RG-AP180(V3) 무선 - 1
RG-AP180(V3) 무선 - 2
RG-AP180(V3) 무선 - 3
RG-AP180(V3) 무선 - 4
RG-AP180(V3) 무선 - 5
RG-AP180(V3) 무선 - 6
RG-AP180(V3) 무선 - 7
RG-AP180(V3) 무선 - 8
RG-AP180(V3) 무선 - 1
RG-AP180(V3) 무선 - 2
RG-AP180(V3) 무선 - 3
RG-AP180(V3) 무선 - 4
RG-AP180(V3) 무선 - 5
RG-AP180(V3) 무선 - 6
RG-AP180(V3) 무선 - 7
RG-AP180(V3) 무선 - 8
RG-AP180(V3), Wi-Fi 6 듀얼 라디오 2.976Gbps 실내 월 플레이트 액세스 포인트
Wall Plate Access Point
RG-AP180(V3)
Appearance
Scenario
Dual-Radio
2.4G/5G
4 Spatial Streams
PoE Power Supply
Max. Combined Rate
2.976 Gbps
Power Consumption
10 W
Practical maximum
clientcount indication (per device)
128
Upgraded to Wi-Fi 6
2.976
Gbps
High Concurrency
Low Latency
20 ms.
High Security
wireless connection.
High Speed
Authentication
PSK、WPA、WPA2、WAP
etc. (store)
802.1XAuthentication
(enterprise-class)
Web Authentication
(enterprise-class)
SM-based Authentication
MAC Authentication Bypass
Go to WIS->
Cloud O&M
24h Network Optimization
Real-Time Warning
Fault Locating
RG-AP180(V3)
Four spatial streams
Channels:
Two spatial streams
Channels:
Channels:
● 2.4 GHz: two built-in omnidirectional antennas, with peak antenna gain of 2.5 dBi.
● One integrated vertically polarized omnidirectional antenna, with peak antenna gain of 2 dBi.
Uplink: 1 x 10/100/1000Base-T port, compliant with IEEE 802.3af/at standard (PoE/PoE+)
Downlink: 4 x 10/100/1000Base-T ports
1 x Bluetooth 5.0
● CAPWAP tunnel timeout
● Specific AP locating
Dimensions (W x H x D)
Shipping: 128 mm x 96mm x 59 mm (5.04 in. x 3.78 in. x 2.33 in.)
Main unit: 0.22 kg (0.49 lbs)
Shipping: 0.31 kg (0.68 lbs)
86 mm junction box-mount
● DC power: 10 W
● 802.3at (PoE+): 10 W
● 802.3af (PoE): 10 W
● Idle mode: 3.5 W
DRAM: 2 GB
SPI: 8 MB
Nand: 128 MB
● Maximum transmit power: 21 dBm (126 mW)
● Minimum transmit power: 8 dBm (6.31 mW)
RG-AP180(V3)
17 dBm
–90 dBm
15 dBm
–87 dBm
–78 dBm
15 dBm
–72 dBm
15 dBm
–67 dBm
15 dBm
–64 dBm
12 dBm
–58 dBm
12 dBm
–78 dBm
15 dBm
–72 dBm
15 dBm
–67 dBm
15 dBm
–64 dBm
15 dBm
24 dBm
–88 dBm
–63 dBm
15 dBm
12 dBm
–58 dBm
12 dBm
12 dBm
–52 dBm
5 GHz, 802.11ax (HE160)
–75 dBm
9 dBm
–47 dBm
RG-AP180(V3)
RGOS11.9(6)B9 or later
128
16 (up to 8 BSSIDs per radio)
Maximum number of WLAN IDs
Rate set settings
MU and TAG device locating
Application management
VLAN-based user isolation
Dynamic Policy
CoA/DM
MAC address table size: 1,024
Jumbo frame length: 1,518
IEEE802.1p and IEEE802.1Q
VLAN ID range: 1–4,094
ARP entry aging and proxy ARP
NAT, FTP ALG and DNS ALG
NTP server and NTP client
RG-AP180(V3)
RG-AP180(V3)
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, IEC 62368-1, EN 62368-1, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, EN IEC 62311, EN 18031-1, and EN 18031-2
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP180(V3)] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP180(V3)] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
RG-AP180(V3)
