Indoor hybrid cable connection, fit for monitoring, wireless connection, and other scenarios on campus networks
4 x 1GE RJ45 ports,1 x 2.5GE SFP port, 1 x DC power port, PoE/PoE+
RG-PF2920-DPBOX-P1 x 1GE RJ45 port, 1 x 1GE SFP port, 1 x DC power port, PoE/PoE+
Hardware Specifications |
RG-PF2920U-4GT1MS-P |
RG-PF2920-DPBOX-P |
| Fixed ports |
4 x 10M/100M/1000M auto-negotiation electrical ports 1 x 1000M/2.5G SFP port |
1 x 10M/100M/1000M auto-negotiation electrical port 1 x GE SFP port |
| Switching capacity |
13 Gbps |
N/A |
| Packet forwarding rate |
9.7 Mpps |
N/A |
| SFP port |
2500Base-X and 1000Base-X supported |
| Power supply |
Powered by a hybrid cable from the PoF switch Maximum voltage range: 42 V DC to 57 V DC Rated voltage range: 44 V DC to 56 V DC Rated current: 1.3 A |
Powered by a hybrid cable from the PoF switch Rated voltage: 44 V DC to 57 V DC Rated current: 0.75 A |
| Leakage current to ground |
≤ 3.5 mA |
N/A |
| EEE |
Supported |
Not supported |
| PoE |
Ethernet electrical ports 1–4 support PoE. Max. overall PoE output power: 60 W The maximum number of PoE devices supported by the switch is determined by the PoE output power of the switch and the actual power of the PoE devices. |
1 x downlink POE/POE+ port |
| Overall power consumption |
Without PoE load: ≤ 15 W With PoE full load: ≤ 75 W |
Without PoE load: ≤ 3 W Overall power (PoE+) ≤ 33 W |
| Operating temperature |
Installed in a rack or unconfined space: 0ºC to 45ºC (32ºF to 113ºF) at a height below 1,800 m (1.12 miles) above the sea level Installed on a workbench or in an ELV box: 0ºC to 40ºC (32ºF to 104ºF) at a height below 1,800 m (1.12 miles) above the sea level Note: At a height ranging from 1800 m (1.12 miles) to 5000 m (3.11 miles) above the sea level, the maximum operating temperature decreases by 1°C (1.8°F) for every increase in altitude of 220 m (721.78 ft.). |
| Storage temperature |
–40°C to +70°C (–40ºF to +158ºF) |
| Operating humidity |
10% to 90% RH |
10% to 90% RH |
| Storage humidity |
5% to 90% RH |
5% to 95% RH |
| Fan |
| Intelligent temperature control |
The temperature alarm and overheat protection functions are supported. |
Not supported |
| Electromagnetic compatibility (EMC) |
GB/T9254.1 |
GB/T9254.1 |
| Safety standard |
GB 4943.1 |
GB 4943.1 |
| Dimension (W x D x H) |
200 mm x 170 mm x 55 mm (7.87 in. x 6.69 in. x 2.17 in.) |
120 mm x 25 mm x 40 mm (4.72 in. x 0.98 in. x 1.57 in.) |
| Weight |
1.5 kg (3.30 lbs, including the package) |
0.2 kg (0.44 lbs, including the package) |
Software Specifications |
RG-PF2920-DPBOX-P |
| 802.1Q VLAN |
4K IEEE 802.1Q VLANs Port-based VLAN |
Not supported |
| DHCP |
DHCP client |
Not supported |
| Security |
Filtering of invalid MAC addresses Broadcast storm suppression Password protection CPP Port protection |
Not supported |
| EEE |
APD port sleeping |
Not supported |
| Management |
CLI-based configuration and management not required, visualized Web management IoT MQTT Syslog/Debug and SNTP |
Not supported |
| Model |
Description |
The 4-port PoE/PoE+ switch provides 1 x uplink GE optical port and 4 x downlink 10M/100M/1000M auto-negotiation electrical ports, and is connected to the hybrid cable (1 x GE/2.5GE SFP port and a round DC plug). The switch supports PoE/POE+ power supply of 4 x 15 W (or 2 x 30 W). A fanless design is adopted, and an optical link fault LED is provided. |
| RG-PF2920-DPBOX-P |
The single-port media converter is connected to a hybrid cable in the uplink direction (GE SFP port + circular DC socket) and provides a PoE/PoE+ port in the downlink direction. |
Bize Ulaşın
