Layer 3 Compact Access Switch for 1GE Uplink RG-S5350-24GT4SFP-E
| Port Specifications |
RG-S5350-24GT4XS-E |
RG-S5350-48GT4XS-E |
RG-S5350-12GT4XS-P-E |
RG-S5350-24GT4XS-P-E |
RG-S5350-48GT4XS-P-E |
| Fixed service ports |
| Fixed management port |
1 x RJ45 console port |
| USB |
1 x USB 2.0 port |
| USB hot swapping |
Supported |
| Cable hot swapping |
Supported by all ports |
RG-S5350-24GT4SFP-E |
RG-S5350-48GT4SFP-E |
RG-S5350-24GT4SFP-P-E |
RG-S5350-48GT4SFP-P-E |
| USB |
1 x USB 2.0 port |
| USB hot swapping |
Supported |
| System Specifications |
115 Mpps |
158 Mpps |
94 Mpps |
115 Mpps |
158 Mpps |
| Switching capacity *2 |
128 Gbps / 336 Gbps |
176 Gbps / 336 Gbps |
104 Gbps / 336 Gbps |
| Switch buffer |
4 MB |
| CPU |
| Real-time clock (RTC) |
Supported |
| BootROM |
16 MB |
| Flash memory |
512 MB |
| Memory |
DDR4 1GB |
| Switch buffer |
4 MB |
| MAC address table size |
16,000 |
| ARP table size |
4,000 |
| Number of IPv4 unicast routes |
6,000 |
| Number of IPv4 multicast routes |
1,000 |
| Number of IPv6 unicast routes |
2,000 |
| Number of IPv6 multicast routes |
750 |
| Number of ACEs |
Ingress: 1,750 Egress: 800 |
| Number of VSU members |
8 |
50 Mpps |
94 Mpps |
50 Mpps |
94 Mpps |
56 Gbps / 336 Gbps |
| Switch buffer |
4 MB |
| CPU |
Supported |
| BootROM |
16 MB |
| Flash memory |
512 MB |
| Memory |
DDR4 1GB |
| Switch buffer |
4 MB |
16,000 |
| ARP table size |
4,000 |
6,000 |
1,000 |
2,000 |
750 |
| Number of ACEs |
4 |
| Dimensions and Weight |
| Rack height |
1 RU |
| Unit weight |
3.1 kg (6.83 lbs) |
3.25 kg (7.17 lbs) |
3.3 kg (7.28 lbs) |
3.4 kg (7.50 lbs) |
4.0 kg (8.82 lbs) |
| Mounting |
| Rack height |
1 RU |
| Unit weight |
3.1 kg (6.83 lbs) |
3.4 kg (7.50 lbs) |
4.0 kg (8.82 lbs) |
| Mounting |
Power supply and Consumption
| Power supply |
1 x fixed power supply |
| Power input |
| Maximum output power |
Fixed power supply: 25 W |
Fixed power supply: 40 W |
| Maximum power consumption |
25 W |
40 W |
| Leakage current |
≤ 3.5 mA |
| Energy saving |
Supported |
| Power supply |
| Power input |
| Leakage current |
≤ 3.5 mA |
| PoE port |
| PoE power cable pairs |
Mode A (1-2, 3-6 pairs) |
| PoE output power |
| Energy saving |
supported |
| Power supply |
| Power input |
Built-in power supply: 40 W |
25 W |
40 W |
| Leakage current |
≤ 3.5 mA |
| Energy saving |
Supported |
| Power supply |
| Power input |
Fixed power supply: 409 W |
Fixed power supply: 460 W |
| Leakage current |
≤ 3.5 mA |
| PoE port |
| PoE output power |
| Energy saving |
Supported |
| Temperature |
| Humidity |
| Altitude |
| Fan |
No fan |
1 x fixed fan module |
| Heat dissipation |
| Acoustic noise |
Fanless, quiet, < 20 dB |
27℃(80.6°F): 32 dB |
27℃(80.6°F): 35 dB |
| Fan monitoring |
Fanless design |
| Temperature monitoring |
Supported |
| ESD |
| Surge protection |
| Temperature |
| Humidity |
| Altitude |
| Fan |
Fanless |
| Heat dissipation |
| Acoustic noise |
| Fan monitoring |
Fanless design |
Supported |
| ESD |
| Surge protection |
| Feature |
RG-S5350-E Series |
| Ethernet switching |
| 802.3az EEE |
| IEEE 802.1Q (4K VLANs) |
| Voice VLAN |
| GVRP |
| Basic QinQ Selective QinQ |
| ERPS (G.8032) |
| LLDP/LLDP-MED |
| IP service |
| DHCP snooping |
| DNS |
| DHCPv6 snooping |
| IP routing |
Static routing |
| RIP and RIPng |
| OSPFv2 and OSPFv3 |
| IS-ISv4 and IS-ISv6 |
| BGP4 and BGP4+ |
| IPv4 and IPv6 VRF |
| IPv4 and IPv6 PBR |
| Multicast |
| IGMP v1/v2 snooping |
| PIM SMv6, and PIM-SSMv6 |
| MSDP |
| MLDv1/v2 and MLD proxy |
| MLD snooping v1/v2 |
| PIM-SMv6 and PIM-SSM v6 |
| Multicast querier |
| ACL and QoS |
| Global ACLs |
| ACL redirection |
| Security |
Multiple AAA modes |
| RADIUS and TACAS+ |
| Web authentication |
| HTTPS |
| SSHv1 and SSHv2 |
| Global IP-MAC binding |
| ICMPv6 |
| IP source guard |
| SAVI |
| ARP spoofing prevention |
| CPP and NFPP |
| BPDU guard |
| Port protection |
| Reliability |
REUP |
| RLDP |
| DLDP |
| BFD, NSR, VRRR, VRRP+ |
| Basic LACP |
| Dual-Boot Redundancy |
| Device virtualization |
| NMS and maintenance |
SPAN, RSPAN |
| sFlow |
| NTP and SNTP |
| FTP and TFTP |
| SNMP v1/v2c/v3 |
| RMON (1, 2, 3, 9) |
| NETCONF |
| CWMP (TR-069) |
| gRPC |
| CLI (Telnet/Console) |
| Web |
| Syslog/Debug |
| PoE |
| Model |
Description |
| Model |
Description |
| Mini-GBIC-GT |
| MINI-GBIC-SX-MM850 |
| MINI-GBIC-LX-SM1310 |
| MINI-GBIC-LH40-SM1310 |
| MINI-GBIC-ZX80-SM1550 |
| GE-SFP-LX03-SM1310-BIDI-I |
| GE-SFP-LX03-SM1550-BIDI-I |
| GE-SFP-LX20-SM1310-BIDI |
| GE-SFP-LX20-SM1550-BIDI |
| GE-SFP-LH40-SM1310-BIDI |
| GE-SFP-LH40-SM1550-BIDI |
| Model |
Description |
| Model |
Description |
| XG-SFP-SR-MM850 |
| XG-SFP-LR-SM1310 |
| XG-SFP-ER-SM1550 |
| XG-SFP-ZR-SM1550 |
| XG-SFP-LR10-SM1270-BIDI-I |
| XG-SFP-LR10-SM1330-BIDI-I |
| XG-SFP-AOC1M |
| XG-SFP-AOC3M |
| XG-SFP-AOC5M |
