RG-MUX-8LC/LC Switch - 1
RG-MUX-8LC/LC Switch - 2
RG-MUX-8LC/LC Switch - 3
RG-MUX-8LC/LC Switch - 4
RG-MUX-8LC/LC Switch - 5
RG-MUX-8LC/LC Switch - 6
RG-MUX-8LC/LC Switch - 7
RG-MUX-8LC/LC Switch - 8
RG-MUX-8LC/LC Switch - 9
RG-MUX-8LC/LC Switch - 10
RG-MUX-8LC/LC All-Optical Modular 8-Port Transparent Distribution Device
Modular transparent distribution device supporting flexible configuration and realizing passive distribution nodes and exclusive FTTR bandwidth of 10 Gbps/1 Gbps
Seri
RG-MUX-8LC/LC 8-Port Transparent Distribution All-Optical Network Passive Device
An 8-port transparent distribution device on the building side supports both 10 Gbps and 1 Gbps per port, and can accommodate up to 48 ports when fully loaded.
The device integrates WDM technology, which allows for a network architecture reduced from three layers to two layers. With WDM, services from the core side to the access side are transparently transmitted, realizing passive distribution nodes.
1:8 Transparent Distribution Products in SOE Solution 3.0
Product Specifications
RG-MUX-8LC/LC
RG-MUX-8LC/LC-H
RG-MUX-EXT
1 x multiplexing port
Wavelength range
1271 nm to 1571 nm (CWDM)
Channel spacing
20 nm
20 nm
20 nm
Channel bandwidth
±6 nm
±6 nm
±6 nm
Insertion loss
< 3.7 dB
< 2.6 dB
< 4.2 dB
Return loss
> 45 dB
> 45 dB
> 45 dB
Polarization loss
< 0.3 dB
< 0.3 dB
< 0.3 dB
Adjacent channel isolation
> 25 dB
> 25 dB
> 35 dB
> 35 dB
LC/UPC
LC/UPC
LC/UPC
0.25 kg (0.55 lbs)
0.25 kg (0.55 lbs)
0.15 kg (0.33 lbs)
4.53 kg (9.99 lbs)
Communication standard
GR-1221-Core and GR-1209-Core
RG-MUX-BOX
6 x transparent distribution module/dual-uplink splitter slots
0.9 kg (1.98 lbs)
11.5 kg (25.35 lbs)
1:16 Transparent Distribution Products in SOE Solution 4.0
> RG-MUX-16LC/LC-H-BIDI and RG-MUX-16LC/LC-V-BIDI
Product description
> Building-side 16-port transparent distribution module, high-end version with low insertion loss, single-fiber BiDi downlink ports supporting 1GE/2.5GE/10GE rates, and a single uplink COM port, supporting standalone scenarios.
> Building-side 16-port transparent distribution module, high-end version with low insertion loss, single-fiber BiDi downlink ports supporting 1GE/2.5GE/10GE rates, built-in dual-uplink splitter, and dual uplink COM ports, supporting VSU scenarios.
Wavelength range
> 1271--1571 nm (CWDM)
Channel spacing
> 20 nm
> 20 nm
Channel bandwidth
> ±6 nm
> ±6 nm
Insertion loss
> < 5.8 dB
> < 9.8 dB
Return loss
> > 45 dB
> > 45 dB
Polarization loss
> < 0.5 dB
> < 0.5 dB
> > 25 dB
> > 25 dB
> > 35 dB
> > 35 dB
> LC/APC (uplink COM port)
> LC/UPC (downlink port)
> Storage humidity: 5% to 95% RH (non-condensing)
> 149.0 mm x 140.5 mm x 34.0 mm (5.87 in. x 5.53 in. x 1.34 in.)
> < 0.5 kg (1.10 lbs, excluding the package)
RG-MUX-BOX-H
Product description
> Subrack of the building-side transparent distribution module, 1 RU, providing three slots for inserting 16-port or 8-port transparent distribution modules or dual-uplink splitters.
> 442 mm x 50.4 mm x 43.6 mm (17.40 in. x 1.98 in. x 1.72 in., without rack mounting brackets)
> 0.6 kg (1.32 lbs, excluding the package)
Sumber daya
Informasi Pesanan
RG-MUX-8LC/LC
RG-MUX-8LC/LC-H
RG-MUX-EXT
RG-MUX-BOX
Building-side 16-port transparent distribution module, high-end version with low insertion loss, single-fiber BiDi downlink ports with LC/UPC connectors, and a single uplink COM port with an LC/APC connector, supporting standalone scenarios
Building-side 16-port transparent distribution module, high-end version with low insertion loss, single-fiber BiDi downlink ports with LC/UPC connectors, and dual uplink COM ports with LC/APC connectors, supporting VSU scenarios
RG-MUX-BOX-H
Subrack of the building-side transparent distribution module, 1 RU, providing three slots, which can accommodate 16-port or 8-port transparent distribution modules or dual-uplink splitters
Note: The CWDM transceiver is not installed on the transparent distribution module.
  • CWDM transceivers are installed on core switches in the core equipment room, and are connected to the multiplexing port of the transparent distribution module through fiber trunk cables.
  • The access-side CWDM transceiver is installed on the access switch in the building's ELV room, and is interconnected with the demultiplexing port of the transparent distribution module through a short fiber.
1:8 CWDM Transceivers in SOE Solution 3.0
Core-side 1GE BASE-LR SFG transceiver, supporting 8 wavelengths, 10 km (6.21 miles), and LC connector
SFM-LR-SM
Core-side SFM 2.5GE CWDM transceiver, supporting 8 wavelengths (for eight access devices), single-fiber, single-mode, 10 km (6.21 miles), and LC connector
Core-side 10GE BASE-LR SFP+ transceiver, supporting 8 wavelengths, 10 km (6.21 miles), and LC connector
Access-side 1GE BASE-LR SFG transceiver, supporting 8 wavelengths, 10 km (6.21 miles), LC connector, and used in dual uplink scenarios
A group of access-side high-power quasi-industrial temperature 2.5GE CWDM transceivers, including 8 transceivers with different wavelengths, single-mode, 10 km (6.21 miles), and LC connectors
Access-side 10GE BASE-LR SFP+ transceiver, supporting 8 wavelengths, 10 km (6.21 miles), LC connector, and used in dual uplink scenarios
1:16 CWDM Transceivers in SOE Solution 4.0
SFGP-LR-SM
Core-side high-density CWDM 16GE SFGP transceiver, supporting 16 distinct wavelengths (corresponding to 16 1GE access devices), SMF, 10 km (6.21 miles), and single-fiber LC/APC connector
SFXP-LR-SM
Core-side high-density CWDM 160GE SFXP transceiver, supporting 16 distinct wavelengths (corresponding to 16 10GE access devices), SMF, 10 km (6.21 miles), and single-fiber LC/APC connector
GE-SFP-LR(A1-16)-H-BIDI
A group of 16 high-power commercial-temperature 1GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single-fiber LC/UPC connector
GE-SFP-LR(A1-16)-H-E-BIDI
A group of 16 high-power quasi-industrial temperature 1GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single-fiber LC/UPC connector
XG-SFP-LR(A1-16)-H-BIDI
A group of 16 high-power commercial-temperature 10GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single-fiber LC/UPC connector, designed to be used with single-uplink transparent distribution modules
XG-SFP-LR(A1-16)-H-E-BIDI
A group of 16 high-power quasi-industrial temperature 10GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single-fiber LC/UPC connector
XG-SFP-LR(A1-16)-P-BIDI
A group of 16 ultra-high-power commercial-temperature 10GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single-fiber LC/UPC connector, designed to be used with dual-uplink transparent distribution modules
Tanya-Jawab
