Home> Sản phẩm> Thiết bị chuyển mạch> Switch không cần quản lý dòng ES100>
RG-ES108GD
8-Port Gigabit Unmanaged Metal Switch
Feature Highlights:
Ruijie RG-ES100 Series Switches are the next-generation unmanaged switches for scenarios like CCTV, ELV and small offices. The series is designed for small and medium-sized businesses looking for Plug-n-Play solution.
Ruijie RG-ES100 Series is part of the Ruijie SME networking products. The series consists of 3 switches including one 8-port Gigabit PoE+ models and two 24-port Gigabit PoE+ switch models.
These switches can be deployed with plug-and-play out the box. Moreover, port-isolation and flow-control features can be done with a simple flip with the button on the panel. Also, PoE budget status can be shown directly on port indicators, which helps a lot in trouble-shooting.
Key Features
● 24-port and 8 port Gigabit PoE for CCTV/ELV and other SME scenarios
● One-click button simple management beyond Plug-n-Play
● 370W and 180W PoE budget choices on 24-port models
● All 8/24 ports are PoE/PoE+ capable, feel free to choose any ports
● 3 year warranty free of charge
Xem thêm+
Easy Connectivity
● Full Gigabit Ethernet
10/100/1000Mbps choice on every port, line-rate forwarding.
● Auto MDI/MDIX
All RJ45 ports support auto MDI/MDIX, no restrictions on cables when link to client or other switches.
● Fiber uplink options
RG-ES126G-P-L and RG-ES126G-LP-L provides 2 GE-SFP ports for fiber uplink.
Power over Ethernet
● PoE/PoE+
Provides up to 30Watt per port, which allows support of latest IEEE802.3at(PoE+) capable devices such like high-performance access points and IP cameras, as well as any IEEE802.3af(PoE)-compliant powered devices.
● Power on all ports
Ports 1~8 of RG-ES109G-LP-L and ports 1~24 of RG-ES126G-LP/P-L are all PoE/PoE+ capable.
● PoE budget choice
Multiple PoE power budget choice between 185W and 370W on 24-port models.
More than Plug-n-Play
● One-click flow control
With the flip button on the panel, flow control(IEEE802.3X) can be easily enabled to smooth traffic and avoid packet drop due to sudden traffic surge.
● One-click port isolation
With the flip button on the panel, users can also set port isolation between each port, which helps to ensure CCTV camera safety.
● PoE budget indicator
PoE budget status can be seen on LED indicators of each port.
Warranty and support
● 3-Year Warranty Free of Charge
Go to https://www.ruijienetworks.com/support/servicepolicy to see details on warranty and support policies.
RG-ES126G-P-L
Unmanaged Switch, 24 10/100/1000BASE-T ports, 2 1000M SFP ports, AC power supply, support PoE/ PoE+, PoE power budget: 370W
RG-ES126G-LP-L
Unmanaged Switch, 24 10/100/1000BASE-T ports, 2 1000M SFP ports, AC power supply, support PoE/ PoE+, PoE power budget: 180W
RG-ES109G-LP-L
Unmanaged Switch, 9 10/100/1000BASE-T ports, external AC-DC power adaptor, support PoE/ PoE+, PoE power budget: 54W
8/24 Port Full Gigabit PoE Switches
Product Datasheet
