RG-AP720-L Jaringan Usaha Kecil & Menengah - 1
RG-AP720-L Jaringan Usaha Kecil & Menengah - 2
RG-AP720-L Jaringan Usaha Kecil & Menengah - 3
RG-AP720-L Jaringan Usaha Kecil & Menengah - 4
RG-AP720-L Jaringan Usaha Kecil & Menengah - 5
RG-AP720-L Jaringan Usaha Kecil & Menengah - 6
RG-AP720-L Jaringan Usaha Kecil & Menengah - 7
RG-AP720-L Jaringan Usaha Kecil & Menengah - 8
Spesifikasi Utama
Ruijie Wi-Fi 5 Indoor AP
RG-AP720-L
2.4 GHz/5 GHz Dual Radios
PoE and DC Power Input
Ceiling Mounting and Wall Mounting
WIS-based Cloud Management
Dual Radios, Combined Rate Up to 1.167 Gbps
This AP provides both a stable 5 GHz band, and a wide-coverage 2.4 GHz band. Dual radios ensure stable connectivity for more STAs.
Auto Configuration, Simplified Provisioning, Easy Deployment
You do not need to pre-configure this AP before installation. Once connected to a Ruijie wireless AC, this AP can obtain configurations from the AC to complete provisioning, thus greatly reducing the implementation and maintenance workload.
  • Remote monitoring
  • Remote Wi-Fi management
  • Cloud portal authentication
RG-AP720-L
Unit dimensions(W x D x H)
194 mm x 194 mm x 37 mm (7.64 in. x 7.64 in. x 1.46 in.)
463 mm x 370 mm x 240 mm (18.23 in. x 14.57 in. x 9.45 in.)
Main unit: 0.42 kg (0.93 lbs)
7.31 kg (16.12 lbs)
Wall/Ceiling-mount (a mounting bracket is delivered with the main unit)
RG-AP720-L
● Radio 1: 2.4 GHz, two spatial streams, 2x2 MU-MIMO
Operating frequencies
Radio 1, 802.11b/g/n:
Radio 2, 802.11a/n/ac:
Data rates
Combined peak data rate: 1.167 Gbps
2.4 GHz radio
● Two spatial stream Single User (SU) MIMO for up to 300 Mbps wireless data rate to individual 2SS HT40 802.11n client devices (maximum)
● Two spatial stream Single User (SU) MIMO for up to 144.4 Mbps wireless data rate to individual 2SS HT20 802.11n client devices (typical)
5 GHz radio
● Two spatial stream Single User (SU) MIMO for up to 867 Mbps wireless data rate to individual 2SS HT80 802.11ac client devices (typical)
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
5 GHz radio
Packet aggregation
802.11n/ac: A-MPDU and A-MSDU
Antenna gain
2.4 GHz: 4.3 dBi
5 GHz: 5.7 dBi
Maximum transmit power
Thailand
Vietnam:
5150-5350 MHZ, EIRP ≤ 23 dBm
5470-5725 MHz, EIRP ≤ 30 dBm
5725-5850 MHz, EIRP ≤ 30 dBm
Radio technologies
802.11b: BPSK, QPSK, CCK
RG-AP720-L
1 Mbps
–89dBm
–88 dBm
11 Mbps
6 Mbps
24 Mbps
36 Mbps
21 dBm
–76 dBm
54 Mbps
19 dBm
–70 dBm
21 dBm
–83 dBm
19 dBm
–65 dBm
21 dBm
–62 dBm
6 Mbps
24 Mbps
36 Mbps
21 dBm
–76 dBm
54 Mbps
19 dBm
–70 dBm
–83 dBm
–65 dBm
19 dBm
–62 dBm
17 dBm
–57 dBm
19 dBm
19 dBm
–76 dBm
–51 dBm
–83 dBm
–65 dBm
19 dBm
–62 dBm
Ports Specifications
RG-AP720-L
1 x 10/100/1000BASE-T port
● Auto MDI/MDIX crossover
● 802.3az EEE
● Press the button for longer than 3 seconds. Then the device restores to factory settings.
RG-AP720-L
● 12 V DC/1.5 A power input over DC connector: The DC connector accepts 2.1 mm/5.5 mm center-positive circular plug. A DC power adapter needs to be purchased separately.
Overall power consumption
● DC powered: 12.95 W
● Idle mode: 6 W
RG-AP720-L
RG-AP720-L
Security standards
EN 62368-1
Cyber security standards
EN 18031-1
EN 18031-2
EMC standards
EN 301 489-3
EN 301 489-17
Radio frequency standards
EN 300 328
EN 62311
EN IEC 62311
EN 50665:2017
FCC Part 15
Applicable Software Version
RG-AP720-L
RGOS 11.1(9)B1P30 or higher
RG-AP720-L
256
 Note
Maximum number of BSSIDs
Wireless roaming
Layer 2 and Layer 3 roaming
RG-AP720-L
PSK, web, 802.1X and MSCHAPv2 authentication
WPA (TKIP), WPA-PSK, WPA2, WEP (64/128-bit)
Dynamic ACL assignment based on 802.1X authentication (used with the AC)
Routing and Switching
RG-AP720-L
IP service
Static IPv4 address
IPv4 DHCP client
FTP ALG and DNS ALG
IPv6 basics
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, IPv6 Ping, IPv6 Tracert
RG-AP720-L
Fault inspection and alarm
NTP Server and NTP Client
Ruijie Cloud
Web-based management (Eweb)
Fat/Fit/Cloud mode switchover
Sumber daya
Informasi Pesanan
RG-AP720-L
Data rate of up to 1,167 Mbps
Compliance with IEEE 802.11a/b/g/n and 802.11ac Wave2 standards
One uplink electrical port
Tanya-Jawab
