RG-AP680(CD) Jaringan Usaha Kecil & Menengah - 1
RG-AP680(CD) Jaringan Usaha Kecil & Menengah - 2
RG-AP680(CD) Jaringan Usaha Kecil & Menengah - 3
RG-AP680(CD) Jaringan Usaha Kecil & Menengah - 4
RG-AP680(CD) Jaringan Usaha Kecil & Menengah - 5
RG-AP680(CD) Jaringan Usaha Kecil & Menengah - 6
RG-AP680(CD) Jaringan Usaha Kecil & Menengah - 7
RG-AP680(CD) Jaringan Usaha Kecil & Menengah - 8
RG-AP680(CD) Jaringan Usaha Kecil & Menengah - 9
RG-AP680(CD) Jaringan Usaha Kecil & Menengah - 10
RG-AP680(CD), Wi-Fi 6 Dual Radio 2.402 Gbps Outdoor High Power Wireless AP
Recommended for outdoor scenarios such as higher education, wireless city, energy sector, and commercial complexes, delivering good connectivity in the extreme-weather environments at longer distances.
Seri
  • Industrial-rated design, IP68 rating, 9 kV surge protection, and a wide operating temperature range (–40°C to +65°C)
  • Optical port and electrical port for flexible networking
  • 2.402 Gbps ultra-fast speed with Wi-Fi 6
Spesifikasi Utama
RG-AP680(CD) Outdoor Wireless Access Point
2.4 GHz/5 GHz and 5 GHz/5 GHz
dual-radio design
Max. frame rate
2.402 Gbps
IP68 rating
Bluetooth 5.0
DC and PoE power input
Industrial-rated Design, Purposefully Built for Outdoor
Harsh Environments
IP68 Rating
Surge Protection
Wide Operating Temperature Range
The highest protection against solid ingress and water ingress, resisting water, dust and sand.
1 Gbps Optical Port and 1 Gbps Electrical Port Deliver Maximum Networking Flexibility
1 Gbps Optical Port
It supports i-Share+ Solution, covering a range of over one kilometer for AP deployment.
Network cable connection is supported, meeting existing networking requirements.
Ultra-Fast Speed and Capacity with Wi-Fi 6
2.402
Gbps
Hight Concurrency
OFDMA and MU-MIMO technologies are introduced for multi-STA stable connection.
Low Latency
OFDMA supports concurrent data transfer to multiple STAs at a latency as low as 20 ms.
High security
WPA3 is used to dramatically increase wireless security.
High Speed
1024QAM modulation delivers a 25% increase in data rate compared with IEEE 802.11ac.
Remote monitoring
Remote Wi-Fi management
Cloud portal authentication
RG-AP680(CD)
Unit dimensions(W x D x H)
451 mm x 242 mm x 337 mm (17.76 in. x 9.53 in. x 13.27 in.)
Main unit: 1.17 kg (2.58 lbs)
Shipment weight
5.84 kg (12.87 lbs)
RG-AP680(CD)
● Radio 1: 2.4 GHz/5 GHz, two spatial streams, 2x2 MU-MIMO
Operating frequencies
Radio 1: 802.11b/g/n/ax
Radio 2: 802.11a/n/ac/ax
Data rates
Combined peak date rate for 2.4 GHz and 5 GHz radios: 1.775 Gbps
Combined peak date rate for 5 GHz and 5 GHz radios: 2.402 Gbps
Radio 1:
2.4 GHz: 574 Mbps
5 GHz: 1.201 Gbps
Radio 2: 5 GHz, 1.201 Gbps
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
5 GHz radio
● 802.11ax: 8.6 to 1,200 (MCS0 to MCS11, NSS = 1 to 2, HE20 to HE80)
Packet aggregation
Built-in intelligent antennas
Antenna gain
2.4 GHz: 9 dBi
5 GHz: 9 dBi
Maximum transmit power
Note: The transmit power is limited by local regulatory requirements. For details, see WLAN Country or Region Codes and Channel Compliance.
Thailand
Vietnam:
5250-5350 MHZ, EIRP ≤ 23 dBm
5470-5725 MHz, EIRP ≤ 30 dBm
5725-5850 MHz, EIRP ≤ 30 dBm
Power increment
Radio technologies
802.11b: BPSK, QPSK, CCK
RG-AP680(CD)
2.4 GHz 802.11b
25 dBm
–92 dBm
25 dBm
25 dBm
–84 dBm
25 dBm
–78 dBm
2.4 GHz 802.11g
25 dBm
–84 dBm
–74 dBm
–72 dBm
–67 dBm
2.4 GHz 802.11n (HT20)
25 dBm
–84 dBm
–66 dBm
2.4 GHz 802.11n (HT40)
25 dBm
–63 dBm
2.4 GHz 802.11ax (HE20)
25 dBm
–84 dBm
2.4 GHz 802.11ax (HE40)
25 dBm
–51 dBm
5 GHz 802.11a
25 dBm
–84 dBm
–74 dBm
–72 dBm
–67 dBm
5 GHz 802.11n (HT20)
25 dBm
–84 dBm
–66 dBm
5 GHz 802.11n (HT40)
25 dBm
–81 dBm
–63 dBm
5 GHz 802.11ac (VHT20)
25 dBm
–84 dBm
19 dBm
–61 dBm
5 GHz 802.11ac (VHT40)
25 dBm
–81 dBm
19 dBm
–56 dBm
5 GHz 802.11ac (VHT80)
25 dBm
–78 dBm
19 dBm
5 GHz 802.11ax (HE20)
25 dBm
–84 dBm
5 GHz 802.11ax (HE40)
25 dBm
–81 dBm
–51 dBm
5 GHz 802.11ax (HE80)
25 dBm
–78 dBm
–48 dBm
Bluetooth Radio
RG-AP680(CD)
Bluetooth 5.0
Maximum antenna gain
4.5 dBi
10 dBm
Receive sensitivity
-88 dBm (@BLE)
Ports Specifications
RG-AP680(CD)
1 x 10/100/1000BASE-T port, supporting PoE input
1 x 1GE SFP port
3 x single-color RSSI LEDs
RG-AP680(CD)
If both DC power and PoE are available, DC power is preferred.
Overall power consumption
● DC powered: 12.95 W
● Idle mode: 6.0 W
RG-AP680(CD)
IP68
> 250,000 hours
RG-AP680(CD)
Security standards
EN 62368-1
EN 60950-22
Cyber security standards
EN 18031-1
EN 18031-2
EMC standards
EN 301489-3
EN 301489-17
Radio frequency standards
EN 300 328
EN 62311
EN IEC 62311
EN 50665
FCC Part 15
Applicable Software Version
RG-AP680(CD)
RGOS11.9(6)W1B1 or later
RG-AP680(CD)
120
1024
 Note
Maximum number of BSSIDs
RG-AP680(CD)
Dynamic ACL assignment
RG-AP680(CD)
Static IPv4 address
IPv4 DHCP client
NAT FTP ALG and NAT DNS ALG
IPv6 basics
RG-AP680(CD)
Fault inspection and alarm
NTP Server and NTP Client
Web-based management (Eweb)
Fat/Fit/Cloud mode switchover
Sumber daya
Informasi Pesanan
RG-AP680(CD)
Wi-Fi 6 dual-radio outdoor wireless access point
Up to four spatial streams
Data rate of up to 2.402 Gbps
Tanya-Jawab
