Home> Products> Wireless> Reyee Indoor AP>
RG-RAP2260(G) Wi-Fi 6 Dual Band Ceiling Mount Access Point
AX1800 Dual Band Ceiling Mount AP
Feature Highlights:
Ruijie Reyee RG-RAP2260(G) is a high-performance entry Wi-Fi 6 AP for indoor large-area Wi-Fi coverage scenarios. The device supports 802.3at PoE and 12V DC local power supply. The dual LAN ports design facilitates the expansion of third-party devices to meet the needs of more networking scenarios. Compliant with 802.11a/b/g/n/ac/ax Wi-Fi protocol, RG-RAP2260(G) supports MU-MIMO dual-stream technology and offers built-i n omnidirectional antennas. It can operate concurrently at 2.4GHz and 5GHz, providing high-speed wireless access of 574Mbps at 2.4GHz, 1201Mbps at 5GHz and up to 1775Mbps per AP. Its coverage of over 20 meters makes it an ideal choice for many wireless scenarios, especially in offices, commercial industry, hotels, service scenarios, etc.
More+
High-speed dual-band Wi-Fi
The device supports 2.4GHz and 5GHz dual-band communication, providing access rate of 574Mbps at 2.4GHz, 1201Mbps at 5GHz and up to 1775Mbps per AP. It can provide 5GHz frequency band with less interference, wider channel, and faster speed for the terminals, allowing the users to enjoy excellent wireless experience.
Dual LAN ports design
The device adopts the dual LAN ports design. Even for complex networking requirements, it can easily and quickly support the expansion of third-party devices, such as cameras, time and attendance devices, etc.
Support routing and AP mode
The device supports both AP and routing mode. A wireless network can be formed with multiple APs, or it can be used as a wireless router when deployed independently. The device offers more flexible configurations, more abundant application features, and more extensive applicable scenarios.
Support Layer 3 roaming
The device supports Layer 3 roaming for the complex Layer 3 network. When users move across the Layer 3 networks, seamless roaming can be achieved without service interruption.
Stronger and more stable signals
An aluminum alloy antenna reflector is added to reflect interference signals and focus effective signals so as to provide stronger signal transmission and better receiving sensitivity.
The device uses FBAR to filter out most of interferences caused by the operator's base stations, microwave ovens, Bluetooth devices, etc., so as to provide cleaner wireless signals, higher transmission rate and more stable transmission quality.
Robust casing
With the robust and flame-retardant material of the AP casing, the impact resistance is 5 times higher than that of common ABS plastic materials. The tensile and flexural strengths are increased by 30%, which is not easy to damage. Users can rest assured during usage and maintenance.
Simple installation
It supports various installation methods including on desktop, ceiling, wall, and pole. Adopting the non-directional installation design, the equipment can be installed in one go efficiently.
Industrial design
The industrial product design, iconic edges and breathing light makes the product more recognizable.
Multi-end management
The AP supports management via Ruijie Cloud app, Ruijie Cloud platform, equipment EWEB management to achieve multi-end local and remote management on PC, Ruijie Cloud app.
Fast and smart configuration
In large-scale complex networks, the configuration of the entire network can be completed by connecting to a single gateway device. There is no need to configure the devices separately, which can greatly reduce the device configuration time.
Scenario-based configuration
Scenario-based configurations can be performed via the web and Ruijie Cloud app, which can greatly reduce the configuration threshold of complex functions, such as visitor isolation solution, flow control solution, etc. Even novices can easily fulfill the diverse and complex requirements of the customers.
Visualized operation and maintenance
The cloud computing network topology can comprehensively present the equipment operating status of the entire network. Through the rich information in the topology, you can quickly get the full picture of the network (network egress status, link status, device status), and quantify the user experience and network quality, so that users can master the information of the entire network.
Remote collaborative management
Users can perform comprehensive remote operation, management, and maintenance of the equipment in the entire network via the Ruijie Cloud app, Ruijie Cloud platform, etc. They can also share the network to third party for network hosting and collaborative management to operate and maintain the enterprise network more efficiently.
AI & big data network optimization
Through artificial intelligence and cloud big data, the AP can perform comprehensive smart network operation, maintenance and optimization, including but not limited to:
1. Automatic identification of new equipment and adding it into the network, automatic system repair such as avoiding conflict of the WAN IP addresses
2. Smart system optimization such as service-based network policy configuration, RF channel and roaming adjustment
3. Diagnosis and repair suggestions for more than 30 common network anomalies including DHCP conflicts, abnormal negotiation rates, excessive traffic, AP disconnection and device interference.
RG-RAP2260(G)
RG-RAP2260(E)
Radio
Dual-stream dual-band
Protocol
Concurrent 802.11ax, 802.11ac wave2/wave1, 802.11a/b/g/n
Operating Bands
802.11b/g/n/ax :2.4G ~ 2.4835GHz
802.11a/n/ac/ax : 5G:5.150~5.350GHz,5.725~5.850GHz (country specific)
802.11b/g/n :2.4G ~ 2.4835GHz
Internal antennas(2.4G: 3dBi,5G: 3dBi)
Spatial Streams
2.4G 2x2MIMO  5G 2x2MIMO
2.4G 4x4MIMO  5G 4x4MIMO
Max Throughput
Up to 574Mbps at 2.4G
Up to 1201Mbps at 5G
1.775Gbp per AP
Up to 800Mbps at 2.4G
Up to 2402Mbps at 5G
3.202Gbp per AP
Modulation
OFDM:
BPSK@6/9Mbps,QPSK@12/18Mbps,16QAM@24Mbps,64QAM@48/54Mbps
DSSS:
DBPSK@1Mbps,DQPSK@2Mbps,
and CCK@5.5/11Mbps
MIMO-OFDM:
BPSK,QPSK,16QAM ,64QAM,256QAM and1024QAM
OFDMA
OFDM:
DSSS:
and CCK@5.5/11Mbps
MIMO-OFDM:
OFDMA
Receive Sensitivity
11b:
-96dBm(1Mbps),
-93dBm(5Mbps),
-89dBm(11Mbps)
11a/g:
-91dBm(6Mbps),
-85dBm(24Mbps),
-80dBm(36Mbps),
-74dBm(54Mbps)
11n:
-90dBm(MCS0),
-70dBm(MCS7),
-89dBm(MCS8),
-68dBm(MCS15)
11ac:
20MHz:-88dBm(MCS0), -63dBm(MCS9)
40MHz:-85dBm(MCS0), -60dBm(MCS9)
80MHz:-85dBm(MCS0), -60dBm(MCS9)
Wi-Fi 6:
80MHz:-82dBm(MCS0), -57dBm(MCS9),-52dBm(MCS11)
11b:
-96dBm(1Mbps),
-93dBm(5Mbps),
-89dBm(11Mbps)
11a/g:
-91dBm(6Mbps),
-85dBm(24Mbps),
-80dBm(36Mbps),
-74dBm(54Mbps)
11n:
-90dBm(MCS0),
-70dBm(MCS7),
-89dBm(MCS8),
-68dBm(MCS15)
11ac:
Wi-Fi 6:
Maximum output power of the transmitter
(single stream)
2.4GHz(2.4~2.4835GHz):23dBm
5GHz(5.150~5.250GHz,5.725~5.850GHz):23dBm
(country-specific,comply with local laws)
Adjustable Power
1dBm
1dBm
194mm×194mm×35mm (excluding mounting kits)
220mm×220mm×35mm (excluding mounting kits)
0.56kg (excluding mounting kits)
1.05kg (excluding mounting kits)
Service Ports
2 10/100/1000M Base-T Ethernet ports, PoE/LAN1 port supports PoE
1 10/100/1000M/2.5G Base-T Ethernet ports supports PoE;
1 10/100/1000M Base-T ,Ethernet ports
Management Port
NA
NA
LED Indicator
Single indicator (green light)
Local power supply, DC 12V/1.5A (Note: The power adapter is sold as an optional accessory), 802.3at PoE (Warning:802.3af or non-standard POE adapter may cause unknown issues. Please use Ruijie POE+ switch or 802.3at POE adapter as power supplier)
Power Consumption
≤ 15.3W
≤ 25.4W
Operating temperature: 0°C~40°C
Storage temperature: -40°C~70°C
Operating humidity: 5%~95%
(non-condensing)
(non-condensing)
Storage humidity: 5%~95%
(non-condensing)
(non-condensing)
Ceiling/wall-mountable
Safety Standard
GB4943, IEC 62368-1
GB4943, IEC 62368-1
EMC Standard
GB9254,EN301 489,EN50155,EN50121,EN55032,EN61000,EN55035
Vibration Standard
IEC61373
IEC61373
Radio Standard
EN300 328, EN301 893
>400000H
>400000H
Software Features
Operating Mode
AP mode and routing mode
Maximum number of clients: 512
Recommended number of clients: 100
Recommended number of clients: 120
Up to 8 SSIDs
Up to 8 SSIDs
Support SSID hiding
Configuring the authentication mode, encryption mechanism, and VLAN attributes for each SSID
Support SSID hiding
SSID-based and radio-based STA limit
Support Layer 2 user isolation
Roaming
Support Layer 2 and Layer 3 roaming
Support PSK authentication
Support static blacklist and whitelist
Support WPA (TKIP), WPA2 (AES), and WPA-PSK data encryption
Support Black List / White List:
Maximum 256 rules per SSID
Maximum 1024 rules per AP
Routing
Support static IP address, DHCP, PPPoE Dial Up
Support unified networking of all network equipment
Support local or remote management with Ruijie Cloud app
Support local management with web
Support remote management with Ruijie Cloud platform
Platform management features
Automatic RF adjustment via the platform
Unified configuration via the platform
Unified monitoring via the platform
Ordering Information
Remarks
RG-RAP2260(G)
Wi-Fi 6 dual-band Gigabit ceiling mount AP, dual Gigabit LAN uplink ports, built-in antennas, dual-band 2.4GHz/5GHz, 802.11ax, 802.11ac wave2/wave1, up to 1775Mbps access rate per AP; support AP and routing mode, Layer 3 roaming, Reyee unified networking and Ruijie Cloud app management; Support PoE and local power supply (PoE module and DC adapter are sold separately)
RG-RAP2260 Series is an ideal choice for scenarios with simple building structure, no special obstructions, and relatively concentrated users, such as conference rooms, libraries, classrooms, bars, leisure centers, etc. The AP can be flexibly implemented according to different environments, and provides user access for up to maximum 512 recommened 100 terminals per AP.
User Guide
Datasheet
PoC Guide
Software Download
Installation Guide
RGOS Configuration Guide
White Paper
Hardware Installation Guide
