Indoor network scenarios in the higher education, medical industry, government and commerce
Wi-Fi 6, 5.378 Gbps, 5 Gbps Combo Port
RG-SAP825-SPWi-Fi 6, 2.976 Gbps, 2.5 Gbps Combo Port
RG-SAP815-SPWi-Fi 6, 1.775 Gbps, 1GE Ethernet Port
RG-SAP750-SPWi-Fi 5, 1.167 Gbps, 1GE Ethernet Port
| Hardware Specifications |
RG-SAP750-SP |
| 802.11n |
Four spatial streams ● Radio 1 – 2.4 GHz: 2x2 MIMO, two spatial streams ● Radio 2 – 5 GHz: 2x2 MIMO, two spatial streams Channels: ● Radio 1 – 2.4 GHz: 20 MHz and 40 MHz ● Radio 2 – 5 GHz: 20 MHz and 40 MHz Combined peak data rate: 600 Mbps ● Radio 1 – 2.4 GHz: 6.5 Mbps to 300 Mbps (MCS0 to MCS15 ) ● Radio 2 – 5 GHz: 6.5 Mbps to 300 Mbps (MCS0 to MCS15 ) Radio technologies: Orthogonal Frequency-Division Multiplexing (OFDM) Modulation types: BPSK, QPSK, 16-QAM, 64-QAM Packet aggregation: ● Aggregate MAC Protocol Data Unit (A-MPDU) ● Aggregate MAC Service Data Unit (A-MSDU) Dynamic Frequency Selection (DFS) Cyclic Delay/Shift Diversity (CDD/CSD) Maximum Ratio Combining (MRC) Space-Time Block Coding (STBC) Low-Density Parity Check (LDPC) Transmit beam-forming (TxBF) |
| 802.11ac |
Two spatial streams ● Radio 2 – 5 GHz: 2x2 MIMO, two spatial streams Channels: ● Radio 2 – 5 GHz: 20 MHz, 40 MHz, and 80 MHz Combined peak data rate: 867 Mbps ● Radio 2 – 5 GHz: 6.5 Mbps to 867 Mbps (MCS0 to MCS9) Radio technologies: Orthogonal Frequency-Division Multiplexing (OFDM) Modulation types: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM Packet aggregation: ● Aggregate MAC Protocol Data Unit (A-MPDU) ● Aggregate MAC Service Data Unit (A-MSDU) Dynamic Frequency Selection (DFS) Cyclic Delay/Shift Diversity (CDD/CSD) Maximum Ratio Combining (MRC) Space-Time Block Coding (STBC) Low-Density Parity Check (LDPC) Transmit beam-forming (TxBF) |
| Antenna |
Wi-Fi ● 2.4 GHz: two built-in omnidirectional antennas, with peak antenna gain of 4.3 dBi. ● 5 GHz: two built-in omnidirectional antennas, with peak antenna gain of 5.7 dBi. |
| Port |
1 x 10/100/1000BASE-T port 1 x RJ45 console port (serial console port) |
| Status LED |
1 x multi-color system status LED ● AP power-on status ● Software initialization status ● Wireless user online status |
| Button |
1 x Reset button ● Press the button for shorter than 2 seconds. Then the device restarts. ● Press the button for longer than 5 seconds. Then the device restores to factory settings. |
| Dimensions (W x D x H) |
Main unit: 194 mm x 194 mm x 37 mm (7.64 in. x 7.64 in. x 1.46 in.) Shipping: 460 mm x 360 mm x 242 mm (18.11 in. x 14.17 in. x 9.53 in.) |
| Weight |
Main unit: 0.42 kg (1.0 lbs) Mounting bracket: 0.07 kg (0.2 lbs) Shipping: 0.87 kg (2.0 lbs) |
| Mounting |
Wall/Ceiling-mount (a mounting bracket is delivered with the main unit) |
| Lock option |
Kensington lock and securing latch |
| Input power supply |
The AP supports the following two power supply modes: ● 12 V DC/1.5 A power input over DC connector: The DC connector accepts 2.1 mm/5.5 mm center-positive circular plug. A DC power supply needs to be purchased independently. ● PoE input over LAN 1: The power source equipment (PSE) complies with IEEE 802.3af standard (PoE). Note: If both DC power and PoE are available, DC power is preferred. |
| Maximum power consumption |
Maximum power consumption: 12.95 W ● DC power: 12.95 W ● 802.3af (PoE): 12.95 W ● Idle mode: 6 W |
| Environment |
Storage temperature: –40°C to +70°C (–40°F to +158°F) Storage humidity: 5% RH to 95% RH (non-condensing) Storage altitude: 0 m to 3,000 m (0 ft. to 9,842.52 ft.) Operating temperature: –10°C to +50°C (14°F to 122°F) Operating humidity: 5% RH to 95% RH (non-condensing) Operating altitude: 0 m to 3,000 m (0 ft. to 9,842.52 ft.) Note: At an altitude in the range of 1,800–3,000 m (5,905.51–9,842.52 ft.), every time the altitude increases by 220 m (721.78 ft.), the maximum temperature decreases by 1°C (1.8°F). |
| Mean Time Between Failure (MTBF) |
200,000 hours (22 years) at the operating temperature of 25°C (77°F) |
| System memory |
128 MB DRAM, 32 MB flash |
| Transmit power |
2.4 GHz ● Maximum transmit power: 26 dBm (398.11 mW) 5 GHz ● Maximum transmit power: 26 dBm (398.11 mW) Note: ● Adjusting the transmit power by percentage (recommended) and in 1dBm increments. ● The transmit power is limited by local regulatory requirements. For details, see WLAN Country or Region Codes and Channel Compliance. |
| Radio Frequency Performance |
RG-SAP750-SP |
| Frequency Band and Protocol |
Data Rate |
Maximum Transmit Power per Transmit Chain |
Maximum Receive Sensitivity per Receive Chain |
| 2.4 GHz 802.11b |
1 Mbps |
23 dBm |
–91 dBm |
| 2 Mbps |
23 dBm |
–89 dBm |
| 5.5 Mbps |
23 dBm |
–88 dBm |
| 11 Mbps |
23 dBm |
–85 dBm |
| 2.4 GHz 802.11g |
6 Mbps |
23 dBm |
–89 dBm |
| 24 Mbps |
23 dBm |
–80 dBm |
| 36 Mbps |
21 dBm |
–76 dBm |
| 54 Mbps |
19 dBm |
–70 dBm |
| 2.4 GHz 802.11n (HT20) |
MCS0 |
21 dBm |
–83 dBm |
| MCS7 |
19 dBm |
–65 dBm |
| 2.4 GHz 802.11n (HT40) |
MCS0 |
21 dBm |
–80 dBm |
| MCS7 |
18 dBm |
–62 dBm |
| 5 GHz 802.11a |
6 Mbps |
23 dBm |
–89 dBm |
| 24 Mbps |
23 dBm |
–80 dBm |
| 36 Mbps |
21 dBm |
–76 dBm |
| 54 Mbps |
19 dBm |
–70 dBm |
| 5 GHz 802.11n (HT20) |
MCS0 |
20 dBm |
–83 dBm |
| MCS7 |
18 dBm |
–65 dBm |
| 5 GHz 802.11n (HT40) |
MCS0 |
19 dBm |
–80 dBm |
| MCS7 |
18 dBm |
–62 dBm |
| 5 GHz 802.11ac (VHT20) |
MCS0 |
20 dBm |
–82 dBm |
| MCS9 |
17 dBm |
–57 dBm |
| 5 GHz 802.11ac (VHT40) |
MCS0 |
19 dBm |
–79 dBm |
| MCS9 |
16 dBm |
–54 dBm |
| 5 GHz 802.11ac (VHT80) |
MCS0 |
19 dBm |
–76 dBm |
| MCS9 |
16 dBm |
–51 dBm |
Note Available frequency bands may vary with countries or regions. To use the above-mentioned frequency bands, ensure that they are supported in your country or region. For details, see WLAN Country or Region Codes and Channel Compliance.
Software Specifications |
RG-SAP750-SP |
| Basic Function |
| Applicable software version |
AP_RGOS 11.1(9)B1P37 or later |
| WLAN |
| Maximum number of associated STAs |
256 ● Radio 1: 2.4 GHz, up to 100 connected STAs ● Radio 2: 5 GHz, up to 156 connected STAs |
| Practical maximum client count indication (per device) |
75 |
| Maximum number of BSSIDs |
32 (up to 16 BSSIDs per radio) |
| Maximum number of WLAN IDs |
16 Maximum number of associated STAs per WLAN: 256 |
| STA management |
SSID hiding Band steering Each SSID can be configured with the authentication mode, encryption mechanism, and VLAN attributes independently. Remote Intelligent Perception Technology (RIPT) Intelligent load balancing based on the STA quantity or traffic |
| STA limiting |
SSID-based STA limiting Radio-based STA limiting |
| Bandwidth limiting |
STA/SSID/AP-based rate limiting |
| CAPWAP |
IPv4/IPv6 CAPWAP CAPWAP through NAT MTU setting and fragmentation over CAPWAP tunnels |
| Data forwarding |
Centralized and local forwarding |
| Wireless roaming |
Layer 2 and Layer 3 roaming |
| Wireless locating |
MU and TAG device locating |
| Security and Authentication |
| Authentication and encryption |
Remote Authentication Dial-In User Service (RADIUS) PSK , web, 802.1x and MSCHAPv2 authentication SMS-based and QR code-based guest authentication, and MAB authentication (used with RG-WS series wireless controller) Data encryption: WEP (64/128 bits), WPA-Personal, WPA-Enterprise, WPA2-Personal (PSK, TKIP, CCMP), WPA2-Enterprise, WPA3-Personal (SAE, WPA2/WPA3 transition mode), WPA3-Enterprise (CCMP) |
| Data frame filtering |
Allowlist, static blocklist, and dynamic blocklist |
| WIDS |
User isolation Rogue AP detection and containment |
| ACL |
IP standard ACL, MAC extended ACL, IP extended ACL, and expert-level ACL Time range-based ACL Inbound ACL based on Layer 2 interfaces Inbound ACL based on Layer 3 interfaces Inbound ACL based on wireless interfaces Dynamic ACL assignment based on 802.1X authentication (used with the AC) |
| CPP |
CPU Protect Policy (CPP) |
| NFPP |
Network Foundation Protection Policy (NFPP) |
| Routing and Switching |
| MAC |
Static and filtered MAC addresses MAC address table size: 1,024 Maximum number of static MAC addresses: 1,024 Maximum number of filtered MAC addresses: 1,024 |
| Ethernet |
Jumbo frame length: 1,518 Ethernet II IEEE802.1p and IEEE802.1Q |
| VLAN |
Interface-based VLAN assignment Maximum number of CVIs: 40 Maximum number of SVIs: 40 Maximum number of VLANs: 4,094 VLAN ID range: 1–4,094 |
| ARP |
ARP entry aging, proxy ARP, and IP address conflict detection between downlink users Maximum number of ARP entries: 1,024 ARP check |
| IPv4 services |
Static and DHCP-assigned IPv4 addresses Maximum number of IPv4 addresses configured on each Layer 3 interface: 200 NAT, FTP ALG and DNS ALG |
| IPv6 services |
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, IPv6 ping, IPv6 tracert Maximum number of IPv6 addresses configured on each Layer 3 interface: 16 |
| IP routing |
IPv4/IPv6 static route Maximum number of static IPv4 routes: 1,024 Maximum number of static IPv6 routes: 1,000 |
| Multicast |
Multicast, Multicast-to-unicast conversion |
| VPN |
PPPoE client |
| Network Management and Monitoring |
| Network management |
SNMPv1/v2c/v3 Fault detection and alarm Information statistics and logging |
| Network management platform |
Web management (Eweb) |
| User access management |
Console, Telnet, SSH, FTP client, FTP server, and TFTP client |
| Switchover among Fat, Fit, and cloud modes |
When the AP works in Fit mode, it can be switched to Fat mode through an AC. When the AP works in Fat mode, it can be switched to Fit mode through the console port or Telnet mode. When the AP works in cloud mode, it can be managed through WIS Cloud. |
| Value-added Software |
RG-SAP750-SP |
| Intelligent O&M |
| Experience |
Network operation analysis, such as device stability and signal coverage Measuring users' network experience based on indicators such as the latency, packet loss, signal strength, and channel utilization, and visualizing results of the network experience Statistics on the number of online and offline failures of STAs associated with different APs, average signal strength, and other parameters VIP monitoring and alarm, and custom alarm thresholds STA global experience map and experience coverage evaluation based on the time range STA access protocol replay and fine-grained STA fault diagnosis Note: To support the preceding functions, ensure that the AP works in Fit mode. |
| Network optimization |
Network performance optimization, including one-click network optimization and scenario-based optimization Client steering to cope with roaming stickiness, and experience indicator comparison Client steering to cope with remote association, and experience indicator comparison One-click diagnosis – analyzing problems and providing suggestions |
| Big data |
Baseline analysis – recording the configuration, version, and other changes, and tracking network KPI changes Time capsule – analyzing the device version and configuration change history |
| Regional analysis |
Batch generation of building floor information – uploading floor plans, and dragging and dropping AP positions |
| One-click report |
One-click health report – generating a report on the overall operation of a network |
| Security radar |
Unauthorized Wi-Fi signal location, presentation by category, and containment |
| Cloud Management |
| Management and maintenance |
Uniformly connecting, managing, and maintaining APs, ACs, and other devices, batch device configuration and upgrade, and other functions Deployment through Zero Touch Provisioning (ZTP) – creating configuration templates and automatically applying configured templates One-click discovery of the wired and wireless network topology and topology generation |
| Cloud Authentication |
| Authentication mode |
SMS authentication, fixed account authentication, one-click authentication, Facebook authentication, Instagram authentication, voucher authentication, and other authentication modes Authentication implemented in the cloud, without the need to deploy the local authentication server |
| Customized portal |
Customized Portal authentication page for mobile phones and PCs |
| SMS gateway |
Interconnection with SMS gateways of GUODULINK and Alibaba Cloud |
| Platform Capabilities |
| Big data capabilities |
Mainstream persistence solutions based on Hadoop, MongoDB, and MySQL, providing distributed storage capabilities Spark-based big data computing capabilities Data warehouse building based on Hive, and data model conversion, integration, and other functions |
| Hierarchy and decentralization |
Authorizing different applications for different users to meet service needs of different departments Granting operation permissions to administrators in different scenarios |
| System management |
Account operation, authorization configuration, email configuration, configuration backup, exception alarms, and other system management functions |
| Regulatory Compliance |
RG-SAP750-SP |
| Regulatory compliance |
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, IEC 62368-1, EN 62368-1, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, and EN IEC 62311 |
Note:Ruijie wireless products provide only secure and reliable network protocols and communication ports by default. For details, see Ruijie Default Protocols and Ports for Wireless Products. Proper firewall and security policies can be implemented based on this document to ensure the normal operation of wireless services.
| Model |
Description |
| RG-SAP750-SP |
Dual-radio indoor wireless access point Four spatial streams, peak data rate of 1.167 Gbps ● Radio 1: 2.4 GHz: two spatial streams, 2x2 MIMO, peak data rate of 300 Mbps ● Radio 2: 5 GHz: two spatial streams, 2x2 MU-MIMO, peak data rate of 867 Mbps Compliance with IEEE 802.11a/b/g/n and 802.11ac Wave2 standards Fat/Fit/Cloud mode switchover One uplink electrical port IEEE 802.3af-compliant (PoE) power supply and DC power supply Note: ● The power source equipment (PSE) needs to be purchased separately. ● The DC power supply needs to be purchased separately, and the output voltage/current must be 12 V/1.5 A. |
