RG-AP840-I Kablosuz - 1
RG-AP840-I Kablosuz - 2
RG-AP840-I Kablosuz - 3
RG-AP840-I Kablosuz - 4
RG-AP840-I, Wi-Fi 6 Dual-Radio 5.2 Gbps Indoor Access Point
  • Max 5.2 Gbps (total 6 spatial streams) with concurrent dual-band design
  • OFDMA, MU-MIMO and BSS technology for minimal wireless signal interference
Önemli Spesifikasyonlar
Özellikler
Product Overview
RG-AP840-I is a high-performance Wi-Fi 6 enterprise AP designed for the majority of indoor scenarios. With the built-in IoT module, enterprise customers can be ready for future IoT expansion to boost the operational efffciency and customer experience.
The Ruijie RG-AP840-I supports concurrent dual-band dualradio (2x2:2 in 2.4GHz, 4x4:4 in 5GHz), up to 6 total spatial streams and a maximum of 5.2Gbps wireless throughput. Taking the advantage of Wi-Fi 6 OFDMA Modulation, MUMIMO, and BSS Color Spatial Reuse, the RG-AP840-I guarantees minimal signal interference and a maximum of 1024 client connections.
Additionally, RG-AP840-I is IoT ready with integrated module of BLE, without the need of external module and additional investment. With a total of 3 built-in Gigabit LAN ports, the LAN3 port is specially design for external IoT sensor connection with PoE out (passive) feature. Therefore, no extra power adaptor is needed for the sensor.
Upon the uprising challenges of management efffciency and wireless security, all Ruijie enterprise APs support hybrid management mode. Either deployed as standalone AP (Fat mode) or managed AP (Fit mode), the AP will detect the operation mode automatically without extra effort on ffrmware upgrade.
Product Highlights
Max 5.2 Gbps (Total 6 Spatial Streams) with Concurrent Dual-Band Design.
OFDMA, MU-MIMO and BSS Technology for minimal wireless signal interference.
IoT Ready: Integrated with BLE module and one IoT extension port with PoE Out (passive).
AI Wireless Optimization: one-click optimization powered by Ruijie WIS technology.
Hybrid Management: support standalone AP to over thousands of APs with deployment options of appliances, private cloud or public cloud service.
Mobility Management: Free mobile app available for RG-MACC-Base private cloud or Ruijie Public Cloud customers.
Spesifikasyonlar
 RG-AP840-I
Hardware specifications
Radio
Dual-radio dual-band:
Radio 1: 2.4G 11n: 2×2 MIMO
Radio 2: 5G 11ax: 4x4 MIMO
Protocol
Supports standard 802.11ax, dual-radio dual-band, concurrent 802.11ax and 802.11a/b/g/n/ac
Operating Bands
802.11b/g/n :2.4G ~ 2.483GHz
802.11a/n/ac/ax : 5.150~5.350GHz,5.47~5.725GHz,5.725~5.850GHz (vary depending on different countries)
Spatial Streams
Up to 6: 2×2:2 in 2.4GHz , 4×4:4 in 5GHz
Max Throughput
Maximum throughput of 2.4G: 400Mbps
Maximum throughput of 5G: 4.8Gbps
Maximum throughput per AP: 5.2Gbps
Modulation
OFDM:BPSK@6/9Mbps,QPSK@12/18Mbps,16-QAM@24Mbps,64-QAM@48/54Mbps
DSSS:DBPSK@1Mbps,DQPSK@2Mbps,and CCK@5.5/11Mbps
MIMO-OFDM:BPSK, QPSK, 16QAM, 64QAM, 256QAM and 1024QAM
OFDMA (up to 1024-QAM)
Receiver Sensitivity
11b:-96dBm(1Mbps),-93dBm(5Mbps),-89dBm(11Mbps)
11a/g:-91dBm(6Mbps),-85dBm(24Mbps),-80dBm(36Mbps),-74dBm(54Mbps)
11n:-90dBm(MCS0),-70dBm(MCS7),-89dBm(MCS8),-68dBm(MCS15)
11ac HT20:-88dBm(MCS0), -63dBm(MCS9)
11ac HT40:-85dBm(MCS0), -60dBm(MCS9)
11ac HT80:-82dBm(MCS0), -57dBm(MCS9)
11ax HT80:-82dBm(MCS0), -57dBm(MCS9), -52dBm(MCS11)
11ax HT160:-80dBm(MCS0), -49dBm(MCS11)
Integrated antenna design
Antenna Gain
2.4G: 3dBi
5G: 3dBi
Service Ports
3 10/100/1000M Ethernet ports (The LAN1 Port supports PoE in, LAN3 Port supports LAN & IoT module expansion with PoE out)
Management Port
1 console port
1 USB 2.0 port
IoT Capability
BLE
Reset Button
Support
Anti-theft Lock
Support
LED Indicator
1 LED indicator (Supports red, green, blue, orange and flashing mode, which indicates device access. The indicator can be switched off to silent mode.)
Transmit Power
≤100mw(20dBm) (vary depending on different countries)
Adjustable Power
1dBm
Local power supply (DC 48V/1A)  (DC Power adapters should be purchased from third-party vendors separately if needed.)
PoE+ (802.3at)
PoE (802.3af) – Not recommended: 5G radio is degraded to 2x2 MIMO, and the PoE out of the LAN3/ IoT port is disabled
Power Consumption
<25.4W
Physical Specifications
Operating Temperature: -10°C to 50°C
Storage Temperature: -40°C to 70°C
Operating Humidity: 5% to 95% (non-condensing)
Storage Humidity: 5% to 95% (non-condensing)
Installation Mode
Ceiling/wall-mountable
220mm ×220mm x48.85mm(Height of the AP only, excluding the mount kit)
1.30kg
250,000 hours
Certifications and Compliance
Safety Standard
GB4943, EN/IEC 60950-1
EMC Standard
GB9254, EN301 489
EN 55032 , EN 61000, EN 55035
Health Standard
EN 62311
Radio Standard
SRRC, EN300 328, EN301 893
Maximum clients per AP
1024 (Recommended Clients: 64)
BSSID capacity
Up to 32
Support
5G Priority (Band Steering)
Support
Configuring the authentication mode, encryption mechanism and VLAN attributes for each SSID
Support
Support
Intelligent device recognition technology
Support
Intelligent load balancing based on the number of users or traffic
Support
STA control
SSID/radio-based
Bandwidth control
STA/SSID/AP-based bandwidth control
Data encryption
WPA(TKIP), WPA-PSK, WPA2(AES), WPA3, WEP(64/128 bits)
PSK and web authentication
Support
PPSK authentication (For Employee)
Support (require wireless controller)
802.1x authentication
Support
PEAP authentication
Support
Whitelist, static/dynamic blacklist
Support
Rogue AP detection and countermeasure
Support
Dynamic ACL assignment
Support
RADIUS
Support
CPU Protection Policy (CPP)
Support
Support
IP
IPv4 and IPv6 address
Support
Multicast routing
Multicast to unicast conversion
DHCP service
DHCP Snooping, Option 82, Server, Client
Management and Maintenance
Supported wireless LAN controllers
Ruijie WS Series Wireless Controller
Ruijie MACC-Base Software Controller
Ruijie Cloud (Public Cloud)
Management protocol
Telnet, SSH, TFTP, Web
Wireless Intelligent AI Optimization Service (WIS)
Support
SNMP
SNMPV1,V2c,V3
Syslog / Debug
Support
FAT/FIT/MACC mode switching
Factory default firmware supports FAT (standalone) or FIT mode (WS controller) or MACC mode (Ruijie MACC-Base or Ruijie Cloud) management
Kaynaklar
Sipariş Bilgileri
RG-AP840-I
High-density Wi-Fi 6 (802.11ax) indoor wireless access point, concurrent dual-band dual-radio (2x2:2 in 2.4GHz, 4x4:4 in 5GHz), up to 6 total spatial streams and maximum 5.2Gbps wireless throughput, 3 Gigabit Ethernet ports (LAN3 port supports IoT sensor extension), integrated with BLE, support PoE+ and local power supply(PoE+ adapters are sold separately, which could be purchased from Ruijie while DC Power adapters should be purchased from third-party vendors separately if needed)
RG-E-130(GE)
1-port PoE adapter (1000Base-T, PoE+/ 802.3at)
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
