RG-SC6705-SP 무선 - 1
RG-SC6705-SP 무선 - 2
RG-SC6705-SP 무선 - 3
RG-SC6705-SP 무선 - 4
RG-SC6705-SP 무선 - 5
RG-SC6705-SP 무선 - 6
RG-SC6705-SP 무선 - 7
RG-SC6705-SP 무선 - 8
RG-SC6705-SP 무선 - 9
RG-SC6705-SP 무선 - 10
RG-SC6705-SP 무선 - 11
RG-SC6705-SP 무선 - 1
RG-SC6705-SP 무선 - 2
RG-SC6705-SP 무선 - 3
RG-SC6705-SP 무선 - 4
RG-SC6705-SP 무선 - 5
RG-SC6705-SP 무선 - 6
RG-SC6705-SP 무선 - 7
RG-SC6705-SP 무선 - 8
RG-SC6705-SP 무선 - 9
RG-SC6705-SP, 64 AP 라이선스를 갖춘 멀티 서비스 무선 컨트롤러
Enterprise, education, government, hotel, etc.
  • Multi-service integrate AC, PoE switch, and gateway
  • Free authorization and routine auto-management of 64 APs
  • Intra-AC Layer 2 or Layer 3 roaming for wireless STAs
Integrated Multi-Service Functions of AC,
PoE Switch, and Gateway
The access controller integrates functions of the AC, PoE switch, and gateway, reducing investment in device procurement, simplifying networking, and streamlining wiring operations. It can directly constitute networking with APs.
Ruijie Wi-Fi 5/Wi-Fi 6 AP
802.3af/at-Compliant
PoE Output
NAT, PPPoE,
and DHCP
IPv4 Static
Routing
No License Fee, Automatic Management of 64 APs,
Reduced O&M Workload
The AC can automatically associate with APs on the network and supports plug-and-play. It manages up to 64 APs in fit mode with built-in licenses. APs can download configuration and upgrade software from the AC, reducing manual operations and easily achieving routine management of multiple APs.
Triple Intelligent Control,
Stable and High-Speed Network Experience
The AC implements intelligent client-based load balancing and preferentially assigns clients to associate with APs that have fewer clients, preventing AP overload.
The AC conducts intelligent band-based load balancing and steers dual-radio clients to preferentially access the 5 GHz frequency band, reducing band congestion,
The AC performs intelligent traffic-based load balancing and preferentially assigns clients to associate with APs that have smaller data traffic, enhancing average access bandwidth.
Silent and Compact Design, Easy Installation
The AC adopts a fanless and compact design, with dimensions of 200 mm x 110 mm x 25 mm (7.87 in. x 3.94 in. x 0.98 in.). It occupies less space, allowing for easy installation on the desktop, counter, or in the ELV box.
WIS Cloud enables network-wide configuration and optimization, eliminating the need for on-site operations.
Network issue warnings allow wireless networks to be monitored anytime and anywhere.
Go to WIS ->
Cloud O&M
24/7 Network Optimization
Real-Time Warning
Fault Locating
Key Specification
RG-SC6705-SP
Number of Manageable APs
64 (fixed number, license-based expansion unavailable)
Note: The number of APs that can be managed by the AC is subject to the AP model. See the Ordering Information for details
128
2,048
Note: The maximum number of STAs that can be managed by the AC is subject to the network environment. Contact technical support team for details.
802.11 forwarding capacity
2 Gbps (subject to the wireless network environment)
WLAN service
Maximum number of associated STAs per WLAN: 2,048
Number of VLANs
1 x 10/100/1000BASE-T port
4 x 10/100/1000BASE-T ports, compliant with IEEE 802.3af/at standard (PoE/PoE+)
1 x USB port (not supporting removable hard disks)
Input power supply: 1 x 80 W power adapter (the device is powered through the DC power jack)
Power input: 100 V AC to 240 V AC, 50 Hz to 60 Hz, 1.5 A (maximum current)
Power output: 54 V DC, 1.48 A
External power supply
IEEE 802.3af/at-compliant (PoE/PoE+) output
Maximum PoE power consumption: 56 W
Two power supply modes:
● Two ports for IEEE 802.3at-compliant (PoE+) output
● Four ports for IEEE 802.3af-compliant (PoE) output
64.2 W
RGOS11.9(6)B5P9 or later
Web-based management (Eweb)
WIS-based management (RG-iData-WIS)
Hardware Specification
RG-SC6705-SP
Unit dimensions (W x D x H)
200 mm x 110 mm x 25 mm (7.87 in. x 4.33 in. x 0.98 in.).
Main unit: 1.0 kg (2.20 lbs)
Shipping: 1.1 kg (2.43 lbs)
Workbench/Wall-mount
Status LEDs
SYS: 1 x system status LED
PWR: 1 x power LED
WAN: 1 x WAN port LED
LAN: 4 x LAN port LEDs
PoE: 4 x PoE LEDs
400,000 hours (44 years) at the operating temperature of 25°C (77°F)
1 GB DRAM, 512 MB SPI nand flash
RG-SC6705-SP
IEEE 802.11 Protocols
802.11, 802.11b, 802.11a, 802.11d, 802.11g, 802.11i, 802.11e, 802.11n, 802.11ac, 802.11ax, 802.11r, 802.11w, 802.11kv
IPv4 CAPWAP
Number of concurrent CAPWAP data channels: 128
Roaming
Intra-AC roaming handoff time: Less than 50 ms
Centralized forwarding
Local forwarding
Forwarding
Local forwarding and centralized forwarding
Wireless QoS
WLAN/STA-based rate limit range: 8-261,120 in the unit of 8 Kbps For example, if you set the value to 8, the rate limit is as follows:
8 x 8 kbps = 64 kbps
Fair scheduling
Layer 2 user isolation in WIDS configuration mode
Access control based on the number of STAs served by each AP
Access control based on the number of STAs served by each SSID
Access control for load balancing based on the number of STAs served by each AP
Access control for load balancing based on the traffic of each AP
Global blacklist/whitelist
SSID-based blacklist/whitelist
Configuration of the RSSI threshold in dB (range: 0-100)
AP management
An AC can control an AP to restart as scheduled.
An AP can be registered using a password, certificate, MAC address, or SN.
WLAN optimization
Adjustment of the Transmit Power for Beacon and Probe Response
RF management
Band selection
IPv4 security authentication
802.1X authentication
Maximum number of STAs supported by the built-in Portal server: 100
Multi-SSID
IEEE 802.11i PSK authentication
WPA and WPA2
WPA3: WPA3-Personal and WPA3-Enterprise
Anti-ARP spoofing
Maximum number of ACEs: 8,192
SD-WAN gateway
Multiple WAN uplinks with failover capability
IPSec VPN, L2TP VPN, and PPTP VPN
PPPoE
NAT and ALG (FTP ALG/DNS ALG)
URL or application-based traffic control with Deep Packet Inspection (DPI)
Traffic shaping and prioritization
Remote management through CWMP (TR-069) for fast provisioning
Maximum number of MAC address entries: 4,096
Maximum number of ARP entries: 3,000
IPv4 protocols
Ping and traceroute
DHCP server, DHCP client , and DHCP relay
DHCP address pools
● Maximum number of IPv4 address pools: 2,000
● Maximum number of IPv4 addresses: 4,096
DNS client
GRE tunnel: 4 over 4
FREE-URL: App-based, URL-based, and WLAN-based authentication-free
TFTP server and TFTP client
FTP server and FTP client
NTP server and NTP client
IPv4 routing
IPv4 routing entries: 512
Management and Maintenance
Syslog
RMON
The following value-added software functions can be achieved with the WIS solution (used with RG-iData-WIS and AP).
RG-SC6705-SP
Big data capabilities
RG-SC6705-SP
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, ETSI EN 300 386, IEC 62368-1, and EN 62368-1
Main Unit
RG-SC6705-SP
Multi-service AC with wired and wireless network integration:
●     One 10/100/1000 Mbps WAN port, four 10/100/1000 Mbps auto-sensing Ethernet LAN ports.
●     54 V/1.48 A DC local power supply, supporting PoE for external power supply.
●     Supporting management of 64 APs (fixed number, license-based expansion unavailable).
