RG-AM5532 Vô tuyến - 1
RG-AM5532 Vô tuyến - 2
RG-AM5532 Vô tuyến - 3
RG-AM5532 Vô tuyến - 4
RG-AM5532 Vô tuyến - 5
RG-AM5532 Vô tuyến - 6
RG-AM5532, i-Share+ Solution Master AP
Recommended for complex environments, such as wireless dormitory networks, hotels, and dense office networks.
  • Support three modes for data uplink, easily extend micro APs
  • Supply power to micro APs, no local power is required
  • Managing only one master AP to lower the management cost
The RG-AM5532 is an i-Share access point (AP) released by Ruijie Networks for complex application environments, such as wireless dormitory networks, hotels, and dense office networks.
The RG-AM5532 supports three modes for data uplink: four optical ports, four electrical ports, and two optical ports and two electrical ports. The uplink electrical ports can be connected to four IEEE 802.3af-compliant powered devices (PDs), two IEEE 802.3at-compliant PDs, or two IEEE 802.3af-compliant PDs and one IEEE 802.3at-compliant PD, to support standard PoE APs.
Based on the IEEE 802.11ax standard, one RG-AM5532 can extend to connect to 24 radio modules that provide two spatial streams at dual bands for each of 24 rooms. Each room can enjoy up to 2.976 Gbps bandwidth, meeting requirements in high-performance access scenarios, such as dormitory networks.
The RG-AM5532 design considers wireless network security, radio control, mobile access, and quality of service (QoS) guarantee, seamless roaming, and other factors to implement data forwarding, security, and access control of wireless users.
RG-AM5532
Dimensions( W x D x H)
Main unit: 360 mm x 440mm x 44mm (14.17 in. x 17.32 in. x1.73 in.)
Shipping: 550mm x 470 mm x 255 mm (21.65 in. x 18.50 in. x 10.04 in.)
Main unit: 5.8 kg (12.79 lbs, including the package)
Shipping: 6.2 kg (13.67 lbs)
Wall/Workbench/Rack-mount
RG-AM5532
512 MB
512 MB
68 Gbps
101 Mpps
RG-AM5532
Uplink:
4 x 1000BASE-T ports
4 x 10GE SFP+ ports
Downlink:
1 x system status LED
28 x RJ45 port LEDs
4 x SFP+ port LEDs
1 x Power button
RG-AM5532
Rated voltage range: 100 V AC to 240 V AC
Maximum voltage range: 90 V AC to 264 V AC
Frequency: 50/60 Hz
Rated current: 3 A
External power supply
300 W
RG-AM5532
At an altitude in the range of 1,800–3,000 m (5,905.51–9,842.52 ft.), every time the altitude increases by 220 m (544.62 ft.), the maximum temperature decreases by 1°C (1.8°F).
Dual-fan design
Safe fan speed
9000 rpm
Shock and vibration
GB/T 2423.6
Environmental standard
Storage and operating environment: NEBS GR-63-CORE_Issue3_2006 GB/T 2423.6-1995
400,000 hours (44 years) at the operating temperature of 25°C (77°F)
RG-AM5532
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, ETSI EN 300 386, IEC 62368-1, and EN 62368-1
Applicable Software Version
RG-AM5532
RGOS 11.9(6)W2P1 or later
RG-AM5532
2,048
RG-AM5532
PSK and web authentication
Data encryption: WEP (64/128 bits), WPA (TKIP), WPA-PSK, WPA2 (AES)
RG-AM5532
MAC address learning and aging
Static and dynamic MAC addresses
Source MAC address filtering
Limitation on the number of MAC addresses learned on an interface
Jumbo frame length: 1518
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 4,094
VLAN ID range: 1 to 4,094
ARP entry aging and proxy ARP
Static and dynamic IPv4 addresses
DHCP server and DHCP client
DNS client
NTP server and NTP client
Static and dynamic IPv6 addresses
Neighbor Discovery (ND), IPv6 ND proxy, ICMPv6, and IPv6 ping
DNSv6 client
NTPv6 server and NTPv6 client
Static black hole routing
IGMP Snooping
RG-AM5532
RG-AM5532
The master AP of the i-Share+ solution APs with 24 downlink 1000 Mbps PoE ports, four uplink 1000 Mbps PoE electrical ports and four uplink 10GE SFP+ ports in auto negotiation mode. The uplink ports support three mutually exclusive modes: two 1000 Mbps electrical ports and two 10GE optical ports (supporting up to two settled APs), four 1000 Mbps electrical ports (supporting up to three settled APs) and four 10GE optical ports (not supporting settled APs). The master AP supports up to 24 i-Share micro APs. Each master AP uses four wireless controller licenses.
RG-MAP852(V3)
A universal Wi-Fi 6 dual-radio i-Share micro AP. The AP supports up to four spatial streams and the maximum access rate of 2.976 Gbps. It complies with IEEE 802.11b/g/n/ax and IEEE 802.11a/n/ac/ax standards. The AP provides one 1000 Mbps uplink port and four 1000 Mbps downlink ports. The AP can be can be mounted on a wall, ceiling, or junction box.
