RG-RSR20-XA-24 Yönlendiriciler - 1
RG-RSR20-XA-24 Yönlendiriciler - 2
RG-RSR20-XA-24 Yönlendiriciler - 3
RG-RSR20-XA-24 Yönlendiriciler - 4
RG-RSR20-XA-24 Yönlendiriciler - 5
RG-RSR20-XA-24 Yönlendiriciler - 6
RG-RSR20-XA-24 Yönlendiriciler - 7
RG-RSR20-XA-24 Yönlendiriciler - 8
RG-RSR20-XA-24 Yönlendiriciler - 9
RG-RSR20-XA-24 Yönlendiriciler - 10
RG-RSR20-XA-24 24-Port Multi-service Fixed Access Router
Önemli Spesifikasyonlar
Özellikler
Rich port types and quantity, and various network functions including routing, switching, security, and wireless.
Suitable for access scenarios of small and medium-sized enterprise branches in financial, government, and other industries.
4G/5G supported
Software-Level Dual-Boot
Spesifikasyonlar
RG-RSR20-XA-24
RG-RSR20-XA-36
RG-RSR20-XA-54
WAN ports:
● 4 x 10GE SFP+ ports
● 4 x 1GE SPF ports
● 4 x 10/100/1000BASE-T ports
WAN ports:
● 4 x 1GE SPF ports
WAN ports:
● 2 x 10GE SFP+ ports
4 x expansion module slots
224 Gbps
4 Mpps
100,000
2,048
100,000
Number of IGMP Groups
Number of MLD Groups
150 W
● Maximum input current: 3 A
RG-PD150IB-F (DC input):
● Maximum input current: 5 A
Power output
● Output voltage: 12 V
RG-PD150IB-F: 150 W
6 kV
RG-RSR20-XA Series
IPv6 GRE tunnel
BGP and BGP4+
Routing policies
Static multicast routing
MPLS forwarding
IPv6 ACLs
uRPF
GR for OSPF/IS-IS/BGP
SDN technology
SPAN and ERSPAN
NTP server and NTP client
Kaynaklar
Sipariş Bilgileri
RG-RSR20-XA-24
RG-RSR20-XA-36
RG-RSR20-XA-54
Expansion Module
HSIC-2E1/CE1
Power Module
RG-PD150IB-F
150 W DC power module
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
