MINI-GBIC-ZX80-SM1550 Anahtarlar - 1
MINI-GBIC-ZX80-SM1550 Anahtarlar - 2
MINI-GBIC-ZX80-SM1550 Anahtarlar - 3
MINI-GBIC-ZX80-SM1550 Anahtarlar - 4
MINI-GBIC-ZX80-SM1550 Anahtarlar - 5
MINI-GBIC-ZX80-SM1550 1000BASE-SX SFP 1550-nm 80-km DDM Duplex LC SMF Optical Transceiver Module
Özellikler
MINI-GBIC-ZX80-SM1550 Module
The MINI-GBIC-ZX80-SM1550 is aligned to IEEE 1000BASE-ZX optical specifications and supports a link length of up to 80 kilometers over an SMF with an LC connector. It adopts the SFP form factor and operates at a wavelength of 1550 nm. The transceiver conforms to the IEEE 802.3, SFF-8472, SFF-8431, SFF-8432, SFP+ MSA, and RoHS standards.
Spesifikasyonlar
MINI-GBIC-GT
1.25 Gbps
1000base-X to 1000base-T
RJ45
Cat 5e/6/6a
550 m (1,804.46 ft.)
80 km (262,467.19 ft.)
100 m (328.08 ft.)
No
≤ 1.5 W
Wavelength (nm)
850
1310
1310
1550
–3 dBm
5 dBm
–9.5 dBm
–11 dBm
–5 dBm
Min. extinction ratio
≥ 9 dB
< –17 dBm
< –19 dBm
< –23 dBm
< –27 dBm
–3 dBm
–3 dBm
–3 dBm
35 g (0.08 lbs.)
1.25 Gbps
FP
FP
20 km (65,616.80 ft.)
3 km (9,842.52 ft.)
≤ 1.5 W
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
–3 dBm
–5 dBm
–9 dBm
≥ 9 dB
< –23 dBm
< –20 dBm
< –22 dBm
–3 dBm
5% RH to 95% RH
5% RH to 95% RH
35 g (0.08 lbs.)
Kaynaklar
Sipariş Bilgileri
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
