RG-AP1920(V2) Wireless - 1
RG-AP1920(V2) Wireless - 2
RG-AP1920(V2) Wireless - 3
RG-AP1920(V2) Wireless - 4
RG-AP1920(V2) Wireless - 5
RG-AP1920(V2) Wireless - 6
RG-AP1920(V2), Wi-Fi 7 Dual-Radio 3.570 Gbps Wall Plate Access Point
Suitable for indoor scenarios such as dormitories, small offices, and guest rooms across higher education, government, K12 education, finance, and commercial sectors.
Seri
Enterprise-class Wi-Fi 7 delivering a data rate of up to 3.570 Gbps
Rich port design for integrated wired and wireless coverage
PoE and DC power supply modes for flexible deployment
WIS digital twin network for superior network O&M efficiency
Spesifikasi Utama
RG-AP1920(V2), Wi-Fi 7 Wall-Plate Access Point
The RG-AP1920(V2) is Ruijie's next-generation Wi-Fi 7 (802.11be) wall-plate access point. It supports four spatial streams and a combined peak data rate of 3.570 Gbps. With its clean and elegant appearance, it blends easily into indoor scenarios and is fit for wireless coverage scenarios such as dormitories, small offices, and guest rooms.
Enterprise-Class Wi-Fi 7 Delivering a Data Rate of Up to 3.570 Gbps
Empowering seamless high-bandwidth applications with next-generation wireless performance.
Rich Port Design for Integrated Wired and Wireless Coverage
The uplink 2.5GBASE-T port fully unleashes bandwidth performance, enabling high-speed transmission between wireless and wired networks. With four downlink ports, it meets access needs of clients such as PCs and printers, delivering integrated wired and wireless coverage.
PoE and DC Power Supply Modes for Flexible Deployment
The device supports PoE, allowing both power supply and data transmission via a single network cable connected to a PoE switch, eliminating the need for an external power adapter. It also supports DC power supply, removing the requirement for a PoE switch and helping reduce deployment costs.
WIS integrates intelligent O&M functions, including visualized fault locating, along with local, service and key area network optimization. These capabilities aim to improve operational efficiency and enhance the user experience for wireless networks.
Go to WIS >
RG-AP1920(V2)
Channel:
2 spatial streams
● Radio 2 -- 5 GHz: 2x2 downlink MU-MIMO, two spatial streams
● Channel:
Radio 2 -- 5 GHz: 6.5 Mbps to 1.733 Gbps (MCS0 to MCS9)
Radio technologies: OFDM
● A-MPDU
● A-MSDU
DFS
CDD/CSD
MRC
STBC
LDPC
TxBF
● Radio 1 -- 2.4 GHz: 2x2 uplink/downlink MU-MIMO, two spatial streams
● Radio 2 -- 5 GHz: 2x2 uplink/downlink MU-MIMO, two spatial streams
Channel:
● Radio 1 -- 2.4 GHz: 7.3 Mbps to 0.574 Gbps (MCS0 to MCS11)
Radio technologies: Uplink/Downlink Orthogonal Frequency-Division Multiple Access (OFDMA)
● A-MPDU
● A-MSDU
DFS
CDD/CSD
MRC
STBC
LDPC
TxBF
802.11be
● Channel:
● Radio 1 -- 2.4 GHz: 7.3 Mbps to 0.688 Gbps (MCS0 to MCS13)
Radio technologies: Uplink/Downlink OFDMA
● A-MPDU
● A-MSDU
DFS
CDD/CSD
MRC
STBC
LDPC
TxBF
● 2.4 GHz: Two built-in omnidirectional antennas, with the peak antenna gain of 3 dBi
● 5 GHz: Four built-in omnidirectional antennas, with the peak antenna gain of 3.8 dBi
● One built-in vertically polarized omnidirectional antenna, with the peak antenna gain of 4.3 dBi
1 x 10/100/1000/2.5GBASE-T port
4 x 10/100/1000BASE-T ports
1 x USB 3.0 (Type A connector)
1 x Bluetooth 5.1
1 x system status LED
● AP power-on status
● Uplink service interface status
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
● Press the button for shorter than 2s. Then the device restarts.
● Press the button for longer than 5s. Then the device restores to factory settings.
Dimensions (W x H x D)
Shipping:113 mm x 177.5 mm x 63 mm (4.45 in. x 6.99 in. x 2.48 in.)
Main unit: 0.3 kg (0.66 lbs)
Mounting bracket: 0.05 kg (0.11 lbs)
Shipping:0.43 kg (0.95 lbs)
Mounting in the 86 mm (3.39 in.) junction box or wall-mounting
Kensington lock
● 48 V DC/0.3 A power input over the DC connector
● IEEE 802.3af-compliant PoE power input
Maximum power consumption: 11.63 W
● DC power: 11.63 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2
● 802.3af (PoE): 11.63 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2
● Idle mode: 5.7 W
Operating temperature: -10°C to +40°C (14°F to 104°F)
Note: At an altitude in the range of 1,800-5,000 m (5,905.51-16,404.20 ft.), every time the altitude increases by 220 m (721.78 ft.), the maximum temperature decreases by 1°C (1.8°F).
512 MB DRAM, 256 MB flash
● Maximum transmit power: 20 dBm (100 mW)
● Minimum transmit power: 0 dBm (1 mW)
● You can adjust the transmit power by percentage (recommended) or in 1 dBm increments.
The transmit power is limited by local regulatory requirements. For details, see WLAN Country or Region Codes and Channel Compliance.
The following table lists the radio frequency performance of Wi-Fi including different frequency bands, protocols, and data rates. It is country-specific, and Ruijie Networks reserves the right of interpretation.
Wi-Fi Radio Performance
RG-AP1920(V2)
2.4 GHz 802.11b
24 dBm
-96 dBm
24 dBm
-95 dBm
-93 dBm
22 dBm
-89 dBm
2.4 GHz 802.11g
24 dBm
-91 dBm
-85 dBm
-80 dBm
21 dBm
-74 dBm
2.4 GHz 802.11n (HT20)
24 dBm
-90 dBm
-70 dBm
2.4 GHz 802.11n (HT40)
24 dBm
-90 dBm
-70 dBm
2.4 GHz 802.11ax (HE20)
24 dBm
-90 dBm
-62 dBm
2.4 GHz 802.11ax (HE40)
24 dBm
-88 dBm
-60 dBm
5 GHz 802.11a
24 dBm
-91 dBm
-85 dBm
--80 dBm
21 dBm
-74 dBm
5 GHz 802.11n (HT20)
24 dBm
-90 dBm
--68 dBm
5 GHz 802.11n (HT40)
24 dBm
-88 dBm
-68 dBm
5 GHz 802.11ac (VHT20)
24 dBm
-90 dBm
-68 dBm
5 GHz 802.11ac (VHT40)
24 dBm
-88 dBm
-63 dBm
5 GHz 802.11ac (VHT80)
24 dBm
-85 dBm
-60 dBm
5 GHz 802.11ax (HE20)
24 dBm
-90 dBm
-60 dBm
5 GHz 802.11ax (HE40)
24 dBm
-86 dBm
-56 dBm
5 GHz 802.11ax (HE80)
-83 dBm
-53 dBm
5 GHz 802.11ax (HE160)
-81 dBm
-51 dBm
Basic Functions
RG-AP1920(V2)
RGOS11.9(6)W8 or later
Recommended number of STAs
Maximum number of WLAN IDs
CAPWAP through Network Address Translation (NAT)
Mobile unit (MU) location
Application management
PSK, web-based, 802.1X, WPA, WPA2, and WPA3 authentication
MAB
Data encryption: WEP (64/128 bits), WPA (TKIP), WPA-PSK, WPA2 (AES), WPA3
Dynamic policy
Static MAC address, MAC address filtering, and MAC address limiting
MAC address table size: 1,024
Jumbo frame length: 1,518
Optical transceiver information display, alarms about faults, and diagnosis parameter measurement (QSFP+/SFP+/SFP)
Maximum number of SVIs: 200
VLAN ID range: 1--4,094
NAT, FTP ALG, and DNS ALG
NTP server and NTP client
Fault detection and alarms
Web management (eWeb)
When the AP works in cloud mode, it can be managed through WIS Cloud.
The following value-added software functions can be achieved when the RG-AP1920(V2) is used with RG-WIS and the AC.
RG-AP1920(V2)
Network operation analysis such as device stability and signal coverage
Measuring user network experience based on indicators including latency, packet loss, RSSI, and channel utilization, with visualized network experience results
Statistics on the number of online and offline failures of STAs associated with different APs, average RSSI, and other parameters
Note: These functions are supported only when the RG-AP1920(V2) works in Fit mode.
Network performance optimization, including one-click network optimization and optimization solution setting based on different scenarios
Sticky client roam steering and experience indicator comparison
Remote association steering and experience indicator comparison
One-click diagnosis for analyzing problems and providing suggestions
Baseline analysis, recording changes in configuration, software version, and other parameters, and tracking changes in network KPIs
Time capsule for analyzing the history of device version and configuration changes
Cloud site survey
Batch generation of building floor information, floor plan upload, and drag-and-drop AP placement
One-click health check report and generation of reports on the overall network operating status
Unauthorized Wi-Fi signal locating and classified display, as well as countermeasure capabilities
Uniformly connecting, managing, and maintaining APs, ACs, and other devices
Batch device configuration and upgrade
ZTP deployment, creating configuration templates, and automatically applying configured templates
Discovering wired and wireless network topology with one click and generating the topology
Portal authentication page
Customizing Portal authentication pages for PCs and mobile phones
Interworking with Guodu and Alibaba Cloud SMS gateways
Big data capabilities
Data warehouse building based on Hive, data model conversion, and integration
Hierarchical and role-based access control
Administrators at different sites have different operation permissions.
System management functions including account operations, authorization configuration, email configuration, configuration backup, and exception alarms
Note: For details, refer to the latest hybrid cloud management solution of Ruijie Networks.
RG-AP1920(V2)
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP1920(V2)] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP1920(V2)] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at https://www.ruijie.com/.
  • The functions of Wireless Access Systems including Radio Local Area Networks (WAS/RLANs) within the band 5150-5350 MHz for this device are restricted to indoor use only within European Union countries and other relevant European regions (BE/BG/CZ/DK/DE/EE/IE/EL/ES/FR/HR/IT/CY/LV/LT/LU/HU/MT/NL/AT/PL/PT/RO/SI/SK/FI/SE/TR/NO/CH/IS/LI/UK(NI)).
Sumber daya
Informasi Pesanan
RG-AP1920(V2)
Wi-Fi 7 (802.11be) dual-radio wall-plate access point
● Radio 1 -- 2.4 GHz: Two spatial streams, 2x2 MU-MIMO, peak data rate of 688 Mbps
● Radio 2 -- 5 GHz: Two spatial streams, 2x2 MU-MIMO, peak data rate of 2.882 Gbps
It complies with 802.11a/b/g/n/ac/ax/be, and supports switchover among Fat, Fit, and cloud modes.
It provides IEEE 802.3af-compliant (PoE) and DC power supply.
Note: The DC power supply needs to be purchased separately, and the output voltage/current must be 48 V/0.3 A.
