RG-MUX-8LC/LC-H Switches - 1
RG-MUX-8LC/LC-H Switches - 2
RG-MUX-8LC/LC-H Switches - 3
RG-MUX-8LC/LC-H Switches - 4
RG-MUX-8LC/LC-H Switches - 5
RG-MUX-8LC/LC-H Switches - 6
RG-MUX-8LC/LC-H Switches - 7
RG-MUX-8LC/LC-H Switches - 8
RG-MUX-8LC/LC-H Switches - 9
RG-MUX-8LC/LC-H Switches - 10
RG-MUX-8LC/LC-H Switches - 11
RG-MUX-8LC/LC-H Ethernet All-Optical Modular 8-Port Transparent Distribution Device Used with Splitters
Paired with splitters to realize dual uplinks on network links and suitable for scenarios with dual core switches
Serie
  • Combination of splitters and transparent distribution devices, achieving dual uplinks for all-optical links and improving the link reliability between the core network and building
RG-MUX-8LCI/LC-H 8-Port Transparent Distribution All-Optical Network Passive Device
An 8-port transparent distribution device on the building side supports both 10 Gbps and 1 Gbps per port, and can accommodate up to 48 ports when fully loaded. The device integrates WDM technology, which allows for a network architecture reduced from three layers to two layers. With WDM, services from the core side to the access side are transparently transmitted, realizing passive distribution nodes.
Product Specifications
RG-MUX-8LC/LC
RG-MUX-8LC/LC-H
RG-MUX-EXT
1 x multiplexing port
Wavelength range
1271 nm to 1571 nm (CWDM)
Channel spacing
20 nm
20 nm
20 nm
Channel bandwidth
±6 nm
±6 nm
±6 nm
Insertion loss
< 3.7 dB
< 2.6 dB
< 4.2 dB
Return loss
> 45 dB
> 45 dB
> 45 dB
Polarization loss
< 0.3 dB
< 0.3 dB
< 0.3 dB
Adjacent channel isolation
> 25 dB
> 25 dB
> 35 dB
> 35 dB
LC/UPC
LC/UPC
LC/UPC
0.25 kg (0.55 lbs)
0.25 kg (0.55 lbs)
0.15 kg (0.33 lbs)
4.53 kg (9.99 lbs)
Communication standard
GR-1221-Core and GR-1209-Core
RG-MUX-BOX
0.9 kg (1.98 lbs)
11.5 kg (25.35 lbs)
Información de pedido
RG-MUX-8LC/LC
RG-MUX-8LC/LC-H
RG-MUX-EXT
RG-MUX-BOX
