RG-S7810C-X Anahtarlar - 1
RG-S7810C-X Anahtarlar - 2
RG-S7810C-X Anahtarlar - 3
RG-S7810C-X Anahtarlar - 4
RG-S7810C-X 10 RU Modular Campus Core Switch
Can be deployed in data centers, metropolis area networks, campus networks, or integrated scenarios of data centers and campus networks
Önemli Spesifikasyonlar
Özellikler
Modular Core Switch RG-S7810C-X
Eight line card slots support a wide range of cards that provide various port types, including high-density color optical cards, catering to the diverse needs of small, medium, and large-scale campus deployments.
8 x line card slots
M7800C-8SFG-XB
  • 8 GE SFG ports
M7800C-8SFX-XB
  • 8 10GE SFX ports (compatible with GE)
1+1
Supervisor module Redundancy
Dual-Boot Redundancy
N+M
Power Supply Redundancy
N+M Power Supply Redundancy
1+1 Fan Module Redundancy
1+1
Spesifikasyonlar
RG-S7805C
RG-S7808C
RG-S7810C
2 x supervisor module slots
3 x line card slots
1 x fan module slot
6 x line card slots
4 x power module slots
Supervisor module
M7805C-CM II
M7808C-CM II
M7810C-CM
M7810C-CM-F
Switch fabric module
line card
● M7800C-32XS4QXS-DA
● M7800C-24GT24SFP4XS-EB
● M7800C-24SFP/12GT4XS-EB
● M7800C-48GT4XS-EB
● M7800C-48SFP4XS-EB
● M7800C-48GT-FA
● M7800C-48SFP-FA
● M7800C-48XS-FB
● M7800C-8CQ-FB
*1
● M7800C-48GT4XS-EB
● M7800C-48GT-FA
● M7800C-48SFP-FA
● M7800C-48XS-FB
● M7800C-8CQ-FB
*1
● M7800C-48GT4XS-EB
● M7800C-48GT-FA
● M7800C-48SFP-FA
● M7800C-48XS-FB
● M7800C-8CQ-FB
*1
RG-PA300I-F
RG-PA460I-F
RG-PA1000I-F
RG-PA600I-F
RG-PA1600I-F
RG-PA600I
RG-PA1600I
M05C-FAN (pre-installed 1)
M08-FAN (pre-installed 2)
M10C-FAN (pre-installed 2)
Module management port
M7805C-CM II:
● 1 x RJ45 console port
● 1 x RJ45 MGMT port
M7808C-CM II:
M7810C-CM:
M7810C-CM-F:
● 1 x RJ45 console port *2
M7810C-CM: 1 x USB 2.0 port
M7810C-CM-F: 1 x USB 2.0 port
RG-S7805C
RG-S7808C
RG-S7810C
4500 Mpps
9000 Mpps
12000 Mpps
System switching capacity *4
6000 Gbps
12000 Gbps
16000 Gbps
Supervisor module:
Line card
Supervisor module:
Line card
Supervisor module:
Line card
M7805C-CM II: supported
M7808C-CM II: supported
M7805C-CM II:8 MB
EB card: 8 MB
DA/FA/FB card: 16 MB
M7808C-CM II: 16 MB
EB card: 8 MB
M7810C-CM/M7810C-CM-F: 16 MB
EB card: 8 MB
M7805C-CM II: 1 GB
EB card: 512 MB
DA/FA/FB card: 8 GB
M7808C-CM II: 8 GB
EB card: 512 MB
DA/FA/FB card: 8 GB
M7810C-CM/M7810C-CM-F: 8 GB
EB card: 512 MB
DA/FA/FB card: 8 GB
M7805C-CM II: 4 GB DDR3
EB card: 1 GB DDR3
DA card: 1 GB DDR4
FA/FB card: 2 GB DDR4
M7808C-CM II: 4 GB DDR4
EB card: 1 GB DDR3
DA card: 1 GB DDR4
EB card: 1 GB DDR3
DA card: 1 GB DDR4
M7810C-FE-D I: 1 GB DDR4
M7810C-FE-F I: 2 GB DDR4
EB: 4 MB
FB: 32 MB
FA: 8 MB
DA: 16 MB
EB: 4 MB
FB: 32 MB
FA: 8 MB
DA: 16 MB
EB: 4 MB
FB: 32 MB
FA: 8 MB
DA: 16 MB
RG-S7805C
RG-S7808C
RG-S7810C
4 x pluggable power modules
RG-PA300I-F (AC input):
RG-PA460I-F (AC input):
RG-PA1000I-F (AC input):
● Maximum input current: 10 A
RG-PA600I-F (AC input):
RG-PA1600I-F (AC input):
● Maximum input current: 16 A
RG-PA600I (AC input):
RG-PA1600I (AC input):
RG-PA300I-F: 300 W
RG-PA460I-F: 460 W
RG-PA1000I-F:
● 100 V AC to 176 V AC: 800 W
RG-PA600I-F: 600 W
RG-PA1600I-F:
RG-PA600I: 600 W
RG-PA1600I:
M05C-FAN: < 80 W
M7805C-CM II: < 21 W
M08-FAN: < 88 W
M7808C-CM II: < 50 W
M10C-FAN: < 216 W
M7810C-CM: < 50 W
M7810C-CM-F: < 110 W
M7800C-32XS4QXS-DA: < 210 W
M7800C-48GT4XS-EB: < 70 W
M7800C-48SFP4XS-EB: < 101 W
M7800C-48GT-FA: < 75 W
M7800C-48SFP-FA: < 95 W
M7800C-48XS-FB: < 160 W
M7800C-8CQ-FB: < 130 W
RG-S7805C
RG-S7808C
RG-S7810C
4 RU
10 RU
10 RU
28.05 kg (61.84 lbs)
43.93 kg (96.85 lbs)
68.30 kg (150.58 lbs)
RG-S7805C
RG-S7808C
RG-S7810C
27°C (80.6°F): 70 dB
Max Noise: 77 dB
Max Noise: 77 dB
Max Noise: 77 dB
Supervisor module redundancy
1+1 redundancy (same model)
N+M redundancy (same model)
Over-temperature alarming
Service port: 4 kV
Power port: 6 kV
RG-S7805C
RG-S7808C
RG-S7810C
RG-S7805C
RG-S7808C
RG-S7810C-X
3 x line card slots
1 x fan module slot
6 x line card slots
8 x line card slots
Supervisor module
M7805C-CM-X
M7808C-CM-X
M7810C-CM-X
M7810C-FE-X I
M7810C-FE-X II
line card
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-24GT8SFP8XS-XA
M7800C-32XS-XA
M7800C-52XS-XB
M7800C-12CQ-XB
M7800C-48XT-P-XB
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-32XS-XA
M7800C-52XS-XB
M7800C-12CQ-XB
M7800C-48XT-P-XB
M7800C-8SFG-XB
M7800C-8SFX-XB
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-32XS-XA
M7800C-52XS-XB
M7800C-12CQ-XB
M7800C-48XT-P-XB
M7800C-8SFG-XB
M7800C-8SFX-XB
RG-PA300I-F
RG-PA460I-F
RG-PA1000I-F
RG-PA600I-F
RG-PA1600I-F
RG-PA600I
RG-PA1600I
RG-PD600I
M7805C-CM-X:
M7808C-CM-X:
M7810C-CM-X:
M7810C-FE-X I/II:
RG-S7805C
RG-S7808C
RG-S7810C-X
4500 Mpps
9000 Mpps
14300 Mpps
6000 Gbps
12000 Gbps
19200 Gbps
Supervisor module:
Line card:
Supervisor module:
Line card:
Supervisor module:
Line card:
M7805C-CM-X: supported
M7808C-CM-X: supported
M7810C-CM-X: supported
M7805C-CM-X: 16 MB
XA/XB card: 16 MB
M7808C-CM-X: 16 MB
XA/XB card: 16 MB
M7810C-CM-X: 16 MB
M7810C-FE-X I/II: 16 MB
XA/XB card: 16 MB
M7805C-CM-X: 8 GB
XA/XB card: 8 GB
M7808C-CM-X: 8 GB
XA/XB card: 8 GB
M7810C-CM-X: 8 GB
M7810C-FE-X I/II: 8 GB
XA/XB card: 8 GB
M7805C-CM-X: 4 GB DDR4
XA/XB card: 4 GB DDR4
M7808C-CM-X: 4 GB DDR4
M7810C-CM-X: 4 GB DDR4
M7810C-FE-X I: 1 GB DDR4
M7810C-FE-X II: 4 GB DDR4
XB series line card: 35 MB
M7800C-32XS-XA: 35 MB
RG-S7805C
RG-S7808C
RG-S7810C-X
RG-PD600I (DC input):
● Maximum input current: 20 A
RG-PA300I-F: 300 W
RG-PA460I-F: 460 W
RG-PA1000I-F:
RG-PA600I-F: 600 W
RG-PA1600I-F:
RG-PA600I: 600 W
RG-PA1600I:
RG-PD600I: 600 W
M05C-FAN: < 80 W
M7805C-CM-X: < 40 W
M08-FAN: < 88 W
M7808C-CM-X: < 62 W
M7800C-8SFG-XB: < 250 W
M7800C-8SFX-XB: < 250 W
M10C-FAN: < 216 W
M7810C-CM-X: < 60 W
M7810C-FE-X I: < 50 W
M7810C-FE-X II: < 160 W
M7800C-48GT4XS-XA: < 85 W
M7800C-48SFP4XS-XA: < 117 W
M7800C-24GT8SFP8XS-XA: < 95 W
M7800C-32XS-XA: < 149 W
M7800C-52XS-XB: < 250 W
M7800C-12CQ-XB: < 240 W
M7800C-48XT-P-XB: < 300 W
M78-PSE-X
2 x PoE out ports
RG-PA1600I-PL
RG-PA1600I-PL (AC input):
RG-PA1600I-PL
5.0 kg (11.02 lbs)
RG-S7805C
RG-S7808C
RG-S7810C-X
4 RU
10 RU
10 RU
RG-S7805C
RG-S7808C
RG-S7810C-X
Max Noise: 77 dB
Max Noise: 77 dB
Max Noise: 77 dB
Over-temperature warning
Service port: 4 kV
Power port: 6 kV
RG-S7805C
RG-S7808C
RG-S7810C-X
RG-S7800C Series
GRE tunnel
IP routing
IPv4/IPv6 IS-IS
EVPN
IPv4/IPv6 VRF
Policy-based routing (PBR)
IPv4 and IPv6 ECMP
IGMP v1/v2/v3
IGMP snooping v1/v2/v3
IGMP proxy
MLDv1 and MLDv2
Multicast static routing
MLD v1/v2 snooping
MPLS IPv6
MPLS 6VPE
ACL80 and IPv6 ACL
Port-based rate limiting
802.1p
CAR
ICMP
uRPF
VRRP for the super-VLAN
Hot swapping of components
GR for OSPF/IS-IS/BGP
SPAN, RSPAN, and ERSPAN
NTP
SNTP
FTP, TFTP, and Xmodem
Web-based NMS
RG-S7800C-X Series
IP subnet-based VLAN
MAC VLAN
Port-based VLAN
protocol-based VLAN
Super-VLAN
STP (IEEE 802.1.d)
RSTP (IEEE 802.1w)
MSTP (IEEE 802.1s)
Device Virtualization
SDN
OpenFlow 1.3
DHCPv6 client
DHCPv6 relay
FTP Server
FTP Client
NTP server
NTP Client
SNTP Client
TFTP Client
TFTP Server
IP routing
BGP4
BGP4+
IS-ISv4
IS-ISv6
OSPFv2
OSPFv3
RIP
RIPng
Routing Policy
IPv4/IPv6 VRF
IGMP v1/v2/v3
IGMP snooping v1/v2
IGMP proxy
PIM-DM
PIM-SM
MLDv1 and MLDv2
MLD v1/v2 snooping
MPLS 6VPE
MPLS IPv6
MPLS forwarding
LDP
LSP
VXLAN Layer 2 bridge
VXLAN Layer 3 gateway
EVPN VXLAN
Standard IP ACL
extended IP ACL
extended MAC ACL
Layer 2 and Layer 3 port ACL
VLAN ACL
Expert-level ACL
ACL 80
Applying ACLs globally
ACL COUNTER
ACL LOGGING
ACL REMARK
802.1P
SP
WRR
SP+WFR
RED/WRED
MPLS QOS
VRRP+
Faulty optical port isolation
port security
RADIUS
uRPF
SSHv2
IPv6 SAVI
SNMP V1/V2c/V3
RMON
GRPC
Fault alarm and auto-recovery
SPAN
RSPAN
ERSPAN
VLAN mirroring
Web-based NMS
Energy-Saving Design
Kaynaklar
Sipariş Bilgileri
Switch Chassis
RG-S7805C
RG-S7808C
RG-S7810C
RG-S7810C-X
Supervisor Modules
M7805C-CM II
M7808C-CM II
M7810C-CM
M7810C-CM-F
M7805C-CM-X
M7808C-CM-X
M7810C-CM-X
Notes:
Switch Fabric Modules
M7810C-FE-D I
M7810C-FE-F I
M7810C-FE-X I
M7810C-FE-X II
Line Cards
M7800C-32XS4QXS-DA
M7800C-48GT4XS-EB
M7800C-48SFP4XS-EB
M7800C-48GT-FA
M7800C-48SFP-FA
M7800C-48XS-FB
48 x 1GE/10GE SFP+ ports (LC)
M7800C-8CQ-FB
Notes:
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-32XS-XA
M7800C-52XS-XB
52 x 1GE/10GE SFP+ ports (LC)
M7800C-12CQ-XB
M7800C-48XT-P-XB
M7800C-8SFG-XB
M7800C-8SFX-XB
Power Chassis and Modules
RG-PA300I-F
RG-PA460I-F
RG-PA600I
RG-PA600I-F
RG-PA1000I-F
RG-PA1600I
RG-PA1600I-F
M78-PSE-X
RG-PA1600I-PL
RG-PD600I
XG-SFP-T
SFM-LR-SM
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
