RG-MAP852(V3) Vô tuyến - 1
RG-MAP852(V3) Vô tuyến - 2
RG-MAP852(V3) Vô tuyến - 3
RG-MAP852(V3) Vô tuyến - 4
RG-MAP852(V3) Vô tuyến - 5
RG-MAP852(V3), i-Share+ Solution Micro AP, Wi-Fi 6 Dual-Radio 2.976 Gbps
Recommended for complex environments, such as wireless dormitory networks, hotels, and dense office networks.
  • 4 x 1 Gbps downlink Ethernet ports,  wired and wireless integration for cost-efficient networking
  • 2.976 Gbps ultra-fast speed with Wi-Fi 6
  • PoE protocols supported, no local power is required
Thông số chi tiết chính View More
The RG-AM5532 is an i-Share access point (AP) released by Ruijie Networks for complex application environments, such as wireless dormitory networks, hotels, and dense office networks.
The RG-AM5532 supports three modes for data uplink: four optical ports, four electrical ports, and two optical ports and two electrical ports. The uplink electrical ports can be connected to four IEEE 802.3af-compliant powered devices (PDs), two IEEE 802.3at-compliant PDs, or two IEEE 802.3af-compliant PDs and one IEEE 802.3at-compliant PD, to support standard PoE APs.
Based on the IEEE 802.11ax standard, one RG-AM5532 can extend to connect to 24 radio modules that provide two spatial streams at dual bands for each of 24 rooms. Each room can enjoy up to 2.976 Gbps bandwidth, meeting requirements in high-performance access scenarios, such as dormitory networks.
The RG-AM5532 design considers wireless network security, radio control, mobile access, and quality of service (QoS) guarantee, seamless roaming, and other factors to implement data forwarding, security, and access control of wireless users.
Micro AP Product Specifications
RG-MAP852(V3)
Unit dimensions(W x D x H)
125 mm × 86 mm × 30 mm (4.92 in x 3.38 in x 1.18 in)
180 mm x 137 mm x 52 mm (7.09 in x 5.39 in x 2.05 in)
0.31 kg (0.68 lbs)
0.35 kg (0.77 lbs)
Wall/Ceiling/In-wall-mount
RG-MAP852(V3)
Dual-radio, four spatial streams per device
Operating frequencies
Radio 1, 802.11b/g/n/ax:
●     2.400 GHz to 2.4835 GHz, channels 1 to 13
Radio 2, 802.11a/n/ac/ax:
●     5.150 GHz to 5.250 GHz, U-NII-1, channels 36, 40, 44, and 48
●     5.250 GHz to 5.350 GHz, U-NII-2A, channels 52, 56, 60, and 64
●     5.470 GHz to 5.725 GHz, U-NII-2C, channels 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, and 140
●     5.725 GHz to 5.850 GHz (HE80), U-NII-3/ISM, channels 149, 153, 157, 161, and 165
Date rates
Radio1: 2.4GHz, 574Mbps
●     Two spatial stream Single User (SU) MIMO for up to 574 Mbps wireless data rate to individual 2SS HE40 802.11ax client device (max.)
●     Two spatial stream SU MIMO for up to 287 Mbps wireless data rate to individual 2SS HE20 802.11ax client device (typical)
Radio2: 5GHz, 2.402Gbps
●     Two spatial stream Single SU MIMO for up to 2.402 Gbps wireless data rate to individual 2SS HE160 802.11ax client device (max.)
●     Two spatial stream SU MIMO for up to 1.201 Gbps wireless data rate to individual 2SS HE80 802.11ax client device (typical)
Data rate set
●     802.11b: 1, 2, 5.5, 11
●     802.11g: 1, 2, 5.5, 6, 9, 11, 12, 18, 24 ,36, 48, 54
●     802.11n: 6.5 to 300 (MCS0 to MCS15, HT20 to HT40)
●     802.11ac: 6.5 to 400 (MCS0 to MCS9, NSS = 1 to 2,VHT20 to VHT40)
●     802.11ax:  8.6 to 574 (MCS0 to MCS11, NSS = 1 to 2, HE20 to HE40)
●     802.11a: 6, 9, 12, 18, 24, 36, 48, 54
●     802.11ac: 6.5 to 1732 (MCS0 to MCS9, NSS = 1 to 2,VHT20 to VHT160)
●     802.11ax: 8.6 to 2402 (MCS0 to MCS11, NSS = 1 to 2, HE20 to HE160)
Packet aggregation
802.11n/ac/ax: A-MPDU, A-MSDU
Build-in ominidirectional antenna (2 x 2.4 GHz antennas, 2 x 5 GHz antennas)
Antenna gain
2.4GHz: 2dBi
5GHz: 2dBi
Max. transmit power
2.4 GHz radio: 21 dBm (18 dBm per chain)
5 GHz radio: 21 dBm (18 dBm per chain)
Power increment
Radio technologies
802.11b: BPSK, QPSK, CCK
802.11a/g/n: BPSK, QPSK, 16-QAM, 64-QAM,
RG-MAP852(V3)
2.4GHz 802.11b
17 dBm
–90 dBm
15 dBm
–87 dBm
2.4GHz 802.11g
–78 dBm
15 dBm
–72 dBm
2.4GHz 802.11n (HT20)
15 dBm
–67 dBm
2.4GHz 802.11n (HT40)
15 dBm
–64 dBm
2.4GHz 802.11ax (HE20)
12 dBm
–58 dBm
2.4GHz 802.11ax (HE40)
12 dBm
5GHz 802.11a
–78 dBm
15 dBm
–72 dBm
5GHz 802.11n (HT20)
15 dBm
–67 dBm
5GHz 802.11n (HT40)
15 dBm
–64 dBm
5GHz 802.11ac (VHT20)
15 dBm
5GHz 802.11ac (VHT40)
15 dBm
–57 dBm
5GHz 802.11ac (VHT80)
15 dBm
5GHz 802.11ax (HE20)
12 dBm
–58 dBm
5GHz 802.11ax (HE40)
12 dBm
5GHz 802.11ax (HE80)
12 dBm
–52 dBm
5GHz 802.11ax (HE160)
–75 dBm
9 dBm
–47 dBm
RG-MAP852(V3)
Uplink: One 10/100/1000Base-T Ethernet port with auto-negotiation, supporting IEEE 802.3af/at/bt-compliant PoE
Downlink: Four 10/100/1000Base-T Ethernet ports with auto-negotiation
●     Press the button for shorter than 2 seconds. Then the device restarts.
●     Press the button for longer than 5 seconds. Then the device restores to factory settings.
RG-MAP852(V3)
PoE/PoE+/PoE++ (IEEE 802.3af/at/bt-compliant), powered by an i-Share+ master AP
Max. power consumption
9 W
RG-MAP852(V3)
Note: At an altitude between 3,000 m (9,843 ft) and 5,000 m (16,404 ft), every time the altitude increases by 167 m (548 ft), the maximum temperature decreases by 1°C (1.8°F).
Environment standard
Storage and operating environment: NEBS GR-63-CORE_Issue3_2006 GB/T 2423.6-1995
RG-MAP852(V3)
EN 301 489-3
EN 301 489-17
EN 300 328
FCC Part 15
EN IEC 62311
EN 62368-1
Software Specification
Software
RG-MAP852(V3)
RGOS11.9(6)W2B5 or higher
RG-MAP852(V3)
Max. number of BSSIDs
16 (up to 8 BSSIDs per radio)
Max. number of WLAN IDs
Rate set settings
IPv4 / IPv6 CAPWAP
MU and TAG device locating
RG-MAP852(V3)
PSK and web authentication
Data encryption: WEP (64/128 bits), WPA (TKIP), WPA-PSK, WPA2 (AES)
MAC extended ACLACL based on a Layer 2 interface
RG-MAP852(V3)
MAC address table size: 1,024
Max. number of static MAC addresses: 1,024
Max. number of filtered MAC addresses: 1,024
Jumbo frame length: 1518
IEEE802.1p and IEEE802.1Q
Max. number of VLANs: 4094
VLAN ID range: 1–4094
ARP entry aging and proxy ARP
Max. number of ARP entries: 1,024
Static and dynamic IPv4 addresses
IPv6 addressing, ND, ICMPv6, IPv6 ping
Max. number of static IPv4 routes: 1,024
Max. number of static IPv6 routes: 1,000
RG-MAP852(V3)
SNMPv1/v2C/v3
Telnet andTFTP
Order the RG-AM5532 (i-Share+ solution master AP) first. Then order the RG-MAP852(V3) (i-Share+ solution micro AP).
RG-AM5532
The master AP of the i-Share+ solution APs with 24 downlink 1000 Mbps PoE ports, four uplink 1000 Mbps PoE electrical ports and four uplink 10GE SFP+ ports in auto negotiation mode. The uplink ports support three mutually exclusive modes: two 1000 Mbps electrical ports and two 10GE optical ports (supporting up to two settled APs), four 1000 Mbps electrical ports (supporting up to three settled APs) and four 10GE optical ports (not supporting settled APs). The master AP supports up to 24 i-Share micro APs. Each master AP uses four wireless controller licenses.
RG-MAP852(V3)
A universal Wi-Fi 6 dual-radio i-Share micro AP. The AP supports up to four spatial streams and the maximum access rate of 2.976 Gbps. It complies with IEEE 802.11b/g/n/ax and IEEE 802.11a/n/ac/ax standards. The AP provides one 1000 Mbps uplink port and four 1000 Mbps downlink ports. The AP can be can be mounted on a wall, ceiling, or junction box.
Technical Support
Technical Support
Get in Touch
Get in Touch
