RG-WS7816C Wireless - 1
RG-WS7816C Wireless - 2
RG-WS7816C Wireless - 3
RG-WS7816C Wireless - 4
RG-WS7816C Wireless - 5
RG-WS7816C Wireless - 6
RG-WS7816C, High-Performance Enterprise-Class Wireless Access Controller
Seri
  • Supporting 128 licenses by default and up to 10,240 licenses after expansion
  • Rich port design with high capacity and high performance
  • Full-series AP management for flexible networking
  • Intelligent load balancing, improving network performance
  • MAB, 802.1X, and Web-based authentication, ensuring network security
  • Unified cloud management, enabling remote O&M
Spesifikasi Utama
RG-WS7816C, Enterprise-Class 10GE Wireless Access Controller
The RG-WS7816C is an enterprise-class 10GE access controller launched by Ruijie. Designed for medium- and large-scale networks, it can flexibly manage Ruijie wireless access points (APs), helping build a secure, efficient, and easy-to-manage wireless network.
High Capacity and High Performance
The device supports multiple ports, including 40GE, 10GE and GE ports, with a maximum forwarding capacity of 120 Gbps. It comes with 128 licenses by default and can be expanded to 8,000 licenses, flexibly meeting service needs.
Full-Series AP Management
The device can manage Ruijie's full range of APs, enabling flexible networking across Wi-Fi 7, Wi-Fi 6 and Wi-Fi 5 APs. It also supports fair client access, effectively improving the performance of low-speed clients.
Intelligent Load Balancing
Client-based load balancing, steering clients to less congested APs to prevent overload. Band-based load balancing, steering clients to the 5 GHz frequency band to enhance bandwidth utilization. Traffic-based load balancing, steering clients to APs with less traffic to increase the average bandwidth for client access.
Multiple Authentication Modes
MAB authentication: It frees a user from repeatedly entering the username and password that are required only upon first login. Other authentication modes: 802.1X, Web-based, and PPSK authentication.
Unified Cloud Management
Unified management through WIS Cloud, eliminating the need for on-site provisioning. Real-time alarms and intelligent troubleshooting, improving O&M efficiency.
Key Specifications
RG-WS7816C
Maximum number of managed APs
10,240 (indoor or wall-plate APs)
Note: The RG-WS7816C manages 128 APs by default. The maximum number of APs that can be managed by the RG-WS7816C is subject to the AP model. For details, see Ordering Information.
32,768
Maximum number of managed clients
120,000
Note: The maximum number of clients that can be managed by the RG-WS7816C is subject to the network environment. Contact technical support team for details.
802.11 forwarding performance
120 Gbps
Note: The value depends on the wireless network environment and configuration mode.
WLAN service
Maximum number of clients on each WLAN: 120,000
Maximum number of VLANs
16 x 10/100/1000BASE-T ports
12 x 10GE SFP+ ports
2 x 40GE QSFP+ ports
2 x RG-PA550I II-F power modules (one power module configured)
Power input: 100 V AC to 240 V AC, 50 Hz to 60 Hz, 7.2-3.5A MAX(X2)
Power output: 12 V DC/45 A
220 W
Rack size
Software version
RGOS11.9(6)W7 or later
NMS platform
eWeb
RG-UNC
WIS
Hardware Specification
RG-WS7816C
Excluding the rack-mount bracket: 442 mm x 420 mm x 43.6 mm (17.40 in. x 16.54 in. x 1.72 in.)
Including the rack-mount bracket: 484.6 mm x 420 mm x 43.6 mm (19.08 in. x 16.54 in. x 1.72 in.)
570 mm x 565 mm x 225 mm (22.44 in. x 22.24 in. x 8.86 in.)
Unit weight: 6.75 kg (14.88 lbs)
Shipping weight: 7 kg (15.43 lbs)
SYS: 1 x system status LED
PWR: 2 x power module LEDs
Link/ACT:
2 x MGMT port LEDs
16 x 1000M RJ45 port LEDs
12 x 10GE SFP+ port LEDs
2 x 40GE QSFP+ port LEDs
● Press the button for less than 3 seconds to restart the device.
● Press the button for more than 5 seconds to restore the device to factory settings.
Fan fault alarms
Noise
< 78 dB
Mean Time Between Failures (MTBF)
400,000 hours (44 years) at the operating temperature of 25°C (77°F)
Basic Functions
RG-WS7816C
IEEE 802.11 LAN protocols
802.11, 802.11b, 802.11a, 802.11g, 802.11d, 802.11h, 802.11w, 802.11k, 802.11v, 802.11r, 802.11i, 802.11e, 802.11n, 802.11ac, 802.11ax, and 802.11be
CAPWAP through Network Address Translation (NAT)
Number of concurrent CAPWAP data tunnels: 10,240
Roaming
Handover time for intra-AC roaming: < 50 ms
Intra-AC Layer 2 or Layer 3 roaming in centralized forwarding mode
Forwarding
Centralized forwarding
Local forwarding
Wireless QoS
(For WLAN/STA-based bandwidth limiting, the value range is from 8 to 261,120. The unit is expressed in 8 kbps.)
STA-based static rate limiting and smart rate limiting
Fair scheduling
STA isolation
AC-based global user isolation
AP-based user isolation
WLAN-based user isolation
AC virtualization
Dual-AC fast failover
Multi-AC hot standby (1:1 A/A and A/S hot standby, and N:1 hot standby)
Multi-AC cluster (N:N)
Service continuity during upgrade
Client management
AP-based access control by limiting the number of associated STAs
SSID-based access control by limiting the number of associated STAs
AP-based load balancing by limiting the number of associated STAs
AP-based load balancing by limiting STA traffic
Frequency band-based load balancing by limiting the number of associated STAs
RSSI threshold for STAs: 0 to 100, in dBm
Idle timeout period for STAs: 60 to 86,400, in seconds
WLAN optimization
RF management
Setting of the country code
Manual setting of the working channel
Automatic setting of the working channel
Automatic adjustment of the transmission rate
Coverage hole compensation
Traffic-based and STA-based AP load balancing
Band selection
IPv4 security authentication
Web-based authentication, MAB, SMS authentication, and QR code-based authentication
802.1X authentication
Maximum number of users supported by the built-in Portal server: 120,000
IPv6 security authentication
Multi-SSID mode
WPA, WPA2, and WPA3
WEP (WEP/WEP128)
TKIP
CCMP
ARP anti-spoofing
Number of ACLs: 512K (524,288)
Virtual AP
Switching and Routing
Maximum number of MAC address entries: 256K (262,144)
Maximum number of ARP entries: 308K (315,392)
Ping
Traceroute
DHCP relay agent
DHCP IP address pool
● Maximum number of IPv4 address pools: 2,000
● Maximum number of IPv4 addresses (users): 308K (315,392)
NTP
Telnet
TFTP server
TFTP client
FTP server
FTP client
DNSv6 client
DHCPv6 relay
DHCPv6 server
● Maximum number of IPv6 address pools: 256
● Maximum number of IPv6 addresses (users): 78K (80,000)
TFTPv6 client
FTPv6 server
FTPv6 client
IPv6 CAPWAP
IPv6 ping
Manually configured tunnels, automatic tunnels, and ISATAP tunnels
IPv6 traceroute
IPv4 routing
Static routing, RIP, OSPF, and PBR
IPv6 routing
Static routing, RIPng, OSPFv3, and PBR
Maximum number of multicast static routes: 2,048
Maximum number of multicast group routes: 4,096
RMON
Syslog
Remote probe
Console port login
Telnet login
SSH login
FTP upload
The following value-added software functions can be achieved when the RG-WS7816C is used with RG-WIS and APs.
RG-WS7816C
Network operation analysis such as device stability and signal coverage
Measuring user network experience based on indicators including latency, packet loss, RSSI, and channel utilization, with visualized network experience results
Statistics on the number of online and offline failures of STAs associated with different APs, average RSSI, and other parameters
Note: These functions are supported only when the AP works in Fit mode.
Network performance optimization, including one-click network optimization and optimization solution setting based on different scenarios
Sticky client roam steering and experience indicator comparison
Remote association steering and experience indicator comparison
One-click diagnosis for analyzing problems and providing suggestions
Baseline analysis, recording changes in configuration, software version, and other parameters, and tracking changes in network KPIs
Time capsule for analyzing the history of device version and configuration changes
Area analysis
Batch generation of building floor information, floor plan upload, and drag-and-drop AP placement
One-click health check report and generation of reports on the overall network operating status
Unauthorized Wi-Fi signal locating and classified display, as well as containment capabilities
Uniformly connecting, managing, and maintaining APs, ACs, and other devices
Batch device configuration and upgrade
ZTP deployment, creating configuration templates, and automatically applying configured templates
Discovering wired and wireless network topology with one click and generating the topology
Portal authentication page
Customizing Portal authentication pages for PCs and mobile phones
Interworking with Guodu and Alibaba Cloud SMS gateways
Big data capabilities
Data warehouse building based on Hive, data model conversion, and integration
Hierarchical and role-based access control
Administrators at different sites have different operation permissions.
System management functions including account operations, authorization configuration, email configuration, configuration backup, and exception alarms
Note: For details, refer to the latest hybrid cloud management solution of Ruijie Networks.
RG-WS7816C
EN 62368-1
ETSI EN 300 386
Sumber daya
Informasi Pesanan
Main Unit and Accessories
RG-WS7816C
The next-generation wireless controller RG-WS7816C provides 16 x 1000M RJ45 ports, 12 x 10GE SFP+ ports, and 2 x QSFP+ 40GE ports, supporting 128 licenses by default and up to 10,240 licenses.
The maximum number of manageable APs is subject to the AP model, as follows:
A generic AP occupies one license. The RG-WS7816C can manage up to 10,240 generic APs.
A wall-plate AP occupies half of the license. The RG-WS7816C can manage up to 10,240 wall-plate APs.
An SOE O-Share micro AP occupies no license. The RG-WS7816C can manage up to 10,240 SOE O-Share micro APs.
The number of licenses occupied by an SOE O-Share master AP is subject to the model. For details, see Ordering Information in the datasheet of corresponding SOE O-Share master AP.
One power module is configured for factory delivery, and the other power module needs to be purchased independently.
RG-PA550I II-F
550 W AC power module
License
RG-LIC-WS-16
16 licenses are provided for the RG-WS series wireless controller. A generic AP or two wall-plate APs consume one license. For the number of licenses consumed by an SOE O-Share master AP, see Ordering Information in its datasheet.
RG-LIC-WS-32
32 licenses are provided for the RG-WS series wireless controller. A generic AP or two wall-plate APs consume one license. For the number of licenses consumed by an SOE O-Share master AP, see Ordering Information in its datasheet.
RG-LIC-WS-128
128 licenses are provided for the RG-WS series wireless controller. A generic AP or two wall-plate APs consume one license. For the number of licenses consumed by an SOE O-Share master AP, see Ordering Information in its datasheet.
RG-LIC-WS-512
512 licenses are provided for the RG-WS series wireless controller. A generic AP or two wall-plate APs consume one license. For the number of licenses consumed by an SOE O-Share master AP, see Ordering Information in its datasheet.
RG-LIC-WS-1024
1,024 licenses are provided for the RG-WS series wireless controller. A generic AP or two wall-plate APs consume one license. For the number of licenses consumed by an SOE O-Share master AP, see Ordering Information in its datasheet.
Optical Transceivers
Mini-GBIC-SX
1000BASE-SX mini GBIC transceiver
Mini-GBIC-LX
1000BASE-LX mini GBIC transceiver
SR 10GE SFP+ transceiver
LR 10GE SFP+ transceiver
40GE SR QSFP transceiver, applicable to QSFP+ ports OM3 and OM4 MMF, MPO, 8-core, 850-nm wavelength, 100 m (0.062 miles) over OM3 MMF or 150 m (0.093 miles) over OM4 MMF
40G-QSFP-LR-SM1310
40GE LR4, QSFP transceiver, LC, 1310-nm wavelength, 2-core, 10 km (6.21 miles) over SMF, applicable to QSFP+ ports
