RG-SF2920-8GT2MG2XS-P Anahtarlar - 1
RG-SF2920-8GT2MG2XS-P Anahtarlar - 2
RG-SF2920-8GT2MG2XS-P Anahtarlar - 3
RG-SF2920-8GT2MG2XS-P Anahtarlar - 4
RG-SF2920-8GT2MG2XS-P Anahtarlar - 5
RG-SF2920-8GT2MG2XS-P Anahtarlar - 6
RG-SF2920-8GT2MG2XS-P Anahtarlar - 7
RG-SF2920-8GT2MG2XS-P 8-Port GE All-Optical PoE Switch, 2 × 5G Electrical Ports (Backward Compatible)
  • Various port combinations, surge protection greater than 8 kV, 8 x 10/100/1000BASE-T ports, ports 3 to 8 PoE/PoE+ supported, 2 x 1G/2.5G/5GBASE-T ports, ports 1 to 2 PoE/PoE+ supported, and 2 x 1GE/10GE SFP+ ports for uplink
Önemli Spesifikasyonlar
Özellikler
All-Optical Ethernet Switch RG-SF2920-8GT2MG2XS-P
This switch provides 8 x 10/100/1000BASE-T ports, ports 3 to 8 PoE/PoE+ supported, 2 x 1G/2.5G/5GBASE-T ports, ports 1 to 2 PoE/PoE+ supported, 2 x 1GE/10GE SFP+ uplink ports, rich interfaces, supporting full service expansion.
and No Security Concern
Flexible Installation
Heat Dissipation Design
Quietness
Optical Link O&M
Spesifikasyonlar
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2MG2XS
RG-SF2920-16GT2SFP
2 x 1G/2.5GBASE-T ports
16 x 10/100/1000BASE-T ports
2 x 1GE SFP ports
RG-SF2920-16GT2SFP-P
RG-SF2920-16GT2MG2XS-P
2 x 1GE SFP ports
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
49.1 Mpps
61 Mpps
26.8 Mpps
System switching capacity *2
66 Gbps
82 Gbps
256 MB
512 MB DDR3
1.5 MB
500
500
Ingress: 1,500
Egress: 500
26.8 Mpps
56.5 Mpps
68.44 Mpps
76 Gbps
92 Gbps
256 MB
512 MB DDR3
1.5 MB
500
500
Ingress: 1,500
Egress: 500
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
1.97 kg (4.34 lbs)
2.04 kg (4.5 lbs)
1.98 kg (4.37 lbs)
2.75 kg (6.06 lbs)
2.81 kg (6.19 lbs)
2.75 kg (6.06 lbs)
2.34 kg (5.16 lbs)
2.33 kg (5.14 lbs)
2.33 kg (5.14 lbs)
3.11 kg (6.86 lbs)
3.12 kg (6.88 lbs)
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
1 x fixed power module
Fixed power supply: 25 W
Fixed power supply: 150 W
25 W (without PoE load)
150 W (full PoE load)
RG-SF2920 Series
Operating temperature:
Air discharge: 15 kV
Contact discharge: 8 kV
Service port: 8 kV
RG-SF2920 Series
RG-SF2920
MAC VLAN
Basic QinQ and flexible QinQ
Static blackhole routing
ACL80 and IPv6 ACLs
SSHv1.5 and SSHv2.0
Portal authentication
Unknown unicast suppression
Load balancing
LACP dynamic aggregation
Cross-VSU aggregate interface
IPv4 VRRP v2/v3, IPv6 VRRPv3
GR for OSPF
SPAN, RSPAN and ERSPAN
Flow- and VLAN-based SPAN
● Port priority
Kaynaklar
Sipariş Bilgileri
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
CWDM
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
