MINI-GBIC-SX-MM850 Anahtarlar - 1
MINI-GBIC-SX-MM850 Anahtarlar - 2
MINI-GBIC-SX-MM850 Anahtarlar - 3
MINI-GBIC-SX-MM850 Anahtarlar - 4
MINI-GBIC-SX-MM850 Anahtarlar - 5
Özellikler
MINI-GBIC-SX-MM850 Module
Spesifikasyonlar
MINI-GBIC-GT
1.25 Gbps
1000base-X to 1000base-T
RJ45
Cat 5e/6/6a
550 m (1,804.46 ft.)
80 km (262,467.19 ft.)
100 m (328.08 ft.)
No
≤ 1.5 W
Wavelength (nm)
850
1310
1310
1550
–3 dBm
5 dBm
–9.5 dBm
–11 dBm
–5 dBm
Min. extinction ratio
≥ 9 dB
< –17 dBm
< –19 dBm
< –23 dBm
< –27 dBm
–3 dBm
–3 dBm
–3 dBm
35 g (0.08 lbs.)
1.25 Gbps
FP
FP
20 km (65,616.80 ft.)
3 km (9,842.52 ft.)
≤ 1.5 W
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
–3 dBm
–5 dBm
–9 dBm
≥ 9 dB
< –23 dBm
< –20 dBm
< –22 dBm
–3 dBm
5% RH to 95% RH
5% RH to 95% RH
35 g (0.08 lbs.)
Kaynaklar
Sipariş Bilgileri
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
