RG-MAP852-SF-S Беспроводная сеть - 1
RG-MAP852-SF-S Беспроводная сеть - 2
RG-MAP852-SF-S Беспроводная сеть - 3
RG-MAP852-SF-S Беспроводная сеть - 4
RG-MAP852-SF-S Беспроводная сеть - 5
RG-MAP852-SF-S Беспроводная сеть - 6
RG-MAP852-SF-S Беспроводная сеть - 7
RG-MAP852-SF-S Беспроводная сеть - 8
RG-MAP852-SF-S Беспроводная сеть - 9
RG-MAP852-SF-S, Simplified Optical Ethernet (SOE) Basic Micro AP, Wi-Fi 6 Dual-Radio 1.775 Gbps
  • 1G optical port and gigabit electrical ports, integrated wired and wireless coverage
  • Data transmission and power supply through a hybrid cable
  • Upgrade to Wi-Fi 6, wireless transmission at a rate of up to 1.775 Gbps
  • Unified cloud management, intelligent optimization, and easy O&M
Основные характеристики
Ruijie All-Optical i-Share+ Solution - Micro AP (RG-MAP852-SF-S)
Solution
RG-MAP852-SF-S works with the optical i-Share master AP to realize high-bandwidth data transmission and long-distance PoE power supply through a hybrid cable, integrating wired and wireless coverage.
Wi-Fi 6
Maximum Data Rate: 1.775 Gbps
Maximum STAs: 256
i-Share Mode
P2P Power Supply Through a Hybrid Cable
New Wi-Fi 6 Experience with a Speed of 1.775 Gbps
1.775
Gbps
Hight Concurrency
Multi-user transmission technologies such as OFDMA and MU-MIMO are introduced, supporting 64 concurrent users.
Low Latency
OFDMA technology is used to transmit data to multiple terminals simultaneously. The latency is as low as 20 ms.
The next-generation wireless encryption protocol WPA3 greatly improves the security of wireless connections.
High Speed
With 1024QAM modulation, data rate is 25% higher compared with 802.11ac.
Unified Cloud Management
Intelligent Optimization, and Easy O&M
The WIS cloud network configuration and optimization can be completed without onsite operations.You can use Wi-Fi Moho for easier O&M.
With early warning of network failures, wireless networks can be monitored anytime and anywhere
Go to WIS cloud network >
Cloud O&M
24/7 Network Optimization
Real-time Warnings
Fault Location
Сравнение
Protocol
Max. data rate
MIMO
CWDM
Max. power consumption
Dimensions (W x H x D)
Характеристики
RG-MAP852-SF-S
Unit dimensions
(W x H x D)
86 mm x 160 mm x 30 mm (3.39 in. x 6.30 in. x 1.18 in.)
Shipping dimensions
383mm x 355mm x 273mm (15.08 in. x 13.98 in. x10.75 in.)
Main unit: 0.30 kg (0.66 lbs.)
Shipping weight
10.99 kg (24.23 lbs)
Ceiling/Wall/86 mm junction box-mount
White
Kensington lock
RG-MAP852-SF-S
512 MB
128 MB
RG-MAP852-SF-S
Dual-radio:
Up to a total of four spatial streams
Operating frequencies
Radio 1, 802.11b/g/n/ax:
● 2.400 GHz to 2.4835 GHz, channels 1 to 13
Radio 2, 802.11a/n/ac/ax:
● 5.725 GHz to 5.850 GHz, U-NII-3/ISM, channels 149, 153, 157, 161, and 165
Date rates
Radio 1: 2.4 GHz, 574 Mbps
Radio 2: 5 GHz, 1.201 Gbps
● Two spatial stream Multi-User (MU) MIMO for up to 1.201 Gbps wireless data rate to two 1SS or 2SS HE80 802.11ax DL-MU-MIMO client devices (maximum)
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
5 GHz radio
● 802.11n: 6.5 to 600 (MCS0 to MCS15, HT20 to HT40)
Packet aggregation
● 2.4 GHz: two built-in omnidirectional antennas, with peak antenna gain of 4.72 dBi
● 5 GHz: two built-in omnidirectional antennas, with peak antenna gain of 6.12 dBi
● Maximum transmit power: 21 dBm (125.89 mW)
● Minimum transmit power: 6 dBm (3.98 mW)
Power increment
Radio technologies
802.11b: BPSK, QPSK, CCK
Frequency Performance
RG-MAP852-SF-S
2.4GHz 802.11b
17 dBm
–90 dBm
15 dBm
–87 dBm
2.4GHz 802.11g
–78 dBm
15 dBm
–72 dBm
2.4GHz 802.11n (HT20)
15 dBm
–67 dBm
2.4GHz 802.11n (HT40)
15 dBm
–64 dBm
2.4GHz 802.11ax (HE20)
12 dBm
–58 dBm
2.4GHz 802.11ax (HE40)
12 dBm
5GHz 802.11a
–78 dBm
15 dBm
–72 dBm
5GHz 802.11n (HT20)
15 dBm
–67 dBm
5GHz 802.11n (HT40)
15 dBm
–64 dBm
5GHz 802.11ac (VHT20)
15 dBm
5GHz 802.11ac (VHT40)
15 dBm
–57 dBm
5GHz 802.11ac (VHT80)
15 dBm
5GHz 802.11ax (HE20)
12 dBm
–58 dBm
5GHz 802.11ax (HE40)
12 dBm
5GHz 802.11ax (HE80)
12 dBm
–52 dBm
Port Specifications
RG-MAP852-SF-S
Uplink: 1 x 1000BASE-X LC port
Downlink: 1 x 10/100/1000BASE-T port
1 x Micro USB console port
1 x system indicator
RG-MAP852-SF-S
● 48 V DC/0.5 A power input
● IEEE 802.3af-compliant PoE power input using hybrid cables
Maximum power consumption: 11 W
● DC power: 11 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2.
● 802.3at (PoE+) : 11 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2.
● 802.3af (PoE) : 11 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2.
● Idle mode: < 5 W
RG-MAP852-SF-S
Operating temperature: –10°C to +40°C (14°F to 104°F)
Software
RG-MAP852-SF-S
RGOS11.9(6)W1B4 or later
WLAN service
Maximum number of WLAN IDs: 16
Maximum number of users per WLAN: 256
Intelligent load balancing based on client count, traffic, or radio frequency
Enabling or disabling the radio as scheduled
Rate set settings
Parameter adjustment for enhanced user experience: client RSSI threshold, client idle timeout, client average rate threshold, transmit power of beacon frames and probe responses
WLAN QoS rate limiting, fair scheduling, and Wi-Fi Multimedia (WMM)
MU device locating
Application management
PSK and web authentication
ARP attack prevention
ICMP attack prevention
DHCP attack prevention
MAC address table size: 2,048
Jumbo frame length: 1,518 bytes
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 200
VLAN ID range: 1 to 4,094
IPv4 ping and IPv4 traceroute
DNS client
DHCP server, DHCP client, and DHCP relay
DHCPv4 snooping
IPv4 source guard
Static and dynamic IPv6 addresses
IPv6 ping and IPv6 traceroute
IPv6 transparent transmission
Static black hole routing
NTP server and NTP client
Telnet and TFTP client
RG-MAP852-SF-S
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, EN IEC 62311, IEC 62368-1, EN 62368-1, EN 18031-1, and EN 18031-2
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-MAP852-SF-S] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-MAP852-SF-S] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
Ресурсы
Информация для заказа
RG-AM5528-SF
Optical i-Share+ master AP for Ruijie SOE Solution
24 x downlink 1G/2.5G SFP ports and 24 x PoE/PoE+ power supply ports. Four power supply ports support PoE/PoE+/PoE++ power supply.
4 x uplink 10G SFP+ ports, low noise, and power supply included
RG-MAP852-SF-S
Wi-Fi 6 dual-radio wall plate micro AP for Ruijie SOE Solution
1 × SFP port
BOB structure
One 1G optical module of the master AP
RG-MAP852-SF-M
1 × 2.5G SFP port
4 ×10/100/1000Base-T Ethernet ports with auto-negotiation
Support for Bluetooth
Wall-mounted, ceiling-mounted, and junction box-mounted installation
RG-HybridBox
The hybrid box for Ruijie SOE Solution supports for the input of 24 hybrid pigtails and the output of 24 hybrid cables, connecting the hybrid pigtails to the hybrid cables.
RG-OEHC-SM-1B6A2-2x0.5-I-305
Indoor single-core 2 x 0.5 mm² hybrid cable, single roll, with a length of 305 m
RG-OEHC-SM-2B6A2-2x0.4-I-305
Indoor dual-core 2 x 0.4 mm² photoelectric hybrid cable, single roll, with a length of 305 m (1000.66 ft)
RG-OEHC-SM-2B6A2-2x1.0-I-305
RG-OEHC-SM-2B6A2-2x1.5-O-1000
