RG-S6520-64CQ Jaringan Pusat Data - 1
RG-S6520-64CQ Jaringan Pusat Data - 2
RG-S6520-64CQ Jaringan Pusat Data - 3
RG-S6520-64CQ Jaringan Pusat Data - 4
RG-S6520-64CQ Jaringan Pusat Data - 5
RG-S6520-64CQ Jaringan Pusat Data - 6
RG-S6520-64CQ Jaringan Pusat Data - 7
RG-S6520-64CQ Jaringan Pusat Data - 8
RG-S6520-64CQ Jaringan Pusat Data - 9
Spesifikasi Utama
De-stacking
M-LAG
RG-S6520-64CQ
12.8 Tbps
4482 Mpps
Service port
64 x 40G/100G QSFP28 ports
Management port
RG-PA800I-F (AC input):
Power port type: C14
RG-PA800I-F (HVDC input):
Rated input voltage: 240 V DC
Rated input current: 5 A
RG-S6520-64CQ
Layer 2 Protocols
Layer 3 Protocols (IPv4)
IPv6 Basic Protocols
IPv6 Features
Data Center Features
M-LAG
RDMA
Visualization
sFLOW sampling
Priority marking/remarking
Virtualization
Virtual Switching Unit
Buffer Management
HA Design
Security Features
Management Mode
Other Protocols
Sumber daya
Informasi Pesanan
RG-S6520-64CQ
64 × 100GE ports
RG-PA800I-F
M6520-FAN-F
40G Optical Transceivers
100G Optical Modules
