RG-N18010-E 스위치 - 1
RG-N18010-E 스위치 - 2
RG-N18010-E 스위치 - 3
RG-N18010-E 스위치 - 4
RG-N18010-E 스위치 - 5
RG-N18010-E 스위치 - 6
RG-N18010-E 스위치 - 7
RG-N18010-E 스위치 - 8
RG-N18010-E 스위치 - 9
RG-N18010-E 스위치 - 10
RG-N18010-E 스위치 - 11
RG-N18010-E 스위치 - 1
RG-N18010-E 스위치 - 2
RG-N18010-E 스위치 - 3
RG-N18010-E 스위치 - 4
RG-N18010-E 스위치 - 5
RG-N18010-E 스위치 - 6
RG-N18010-E 스위치 - 7
RG-N18010-E 스위치 - 8
RG-N18010-E 스위치 - 9
RG-N18010-E 클라우드 아키텍처 네트워크용 고밀도 대형 버퍼 코어 스위치
  • Fit for new SOE solution and innovative hyper-converged ports, allowing flexible networking
RG-N18010-E
Up to 52 x 10GE ports and 12 x 100GE ports per line card, and up to 416 x 10GE ports and 96 x 100GE ports per switch
Front Panel
Rear Panel
Eight line card slots,
M18000E-8SFX
8 x SFX 10GE ports
M18000E-8SFG
8 x SFG GE ports
M18000E-HCA
20 x 10GE optical ports
4 x 100GE optical ports
Low CPU usage Low CPU usage
Faulty Optical Port Isolation
Port Specifications
RG-N18010-E
RG-N18014-E
2 x supervisor module slots
8 x line card slots
4 x power module slots
12 x line card slots
Supervisor module
M18000E-CM
M18000E-CM II
Switch fabric module
M18010E-FE-X I
M18000E-FE-X II
M18000E-FE-X II
Line card
M18000E-48GT4XS-XA
M18000E-48SFP4XS-XA
M18000E-24GT8SFP8XS-XA
M18000E-32XS-XB
M18000E-52XS-XB
M18000E-12CQ-XB
M18000E-8SFG
M18000E-8SFX
RG-PA600I
RG-PA1600I
M10C-FAN (pre-installed 2)
M14FAN-F (pre-installed 2)
Module management port
Supervisor module:
● 1 x RJ45 console port
● 1 x RJ45 MGMT port
Switch fabric module:
RG-N18010-E
RG-N18014-E
14,200 Mpps
21,000 Mpps
19.2 Tbps
28.8 Tbps
Supervisor module:
Line card:
M18000E-CM/CM II: supported
M18000E-CM/CM II: 16 MB
XA/XB/CWDM/FE card: 16 MB
M18000E-HCA: 16 MB
M18000E-CM: 8 GB
M18000E-CM II: 16 GB
XA/XB/CWDM/FE card: 8 GB
M18000E-HCA: 16 GB
M18000E-CM: 4 GB DDR4
M18000E-CM II: 16 GB DDR4
XA/XB/CWDM/FE card: 4 GB DDR4
M18000E-HCA: 16 GB DDR4
XA card: 4 MB
XB/CWDM/HCA card: 35 MB
Number of MAC address
● XA card: 4,000
● XB card: 10,000
● HCA card: 10,000
● HCA card: 512,000
XB card: 96,000
HCA card: 96,000
XA card: 4,000
XB card: 4,000
HCA card: 4,000
HCA card: 1,000,000
XA card: 2,000
XB card: 2,000
HCA card: 2,000
XA card:
● Ingress: 7,000
● Egress: 1,500
XB card:
● Egress: 4,000
HCA card:
● Ingress: 24,000
● Egress: 4,000
RG-N18010-E
RG-N18014-E
4 x pluggable power modules
RG-PA600I (AC input):
● Maximum input current: 10 A
RG-PA1600I (AC input):
● Maximum input current: 16 A
RG-PA600I: 600 W
RG-PA1600I:
Supervisor module:
● M18000E-CM: < 60 W
● M18000E-CM II: < 70 W
● M18000E-FE-X II: < 160 W
Line card:
● M18000E-48GT4XS-XA: < 85 W
● M18000E-32XS-XB: < 149 W
● M18000E-52XS-XB: < 250 W
● M18000E-12CQ-XB: < 240 W
● M18000E-8SFG: < 250 W
● M18000E-8SFX: < 250 W
● M18000E-HCA: < 280 W
● HCA-20XS: < 30 W
● HCA-4CQ: < 20 W
● M18000E-FE-X I: < 50 W
Fan module:
● M10C-FAN: < 216 W
Fan module:
● M14FAN-F: < 360 W
RG-N18010-E
RG-N18014-E
bracket excluded)
bracket included)
10 RU
14 RU
68.3 kg (150.58 lbs)
82.5 kg (181.88 lbs)
RG-N18010-E
RG-N18014-E
35°C (95°F): 55.9 dB
50°C (122°F): 73.4 dB
Supervisor module redundancy
1+N redundancy
N+M redundancy (same model)
Over-temperature alarming
Service port: 4 kV
RG-N18010-E
RG-N18014-E
RG-N18000-E Series
Ethernet Switching
Basic QinQ and selective QinQ
IPv4 and IPv6 GRE tunnel
IP Routing
IPv4/IPv6 VRF
IPv4/IPv6 PBR
IGMPv1/v2 snooping
IGMP proxy
Multicast static routing
MLDv1 snooping
MPLS L3VPN
MPLS 6VPE and MPLS 6PE
MPLS IPv6
ACL80 and IPv6 ACL
ACL redirection
IEEE 802.1p
Multi-AAA
IEEE 802.1X
Loose and strict RPF
uRPF ignoring default routes
IPv4/IPv6 ECMP
GR for OSPF/IS-IS/BGP
Device Virtualization
VLAN mirroring
FTP, SFTP, TFTP, and Xmodem
SNMP v1/v2/c3
Web-based NMS
LAN access to VXLAN
IPv4 over IPv4
Distributed gateway
IPv6 over IPv6
VXLAN static route
Anycast gateway
VXLAN bridging mode
VXLAN routing mode
Static VXLAN tunnel creation
Layer 2 VXLAN bridge
Layer 3 VXLAN gateway
EVPN VXLAN
RG-N18010-E
RG-N18014-E
M18000E-CM
M18000E-CM II
Power Modules and Fan Modules
RG-PA600I
RG-PA1600I
SFUs
M18010E-FE-X I
M18000E-FE-X II
Line Cards
M18000E-32XS-XB
32 x 1GE/10GE SFP+ ports (LC)
M18000E-52XS-XB
52 x 1GE/10GE SFP+ ports (LC)
M18000E-12CQ-XB
M18000E-48GT4XS-XA
M18000E-48SFP4XS-XA
M18000E-8SFX
M18000E-8SFG
M18000E-HCA
HCA-20XS
20 x 1GE/10GE SFP ports (LC)
HCA-4CQ
SFM-LR-SM
