RG-N18010-E Anahtarlar - 1
RG-N18010-E Anahtarlar - 2
RG-N18010-E Anahtarlar - 3
RG-N18010-E Anahtarlar - 4
RG-N18010-E Anahtarlar - 5
RG-N18010-E Anahtarlar - 6
RG-N18010-E Anahtarlar - 7
RG-N18010-E Anahtarlar - 8
RG-N18010-E Anahtarlar - 9
RG-N18010-E Anahtarlar - 10
RG-N18010-E Anahtarlar - 11
RG-N18010-E High-density Large-buffer Core Switch for Cloud Architecture Network
  • Fit for new SOE solution and innovative hyper-converged ports, allowing flexible networking
Önemli Spesifikasyonlar
Özellikler
RG-N18010-E
Up to 52 x 10GE ports and 12 x 100GE ports per line card, and up to 416 x 10GE ports and 96 x 100GE ports per switch
Front Panel
Rear Panel
Eight line card slots,
M18000E-8SFX
8 x SFX 10GE ports
M18000E-8SFG
8 x SFG GE ports
M18000E-HCA
20 x 10GE optical ports
4 x 100GE optical ports
Low CPU usage Low CPU usage
Faulty Optical Port Isolation
Visualization Visualization
Virtualization Virtualization
Spesifikasyonlar
RG-N18010-E
RG-N18014-E
2 x supervisor module slots
8 x line card slots
4 x power module slots
12 x line card slots
Supervisor module
M18000E-CM
M18000E-CM II
Switch fabric module
M18010E-FE-X I
M18000E-FE-X II
M18000E-FE-X II
Line card
M18000E-48GT4XS-XA
M18000E-48SFP4XS-XA
M18000E-24GT8SFP8XS-XA
M18000E-32XS-XB
M18000E-52XS-XB
M18000E-12CQ-XB
M18000E-32XS-XE
M18000E-52XS-XE
M18000E-12CQ-XE
M18000E-24CQ-XE
M18000E-8SFG
M18000E-8SFX
RG-PA600I
RG-PA1600I
M10C-FAN (pre-installed 2)
M14FAN-F (pre-installed 2)
Module management port
Supervisor module:
● 1 x RJ45 console port
● 1 x RJ45 MGMT port
Switch fabric module:
RG-N18010-E
RG-N18014-E
28,800 Mpps
43,200 Mpps
38.4 Tbps
57.6 Tbps
Supervisor module:
Line card:
● M18000E-XE card: quad-core CPU, 2 x 2.0 GHz + 2 x 1.5 GHz
● M18000E-HCA card: octa-core CPU, each core with the clock speed of 2.2 GHz
M18000E-CM/CM II: supported
M18000E-CM/CM II: 16 MB
XA/XB/XE/CWDM/FE card: 16 MB
M18000E-HCA: 16 MB
M18000E-CM: 8 GB
M18000E-CM II: 16 GB
XA/XB/XE/CWDM/FE card: 8 GB
M18000E-HCA: 16 GB
M18000E-CM: 4 GB DDR4
M18000E-CM II: 16 GB DDR4
XA/XB/XE/CWDM/FE card: 4 GB DDR4
M18000E-HCA: 16 GB DDR4
XA card: 4 MB
XE card: 14 MB
XB/CWDM/HCA card: 35 MB
* 1 means the system's packet forwarding rate.
* 2 means the system's switching capacity.
RG-N18010-E
RG-N18014-E
4 x pluggable power modules
RG-PA600I (AC input):
● Maximum input current: 10 A
RG-PA1600I (AC input):
● Maximum input current: 16 A
RG-PA600I: 600 W
RG-PA1600I:
Supervisor module:
● M18000E-CM: < 60 W
● M18000E-CM II: < 70 W
● M18000E-FE-X II: < 160 W
Line card:
● M18000E-48GT4XS-XA: < 85 W
● M18000E-32XS-XB: < 149 W
● M18000E-52XS-XB: < 250 W
● M18000E-12CQ-XB: < 240 W
● M18000E-32XS-XE: <110 W
● M18000E-52XS-XE: <140 W
● M18000E-12CQ-XE: <160 W
● M18000E-24CQ-XE: <240 W
● M18000E-8SFG: < 250 W
● M18000E-8SFX: < 250 W
● M18000E-HCA: < 280 W
● HCA-20XS: < 30 W
● HCA-4CQ: < 20 W
● M18000E-FE-X I: < 50 W
Fan module:
● M10C-FAN: < 216 W
Fan module:
● M14FAN-F: < 360 W
RG-N18010-E
RG-N18014-E
442.0 mm x 561.0 mm x 605.1 mm (17.40 in. x 22.09 in. x 23.82 in., cable management bracket excluded)
442.0 mm x 670.1 mm x 605.1 mm (17.40 in. x 26.38 in. x 23.82 in., cable management bracket included)
860.0 mm x 670.0 mm x 887.0 mm (33.86 in. x 26.38 in. x 34.92 in.)
10 RU
14 RU
68.3 kg (150.58 lbs)
82.5 kg (181.88 lbs)
RG-N18010-E
RG-N18014-E
35°C (95°F): 55.9 dB
50°C (122°F): 73.4 dB
Supervisor module redundancy
1+1 redundancy (same model)
1+N redundancy (same model)
N+M redundancy (same model)
Over-temperature alarming
Service port: 4 kV
RG-N18010-E
RG-N18014-E
RG-N18000-E Series
3,200 Gbps
Without the HCA card:
XA card: 96,000
XB card: 256,000
XE card: 256,000
CWDM card: 256,000
With the HCA card:
XA card: 150,000
XB card: 512,000
XE card: 384,000
CWDM card: 512,000
HCA card: 512,000
XA card: 40,000
XB card: 96,000
XE card: 90,000
CWDM card: 96,000
HCA card: 95,000
XA card: 40,000
XB card: 80,000
XE card: 54,000
CWDM card: 80,000
HCA card: 95,000
● Without the HCA card:
XA card: 64,000 (shared with IPv6 routes)
XB card: 350,000 (shared with IPv6 routes)
XE card: 192,000 (shared with IPv6 routes)
CWDM card: 350,000 (shared with IPv6 routes)
● With the HCA card:
XA card: 1.5 million
XB card: 1.5 million
XE card: 1.5 million
CWDM card: 1.5 million
HCA card: 1.5 million
XA: 15,000 (shared with IPv4 routes)
XB: 65,000 (shared with IPv4 routes)
XE card: 30,000 (shared with IPv4 routes)
CWDM card: 65,000 (shared with IPv4 routes)
XA card: 1 million
XB card: 1 million
XE card: 1 million
CWDM card: 1 million
HCA card: 1 million
4,000 (2,000 in super-optical or super-optical-hca mode)
2,000 (1,000 in super-optical or super-optical-hca mode)
● XA card
In: 7,500 Out: 3,750
● XB card
In: 28,000 Out: 4,000
● XE card
In: 21,000 Out: 8,000
● CWDM card
● HCA card
In: 24,000 Out: 4,000
RG-N18000-E Series
Ethernet Switching
Ethernet Switching
Ethernet Switching
Ethernet Switching
Ethernet Switching
Ethernet Switching
Ethernet Switching
Ethernet Switching
Ethernet Switching
Ethernet Switching
Ethernet Switching
IPv4 and IPv6 GRE tunnel
IP Routing
IP Routing
IP Routing
IP Routing
IP Routing
IP Routing
IP Routing
IP Routing
IPv4/IPv6 PBR
IGMPv1/v2 snooping
IGMP proxy
Multicast static routing
MLDv1 snooping
Validity check of IGMP packets
MPLS 6VPE and MPLS 6PE
MPLS IPv6
ACL80 and IPv6 ACL
IEEE 802.1p
Multi-AAA
IEEE 802.1X
Loose and strict RPF
IPv4/IPv6 ECMP
1+1 redundancy for fan modules
GR for OSPF/IS-IS/BGP
Hot swapping of supervisor modules, switch fabric modules, power modules, and fan modules
Device Virtualization
SPAN, RSPAN, and ERSPAN
VLAN mirroring
FTP, SFTP, TFTP, and Xmodem
SNMP v1/v2/c3
Web-based NMS
LAN access to VXLAN
IPv4 over IPv4
Distributed gateway
IPv6 over IPv6
VXLAN static route
Anycast gateway
VXLAN bridging mode
VXLAN routing mode
Static VXLAN tunnel creation
Layer 2 VXLAN bridge
Layer 3 VXLAN gateway
EVPN VXLAN
Kaynaklar
Sipariş Bilgileri
RG-N18010-E
RG-N18014-E
M18000E-CM
M18000E-CM II
Power Modules and Fan Modules
RG-PA600I
RG-PA1600I
SFUs
M18010E-FE-X I
M18000E-FE-X II
Line Cards
M18000E-32XS-XB
32 x 1GE/10GE SFP+ ports (LC)
M18000E-52XS-XB
52 x 1GE/10GE SFP+ ports (LC)
M18000E-12CQ-XB
M18000E-48GT4XS-XA
M18000E-48SFP4XS-XA
M18000E-32XS-XE
32 x 10GE SFP+ ports (LC)
M18000E-52XS-XE
52 x 10GE SFP+ ports (LC)
M18000E-12CQ-XE
12 x 100GE QSFP28 ports (LC/MPO)
M18000E-24CQ-XE
24 x 100GE QSFP28 ports (LC/MPO)
M18000E-8SFX
M18000E-8SFG
M18000E-HCA
HCA-20XS
20 x 1GE/10GE SFP ports (LC)
HCA-4CQ
XG-SFP-T
XG-SFP-T
10GBASE-T, SFP+ to RJ45 transceiver, 70 m
SFM-LR-SM
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
