RG-S5350-48GT4XS-P-E Switch - 1
RG-S5350-48GT4XS-P-E Switch - 2
RG-S5350-48GT4XS-P-E Switch - 3
RG-S5350-48GT4XS-P-E Switch - 4
RG-S5350-48GT4XS-P-E Switch - 5
RG-S5350-48GT4XS-P-E Switch - 6
RG-S5350-48GT4XS-P-E Switch - 7
RG-S5350-48GT4XS-P-E 48-Port GE Layer 3 Managed Access Switch with PoE+, 4-Port 10GE Uplink
Seri
  • PoE+ supported, powering various terminal devices
Layer 3 Compact Access Switch for 10GE Uplink RG-S5350-48GT4XS-P-E
PoE+ Supported, Powering Various Terminal Devices
The switch automatically detects and supplies the required power for devices, meeting the needs of common PoE applications such as security surveillance, teleconferencing, and wireless coverage.
Industry-leading port surge protection capability of up to 10 kV Passed anti-corrosion tests, with the proven capability to withstand exposure to moisture, ensuring durability in severe environments
CPU Protect Policy (CPP) is supported to control the packet type and traffic volume sent to the CPU, preventing high CPU usage. Virtual Switching Unit (VSU) ensures flexible networking and high performance.
The switch adopts a next-generation hardware architecture and advanced energy-efficient circuit design and components to significantly save power and lower noise. Energy-Efficient Ethernet (EEE) allows idle ports to automatically enter energy-saving mode and resume services only when needed to save energy.
The switch automatically completes registration and configuration after it accesses the all-optical network, achieving plug and play, no commissioning, and fast onboarding. A switch can be flexibly replaced based on service needs without reconfiguration. Service ports supports auto-sensing, achieving automatic O&M.
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
RG-S5350-12GT4XS-P-E
RG-S5350-24GT4XS-P-E
Fixed service ports
4 x 1GE/2.5GE/10GE SFP+ ports
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
RG-S5350-24GT4SFP-P-E
RG-S5350-48GT4SFP-P-E
Fixed service ports
4 x 1GE SFP ports
4 x 1GE SFP ports
4 x 1GE SFP ports
4 x 1GE SFP ports
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
115 Mpps
158 Mpps
94 Mpps
115 Mpps
158 Mpps
Switching capacity *2
128 Gbps / 336 Gbps
176 Gbps / 336 Gbps
104 Gbps / 336 Gbps
128 Gbps / 336 Gbps
176 Gbps / 336 Gbps
512 MB
DDR4 1GB
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
50 Mpps
94 Mpps
50 Mpps
94 Mpps
56 Gbps / 336 Gbps
104 Gbps / 336 Gbps
56 Gbps / 336 Gbps
104 Gbps / 336 Gbps
512 MB
DDR4 1GB
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
3.25 kg (7.17 lbs)
3.3 kg (7.28 lbs)
3.4 kg (7.50 lbs)
4.0 kg (8.82 lbs)
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
3.25 kg (7.17 lbs)
3.4 kg (7.50 lbs)
4.0 kg (8.82 lbs)
Power supply and Consumption
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Fixed power supply: 25 W
Fixed power supply: 40 W
Leakage current
≤ 3.5 mA
● Maximum input current: 6 A
Built-in power supply: 409 W
Built-in power supply: 460 W
35 W (without PoE load)
405 W (full PoE load)
52 W (without PoE load)
460 W (full PoE load)
Leakage current
≤ 3.5 mA
The maximum power is 370 W.
The maximum power is 405 W.
supported
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
Built-in power supply: 40 W
Leakage current
≤ 3.5 mA
●AC input
Fixed power supply: 409 W
Fixed power supply: 460 W
Leakage current
≤ 3.5 mA
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
No fan
Fanless, quiet, < 20 dB
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
RG-S5350-E Series
S5350-24GT4XS-E: 40 Gbps
S5350-24GT4XS-P-E: 40 Gbps
S5350-48GT4XS-E: 40 Gbps
S5350-48GT4XS-P-E: 40 Gbps
S5350-12GT4XS-P-E: 40 Gbps
S5350-24GT4SFP-E: 4 Gbps
S5350-24GT4SFP-P-E: 4 Gbps
S5350-48GT4SFP-E: 4 Gbps
S5350-48GT4SFP-P-E: 4 Gbps
990
750
750
255
In: 1,750 Out: 800
RG-S5350-E Series
IPv4 and IPv6 VRF
IGMP v1/v2 snooping
PIM SMv6, and PIM-SSMv6
MLDv1/v2 and MLD proxy
Extended IP (hardware ACLs
IPv6 ACLon IP addresses)
BFD, NSR, VRRR, VRRP+
Basic LACP
Dual-Boot Redundancy
SPAN, RSPAN
CLI (Telnet/Console)
Web
Syslog/Debug
1:1 mirroring
N:1 mirroring
1:N mirroring
Warm start
Sumber daya
Informasi Pesanan
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
