XG-SFP-LR-SM1310 스위치 - 1
XG-SFP-LR-SM1310 스위치 - 2
XG-SFP-LR-SM1310 스위치 - 3
XG-SFP-LR-SM1310 스위치 - 4
XG-SFP-LR-SM1310 스위치 - 5
Optical Module Specifications
10.3125 Gbps
SFP+
80 km (262,467.19 ft.)
10km (32,808.40.13 ft.)
1.5 W
850 nm
1310 nm
1550 nm
1550 nm
1270 nm TX
1330 nm RX
1330 nm TX
1270 nm RX
1 dBm
0.5 dBm
4 dBm
4 dBm
0.5 dBm
0.5 dBm
7.3 dBm
8.2 dBm
4.7 dBm
8.2 dBm
8.2 dBm
Min. extinction ratio
3.0 dB
3.5 dB
3 dB
8.5 dB
3.5 dB
3.5 dB
< –11.1 dBm
< –12.6 dBm
< –14.1 dBm
< –24 dBm
< –14.4 dBm
< –14.4 dBm
–1 dBm
0.5 dBm
–1 dBm
–7 dBm
0.5 dBm
0.5 dBm
35 g (0.08 lbs.)
Cable Specifications
10.3125 Gbps
SFP+
SFP+ to SFP+
Length
1 m (3.28 ft.)
3 m (9.84 ft.)
5 m (16.40 ft.)
Module type
Active
