Suitable for SME network core and large-scale network aggregation
| Hardware Specifications |
RG-CS86-20XS4VS2QXS-D |
| Interface Specifications |
| Fixed Ports |
20 x 1G/10G SFP+ ports, 4 x 10G/25G SFP28 ports, 2 x 40G QSFP+ ports. One switch provides a maximum of 32 x 10G ports, 2 modular power slots, and 2 modular fan slots. |
| Fan modules |
Dual pluggable modular fans, with front-to-rear ventilation channels Fan speed regulating and alarm function |
| Power modules |
2 replaceable hot-swappable power supply slots |
| Fixed management ports |
One MGMT port, one console port, and one USB port |
| System Specifications |
| Forwarding Rate |
570 Mpps |
| Switching Capacity |
760 Gbps/2.56 Tbps |
| MAC Table Capacity |
32,768 |
| ARP table |
16,000 |
| IPv4 Unicast Routes |
16,000 |
| IPv4 Multicast Routes |
4,000 |
| IPv6 Unicast Routes |
2,000 |
| IPv6 Multicast Routes |
16,000 |
| ACL entries |
In: 2,500 Out:1,000 |
| Number of VSU members |
2 |
| Dimensions and Weight |
| Dimensions (W x D x H) |
440 x 330 x 43.6 mm (17.32 x 12.99 x 1.72 in), 1 RU |
| Weight of the empty chassis |
4.6 kg (10.14 lbs) |
| CPU and Storage |
| CPU |
Dual-core CPU, 1.25GHz |
| Storage |
Flash memory: 1 GB SDRAM: 1 GB |
| Power and Consumption |
| Power Supply |
Supported power module type: RG-PA150I-F AC input: Rated voltage range: 100–240 V AC; 50/60 Hz Maximum voltage range: 90–264 V AC; 47/63 Hz Rated input current: 3 A
HVDC input: Rated voltage: 240 V DC Maximum voltage range: 192–288 V AC Rated current per circuit: 3 A
| Operating temperature |
0°C to 50°C (32°F to 122°F) |
| Storage temperature |
-40°C to +70°C (-40°F to +158°F) |
| Operating humidity |
10% to 90% RH (non-condensing) |
| Storage humidity |
5% to 95% RH (non-condensing) |
| Interface surge protection |
Power port: 6 kV/6 kV Telecom port: 10 kV (MGMT port: 4 kV) |
| Temperature Alarm |
Supported |
| Feature |
Description |
| Ethernet Switching |
| IEEE 802.1Q (supporting 4K VLANs) |
| Voice VLAN |
| Super VLAN, Private VLAN |
| MAC VLAN, Port based VLAN, Protocol based VLAN, IP-Subnet based VLAN |
| GVRP |
| Basic QinQ |
| STP, RSTP, and MSTP |
| ERPS (G.8032) |
| LLDP/LLDP-MED |
| LACP (IEEE 802.3ad) |
| IP Service |
ARP |
| DHCP snooping |
| DNS |
| DHCPv6 client and DHCPv6 relay |
| DHCPv6 snooping |
| IP Routing |
Static routing |
| RIP and RIPng |
| OSPFv2, OSPFv3, IS-ISv4, ISv4, and IS-ISv6 |
| BGP4 and BGP4+ |
| IPv4 and IPv6 VRF |
| IPv4 and IPv6 PBR |
| Equal and Weighted Cost Multi-Path (ECMP) |
| Multicast |
| IGMP v1/v2/v3 snooping |
| MSDP |
| MLD v1/v2 |
| MLD snooping v1/v2 |
| PIM-SMv6 and PIM-SSM v6 |
| IGMP filtering, IGMP immediate leave |
| ACL and QoS |
Standard IP ACLs Extended IP ACLs Extended MAC ACLs Time-based ACLs Expert-level ACLs ACL80 IPv6 ACL |
| ACL redirection |
| Port traffic rate limiting |
| 802.1p/DSCP/ToS traffic classification Eight priority queues per port |
| Security |
Multiple AAA modes |
| RADIUS and TACAS+ |
| Port-based and MAC-based 802.1x authentication |
| Web authentication |
| HTTPS |
| SSHv1, SSHv2 |
| Global IP-MAC binding |
| IP source guard |
| SAVI |
| CPP and NFPP |
| Strict and loose RPF |
| Reliability |
REUP, RLDP, DLDP |
| BFD |
| Hot swapping of power modules and cables |
| 3-level fan speed adjustment Fan fault alarm |
| Device virtualization |
| NMS and maintenance |
SPAN, RSPAN, and ERSPAN |
| sFLOW |
| NTP and SNTP |
| FTP and TFTP |
| SNMP v1/v2/v3 |
| RMON (1, 2, 3, 9) |
| Telnet |
| NETCONF |
| CWMP (TR-069) standard protocol |
| gRPC |
| Cloud and SON |
| Model |
Description |
20 x 1GE/2.5GE/10GE SFP+ ports, 4 x 10G/25G SFP28 ports, 2 x 40G QSFP+ ports, supports up to 32×10G ports, 2 slots for power supply module, requires at least one RG-PA150I-F power supply module, 2 slots for fan modules, 2 pre-installed fans (Purchase at least one RG-PA150I-F module.) |
| RG-PA150I-F |
150W AC power supply module for RG-CS86-20XS4VS2QXS-D |
| Mini-GBIC-GT |
1000BASE-GT mini GBIC conversion module |
| MINI-GBIC-SX-MM850 |
1000BASE-SX, SFP transceiver, SM (850 nm, 500 m, LC). |
| MINI-GBIC-LX-SM1310 |
1000BASE-LX, SFP transceiver, SM (1310 nm, 10 km, LC) |
| MINI-GBIC-LH40-SM1310 |
1000BASE-LH, SFP transceiver, SM (1310 nm, 40 km, LC) |
| MINI-GBIC-ZX80-SM1550 |
1000BASE-ZX80, SFP transceiver, SM (1550 nm, 80 km, LC) |
| GE-SFP-LX20-SM1310-BIDI |
SFP BIDI Transceiver-TX1310/RX1550, 20 km, LC |
| GE-SFP-LX20-SM1550-BIDI |
SFP BIDI Transceiver-TX1550/RX1310, 20 km, LC |
| GE-SFP-LH40-SM1310-BIDI |
| GE-SFP-LH40-SM1550-BIDI |
SFP BIDI Transceiver-TX1550/RX1310, 40 km, LC |
| XG-SFP-SR-MM850 |
10G SP fiber module, applicable to SFP+ ports, max cabling distance: 300m |
| XG-SFP-LR-SM1310 |
10G SP fiber module, applicable to SFP+ ports, max cabling distance: 10km |
| XG-SFP-ER-SM1550 |
10G SP fiber module, applicable to SFP+ ports, max cabling distance: 40km |
| VG-SFP-SR-MM850 |
25G fiber module |
| VG-SFP-LR-SM1310 |
25G fiber module |
| XG-SFP-AOC1M |
10G SFP+ connector fiber, 1m long, including one cable and two connector modules |
| XG-SFP-AOC3M |
10G SFP+ connector fiber, 3m long, including one cable and two connector modules |
| XG-SFP-AOC5M |
10G SFP+ connector fiber, 5m long, including one cable and two connector modules |
| VG-SFP-AOC5M |
25G Base SFP+ fiber cable (including modules on both ends), 5m long |
| 40G-QSFP-SR-MM850 |
40G SR fiber module, applicable to QSFP+ ports (OM3/OM4 MPO interface, 8 core, 850nm wave length, max cabling distance: 100m(OM3), 150m(OM4)) |
| 40G-QSFP-LR4 SM1310 |
40G LR single-mode fiber module, applicable to QSFP+ ports, max cabling distance:10km (LC interface, 2 core, 1310nm wave length) |
| 40G-AOC-5M |
40G QSFP+ connector fiber, 5m long, including one cable and two connector modules |
| 40G-AOC-10M |
40G QSFP+ connector fiber, 10m long, including one cable and two connector modules |
