RG-SF2920-16GT2MG2XS Switch - 1
RG-SF2920-16GT2MG2XS Switch - 2
RG-SF2920-16GT2MG2XS Switch - 3
RG-SF2920-16GT2MG2XS Switch - 4
RG-SF2920-16GT2MG2XS Switch - 5
RG-SF2920-16GT2MG2XS Switch - 6
RG-SF2920-16GT2MG2XS Switch - 7
RG-SF2920-16GT2MG2XS 16-Port GE All-Optical Switch, 2 × 2.5G Electrical Ports (Backward Compatible)
Seri
  • Various port combinations, rate increase, surge protection greater than 8 kV, 16 x 10/100/1000BASE-T ports, 2 x 1G/2.5GBASE-T ports, and 2 x 1GE/10GE SFP+ ports for uplink
  • 2.5G Ethernet port, meeting the requirements of new services and enhancing service scalability
Spesifikasi Utama
All-Optical Ethernet Switch RG-SF2920-16GT2MG2XS
This switch provides 16 x 10/100/1000BASE-T ports, 2 x 1G/2.5GBASE-T ports, 2 x 1GE/10GE SFP+ uplink ports, rich interfaces, supporting full service expansion.
and No Security Concern
Flexible Installation
Heat Dissipation Design
Quietness
Optical Link O&M
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
8 x 10/100/1000BASE-T ports
2 x 1GE SFP ports
RG-SF2920-16GT2SFP-P
RG-SF2920-8GT2MG2XS-P
RG-SF2920-16GT2MG2XS-P
2 x 1GE SFP ports
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
49.1 Mpps
61 Mpps
26.8 Mpps
System switching capacity *2
66 Gbps
82 Gbps
256 MB
512 MB DDR3
1.5 MB
500
500
Ingress: 1,500
Egress: 500
26.8 Mpps
56.5 Mpps
68.44 Mpps
76 Gbps
92 Gbps
256 MB
512 MB DDR3
1.5 MB
500
500
Ingress: 1,500
Egress: 500
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
1.97 kg (4.34 lbs)
2.04 kg (4.5 lbs)
1.98 kg (4.37 lbs)
2.75 kg (6.06 lbs)
2.81 kg (6.19 lbs)
2.75 kg (6.06 lbs)
2.34 kg (5.16 lbs)
2.33 kg (5.14 lbs)
2.33 kg (5.14 lbs)
3.11 kg (6.86 lbs)
3.12 kg (6.88 lbs)
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
1 x fixed power module
Fixed power supply: 25 W
Fixed power supply: 150 W
25 W (without PoE load)
150 W (full PoE load)
RG-SF2920 Series
Operating temperature:
Air discharge: 15 kV
Contact discharge: 8 kV
Service port: 8 kV
RG-SF2920 Series
RG-SF2920
MAC VLAN
Basic QinQ and flexible QinQ
Static blackhole routing
ACL80 and IPv6 ACLs
SSHv1.5 and SSHv2.0
Portal authentication
Unknown unicast suppression
Load balancing
LACP dynamic aggregation
Cross-VSU aggregate interface
IPv4 VRRP v2/v3, IPv6 VRRPv3
GR for OSPF
SPAN, RSPAN and ERSPAN
Flow- and VLAN-based SPAN
● Port priority
Sumber daya
Informasi Pesanan
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
CWDM
Tanya-Jawab
