Dual IP network card
Stack
Stacking + Dual plane
MLAG
E-AP
Multi-homing
Recommended Index
3.5
4.5
5
4.5
4.5
Resource Occupancy
5
5
5
5
Network Card Support Scale
4.5
5
Traffic Balance
3.5
4.5
5
4.5
5
5
Deployment Difficulty
5
4.5
4.5
4.5
4.5
3.5
Difficulty in Operation and Maintenance
5
5
4.5
4.5
4.5
Advantages of the Solution
Simple implementation reusing existing capabilities of network cards and switches.
The mature solution, with an unchanged business access method, improves the reliability of network architecture and eliminates the need for synchronization of MAC/ARP/ND table entries between devices.
Introduce dual-plane behaviour based on stacking. The number of network cards can support double the scale input while greatly reducing the probability of hash polarization.
Enhance network reliability, virtualize as a single switch, and simplify network operation and maintenance.
No need to occupy additional ports, high reliability, support redundant backup of physical links, and reduce the risk of a single point of failure.
Provide redundant connections for VXLAN networks with high flexibility and scalability.
Low requirements for operational and server capabilities.
Disadvantages of the Solution
Additional IP address allocation is required, but there is insufficient balance on some network card sides.
Needs to modify the Linux server to support ARP/ND broadcast packet forwarding.
The interconnection link needs to occupy a port.
Private communication protocol unable to form E-AP group with other vendors' products.
Deploy VXLAN network to support.
