| Hardware Specifications |
RG-S2915-48GT4MS-L |
RG-S2915-24GT4MS-L |
RG-S2915-24GT4MS-P-L |
RG-S2915-10GT2MS-P-L |
| Interface Specifications |
| Fixed Service Ports |
48 × 10/100/1000Base-T Ethernet ports with auto-negotiation, 4 × 2.5GE/1GE SFP ports |
24 × 10/100/1000Base-T Ethernet ports with auto-negotiation, 4 × 2.5GE/1GE SFP ports |
24 × 10/100/1000Base-T Ethernet ports with auto-negotiation, 4 × 2.5G/1GE SFP ports |
10 × 10/100/1000Base-T Ethernet ports with auto-negotiation, 2 × 2.5GE/1GE SFP ports |
| Power modules |
1 fixed power module |
| Fans modules |
2 fixed fans |
0 |
2 fixed fans |
1 fixed fans |
| Fixed management ports |
1 × RJ45 Console, 1 × USB port |
| System Specifications |
| Packet forwarding rate |
87 Mpps |
51 Mpps |
51 Mpps |
22.5 Mpps |
| System Switching capacity |
116Gbps |
68Gbps |
68Gbps |
30Gbps |
| MAC Table Capacity |
16,000 |
16,000 |
16,000 |
16,000 |
| ARP table |
512 |
| Routing Table Size (IPv4/IPv6) |
64 |
| ACL entries |
500 |
| Dimensions and Weight |
| Dimensions (W x D x H) |
440 mm × 220 mm × 43.5 mm (17.32 in × 8.66 in × 1.71 in), 1 RU |
440 mm × 292 mm × 43.6 mm (17.32 in × 11.50 in × 1.72 in), 1 RU |
297 mm × 170 mm × 44.5 mm (11.69 in × 6.69 in × 1.75 in), 1 RU |
| Weight |
2.8 kg (6.17 lbs) |
2.5 kg (5.51 lbs) |
2.8 kg (6.17 lbs) |
2.5 kg (5.51 lbs) |
| CPU and Storage |
| CPU |
Built-in CPU, single-core processor, with the clock speed of 1.2 GHz |
| Storage |
SDRAM: 512 MB Flash Memory: 64 MB |
| Power and Consumption |
| Maximum power consumption |
< 30 W |
< 15.6 W |
< 33 W (non-PoE) < 403 W (PoE full load) |
< 16 W (non-PoE) < 141 W (PoE full load) |
| Rated input voltage |
100 V AC to 240 V AC, 50 Hz to 60 Hz |
| Maximum input voltage |
90 V AC to 264 V AC, 50 Hz to 60 Hz |
| MTBF |
>200K |
>200K |
>200K |
>200K |
| Operating Temperature |
0°C to 45°C (32°F to 113°F) |
| Storage Temperature |
-40°C to +70°C (-40°F to +158°F) |
| Operating Humidity |
10% to 90% RH (non-condensing) |
| Storage Humidity |
5% to 95% RH (non-condensing) |
| Operating noise |
≤ 37 dB |
Fanless |
≤ 39 dB |
≤ 37 dB |
| Interface surge protection |
Power port: 6 kV/2 kV Telecom port: 10 kV |
| Feature |
Description |
| Ethernet switching |
Jumbo frame (maximum length: 9216 bytes) |
| 802.3az EEE |
| IEEE 802.1Q (4,094 VLANs) |
| Voice VLAN |
| Port based VLAN |
| Basic QinQ Selective QinQ |
| STP (IEEE 802.1.d), RSTP (IEEE 802.1w), MSTP (IEEE 802.1s) |
| ERPS (G.8032) |
| LLDP/LLDP-MED |
| LACP (IEEE 802.3ad) |
| IP service |
ARP |
| DHCP snooping |
| DNS |
| IP routing |
Static routing |
| RIP, RIPng |
| OSPFv2 |
| ACL and QoS |
Standard IP ACLs Extended IP ACLs Extended MAC ACLs Expert-level ACLs ACL 80 IPv6 ACL |
| ACL redirection |
| Port traffic rate limiting |
| 802.1p, DSCP, IP precedence traffic prioritization (IEEE 802.1p) for real-time classification |
| Eight priority queues per interface |
| Security |
RADIUS and TACAS+ |
| Port-based and MAC-based 802.1x authentication |
| Web authentication |
| HTTPS |
| SSHv1, SSHv2 |
| IGMP V1,V2 snooping |
| IP Source Guard |
| CPP and NFPP |
| Reliability |
RLDP |
| Hot swapping of power modules and cables |
| Temperature Monitoring Temperature Alarm Overtemperature Protection |
| NMS and maintenance |
RSPAN |
| sFlow |
| NTP |
| TFTP client |
| SNMP v1/v2c/v3 |
| CLI (telnet/console), syslog/debug, Web, MACC public cloud |
| CWMP (TR-069) standard protocol |
| gRPC |
| PoE |
IEEE 802.3af and 802.3at Uninterruptible power supply upon hot start Port priority |
| Model |
Description |
48 × 10/100/1000Base-T copper ports with auto-negotiation, 4 × 1GE/2.5GE SFP ports, fixed single AC power supply |
24 × 10/100/1000Base-T copper ports with auto-negotiation, 4 × 1GE/2.5GE SFP ports, fixed single AC power supply |
24 × 10/100/1000Base-T copper ports with auto-negotiation, 4 × 1GE/2.5GE SFP ports, fixed single AC power supply, PoE/PoE+ power supply, 370 W PoE power supply |
10 × 10/100/1000Base-T copper ports with auto-negotiation, 2 × 1GE/2.5GE SFP ports, fixed single AC power supply, PoE/PoE+ power supply, 125 W PoE power supply |
SFP 2.5G BIDI transceiver-TX1310/RX1550, 3 km, LC |
SFP 2.5G BIDI transceiver-TX1550/RX1310, 3 km, LC |
| MINI-GBIC-SX-MM850 |
1000BASE-SX, SFP transceiver, SM (850 nm, 500 m, LC). |
| MINI-GBIC-LX-SM1310 |
1000BASE-LX, SFP transceiver, SM (1310 nm, 10 km, LC) |
| MINI-GBIC-LH40-SM1310 |
1000BASE-LH, SFP transceiver, SM (1310 nm, 40 km, LC) |
| MINI-GBIC-ZX80-SM1550 |
1000BASE-ZX80, SFP transceiver, SM (1550 nm, 80 km, LC) |
| GE-SFP-LX20-SM1310-BIDI |
SFP BIDI Transceiver-TX1310/RX1550, 20 km, LC |
| GE-SFP-LX20-SM1550-BIDI |
SFP BIDI Transceiver-TX1550/RX1310, 20 km, LC |
| GE-SFP-LH40-SM1310-BIDI |
SFP BIDI Transceiver-TX1310/RX1550, 40 km, LC |
| GE-SFP-LH40-SM1550-BIDI |
SFP BIDI Transceiver-TX1550/RX1310, 40 km, LC |
| Mini-GBIC-GT |
1000BASE-TX, SFP transceiver (100 m) |
