RG-S2915-10GT2MS-P-L Jaringan Usaha Kecil & Menengah - 1
RG-S2915-10GT2MS-P-L Jaringan Usaha Kecil & Menengah - 2
RG-S2915-10GT2MS-P-L Jaringan Usaha Kecil & Menengah - 3
RG-S2915-10GT2MS-P-L Jaringan Usaha Kecil & Menengah - 4
RG-S2915-10GT2MS-P-L Jaringan Usaha Kecil & Menengah - 5
RG-S2915-10GT2MS-P-L Jaringan Usaha Kecil & Menengah - 6
RG-S2915-10GT2MS-P-L Jaringan Usaha Kecil & Menengah - 7
RG-S2915-10GT2MS-P-L Jaringan Usaha Kecil & Menengah - 8
RG-S2915-10GT2MS-P-L Jaringan Usaha Kecil & Menengah - 9
RG-S2915-10GT2MS-P-L Jaringan Usaha Kecil & Menengah - 10
RG-S2915-10GT2MS-P-L Jaringan Usaha Kecil & Menengah - 11
RG-S2915-10GT2MS-P-L 10-Port 1GE RJ45 Layer 2+ Managed PoE+ Switch, 2-Port 2.5GE Uplink
Seri
Spesifikasi Utama
Killer Layer 2+ Access Switch
Applications
and Wider Coverage
10 kV Surge Protection
and Uninterrupted Connection
Port Specifications
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
RG-S2915-24GT4MS-P-L
Fixed Service Ports
4 x 1GE/2.5GE SFP ports
24 x
2 x 1GE/2.5GE SFP ports
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
87 Mpps
51 Mpps
51 Mpps
22.5 Mpps
116 Gbps
68 Gbps
68 Gbps
30 Gbps
64 MB
512 MB DDR4
512 KB
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
(W x D x H) 1*
570 mm x 490 mm x 390 mm
580 mm x 450 mm x 380 mm
2.8 kg (6.17 lbs)
2.5 kg (5.51 lbs)
2.8 kg (6.17 lbs)
2.5 kg (5.51 lbs)
Shipping weight 1*
20.43 kg
(45.04 lbs)
18.18 kg
(40.08 lbs)
20.93 kg
(46.14 lbs)
15.98 kg
(35.23 lbs)
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
AC input:
AC input:
AC input:
AC input:
30 W
15.6 W
33 W (non-PoE)
403 W (full PoE load)
16 W (non-PoE)
141 W (full PoE load)
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
Forced air cooling
Forced air cooling
Forced air cooling
≤ 37 dB
≤ 39 dB
≤ 37 dB
Air discharge: 8 kV/15 kV
Contact discharge: 6 kV/8 kV
Power port: 6 kV/2 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
RG-S2915-L Series
31 (shared with routed ports)
63
62
In: 500 Out: Not Supported
Fuction
IEEE 802.1Q (4,094 VLANs)
Port based VLAN
RIP, RIPng
OSPFv2
ACL 80
SSHv1, SSHv2
IGMP V1,V2 snooping
IP Source Guard
Temperature Monitoring
Temperature Alarm
Overtemperature Protection
RSPAN
NTP
TFTP client
Sumber daya
Informasi Pesanan
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
Optical Transceivers
Tanya-Jawab
