RG-S6510-4C 데이터 센터 네트워킹 - 1
RG-S6510-4C 데이터 센터 네트워킹 - 2
RG-S6510-4C 데이터 센터 네트워킹 - 3
RG-S6510-4C 데이터 센터 네트워킹 - 4
RG-S6510-4C 데이터 센터 네트워킹 - 5
RG-S6510-4C 데이터 센터 네트워킹 - 6
RG-S6510-4C 100GE 데이터 센터 액세스 스위치
  • 96 x 25GE ports and 8 x 100GE ports, 32 x 100GE ports, housed in a 2 RU enclosure for flexible networking
Data Center 100GE Access Switch RG-S6510-4C
100GE high-density modular access switch with 10G/25G/100GE downlink ports
96 x 25GE ports and 8 x 100GE ports, 32 x 100GE ports, housed in a 2 RU enclosure for adaptation to different scenarios
De-stacking
M-LAG
RG-S6510-4C
(W × D × H)
442 mm x 520 mm x 86 mm (17.40 in. x 20.47 in. x 3.39 in.)
14 kg (30.86 lbs., a chassis with two power modules and three fan modules)
6.4 Tbps
2030 Mpps
Management port
Module Slot
4 x expansion module slots
Typical power consumption: 455 W
Static power consumption: 202 W
RG-PA800I-F (AC input):
Power port type: C14
RG-PA800I-F (HVDC input):
Rated input voltage: 240 V DC
Rated input current: 5 A
RG-PD800I-F (DC input):
Rated input voltage: –48 V DC
Rated input current: 23 A
RG-S6510-4C
Layer 2 Protocols
Layer 3 Protocols (IPv4)
BGP4, OSPFv2, RIPv1, RIPv2, MBGP, LPM Routing, Policy-based Routing (PBR), Route-policy, Equal-Cost Multi-Path Routing (ECMP), WCMP, VRRP, IGMP v1/v2/v3, PIM-SSM/SM/DM, MSDP, Any-RP
IPv6 Basic Protocols
IPv6 Features
Data Center Features
EVPN VXLAN
IPv6 VXLAN over IPv4
RDMA
M-LAG
OpenFlow 1.3
Visualization
sFLOW sampling
INT
Priority marking/remarking
Virtualization
Virtual Switching Unit
Buffer Management
Buffer status monitoring and management, and identification of burst traffic
HA Design
GR for RIP/OSPF/BGP, BFD, REUP dual-link fast switching and RLDP unidirectional link detection, 1+1 power redundancy, and fan redundancy, and hot swapping for all line cards and power supply modules
Security Features
Network Foundation Protection Policy (NFPP), CPP, DDoS attack defense, illegitimate data packet detection, data encryption, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, uRPF, broadcast packet suppression, DHCP Snooping, gateway ARP spoofing prevention, and ARP check
Management Mode
SNMP v1/v2c/v3, Netconf, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP clock, Syslog, SPAN/RSPAN, Telemetry, ZTP, Python, fan and power supply alarm, and temperature alarm
Other Protocols
RG-S6510-4C
Four expansion module slots, supporting hot swapping.
The power supply model is RG-PA800I-F, and the fan model is M6500-FAN-F.
RG-PA800I-F
Power module, supporting 1+1 redundancy, hot swapping, front-to-rear ventilation design, AC and HVDC
RG-PD800I-F
Power module, supporting 1+1 redundancy, hot swapping, front-to-rear airflow design, and LVDC
M6500-FAN-F
Expansion Modules
M6500-08CQ
8 x QSFP28 ports
The QSFP28 port supports a speed of 40 Gbps/100 Gbps.
M6500-24VS2CQ
24 25GE SFP28 ports and two QSFP28 ports
SFP28 supports a speed of 10G/25G rates.
The QSFP28 port supports a speed of 40 Gbps/100 Gbps. One QSFP port can be split into four 10GE or 25GE ports.
25GE Optical Transceivers
VG-SFP-SR-SM850
25G LR optical transceiver, SFP28 form factor LC, 1310 nm, 10 km (32,808.40 ft.) over single-mode fiber (SMF)
VG-SFP-AOC5M
25G active optical cable (AOC), SFP28 form factor, 5 m (16.40 ft.)
40G Optical Transceivers
100G Optical Transceivers
100G AOC), QSFP28 form factor, 5 m (16.40 ft.)
100G AOC), QSFP28 form factor, 10 m (32.81 ft.)
For more information about optical transceiver compatibility, refer to Ruijie RG-S6510 Series Data Center Switches Optical Transceiver Compatibility Matrix.
