers
Model Description
MINI-GBIC-GT 1000BASE-X to 1000BASE-T, copper SFP transceiver, RJ45, 100 m over Cat 5e/6/6a
MINI-GBIC-SX-MM850 1000BASE-SX, SFP transceiver, 850 nm, Duplex LC, 500 m over MMF
MINI-GBIC-LX-SM1310 1000BASE-LX, SFP transceiver, 1310 nm, Duplex LC, 10 km over SMF
MINI-GBIC-LH40-SM1310 1000BASE-LH, SFP transceiver, 1310 nm, Duplex LC, 40 km over SMF
MINI-GBIC-ZX80-SM1550 1000BASE-ZX, SFP transceiver, 1550 nm, Duplex LC, 80 km over SMF
GE-SFP-LX20-SM1310-BIDI 1000BASE-LX, SFP transceiver, TX1310/RX1550, BiDi LC, 20 km over SMF
GE-SFP-LX20-SM1550-BIDI 1000BASE-LX, SFP transceiver, TX1550/RX1310, BiDi LC, 20 km over SMF
GE-SFP-LX03-SM1310-BIDI-I 1000BASE-LX, SFP transceiver, TX1310/RX1550, BiDi LC, 3 km over SMF
GE-SFP-LX03-SM1550-BIDI-I 1000BASE-LX, SFP transceiver, TX1550/RX1310, BiDi LC, 3 km over SMF
2.5GE Optical Transceivers
Model Description
2.5G-SFP-LX03-SM1310-BIDI-I 2500BASE-LX, SFP transceiver, TX1310/RX1550, BiDi LC, 3 km over SMF
2.5G-SFP-LX03-SM1550-BIDI-I 2500BASE-LX, SFP transceiver, TX1550/RX1310, BiDi LC, 3 km over SMF
10GE Optical Transceivers
Model Description
XG-SFP-SR-MM850 10GBASE-SR, SFP+ transceiver, 850nm, Duplex LC, 300 m over MMF
XG-SFP-LR-SM1310 10GBASE-LR, SFP+ transceiver, 1310nm, Duplex LC, 10 km over SMF
XG-SFP-ER-SM1550 10GBASE-ER, SFP+ transceiver, 1550nm, Duplex LC, 40 km over SMF
XG-SFP-ZR-SM1550 10GBASE-ZR, SFP+ transceiver, 1550nm, Duplex LC, 80 km over SMF
XG-SFP-LR10-SM1270-BIDI-I 10GBASE-LR, SFP+ transceiver, TX1270/RX1330, BiDi LC, 10 km over SMF
XG-SFP-LR10-SM1330-BIDI-I 10GBASE-LR, SFP+ transceiver, TX1330/RX1270, BiDi LC, 10 km over SMF
XG-SFP-AOC1M 10GBASE, SFP+ active optical cable (AOC), 1 m, including one cable and two optical transceivers
XG-SFP-AOC3M 10GBASE, SFP+ active optical cable (AOC), 3 m, including one cable and two optical transceivers
XG-SFP-AOC5M 10GBASE, SFP+ active optical cable (AOC), 5 m, including one cable and two optical transceivers
CWDM Transceivers
Model Description
GE-SFP-LR(A1-8)-H 1000BASE-LR, access switch-side group of 8 SFP CWDM transceivers, 8 different wavelengths for 8 access devices, Duplex LC, 10 km over SMF, operating temperature of 0ºC to 70ºC (32ºF to 158ºF)
GE-SFP-LR(A1-8)-H-E 1000BASE-LR, access switch-side group of 8 SFP CWDM transceivers, 8 different wavelengths for 8 access devices, Duplex LC, 10 km over SMF, operating temperature of 0ºC to 85ºC (32ºF to 185ºF)
MG-SFP-LR(A1-8)-H 2.5GBASE-LR, access switch-side group of 8 SFP CWDM transceivers, 8 different wavelengths for 8 access devices, Duplex LC, 10 km over SMF, operating temperature of 0ºC to 70ºC (32ºF to 158ºF)
MG-SFP-LR(A1-8)-H-E 2.5GBASE-LR, access switch-side group of 8 SFP CWDM transceivers, 8 different wavelengths for 8 access devices, Duplex LC, 10 km over SMF, operating temperature of 0ºC to 85ºC (32ºF to 185ºF)
XG-SFP-LR(A1-8)-H 10GBASE-LR, access switch-side group of 8 SFP+ CWDM transceivers, 8 different wavelengths for 8 access devices, Duplex LC, 10 km over SMF, operating temperature of 0ºC to 70ºC (32ºF to 158ºF)
XG-SFP-LR(A1-8)-H-E 10GBASE-LR, access switch-side group of 8 SFP+ CWDM transceivers, 8 different wavelengths for 8 access devices, Duplex LC, 10 km over SMF, operating temperature of 0ºC to 85ºC (32ºF to 185ºF)
