RG-CS88-08 Redes para pequeñas y medianas empresas - 1
RG-CS88-08 Redes para pequeñas y medianas empresas - 2
RG-CS88-08 Redes para pequeñas y medianas empresas - 3
RG-CS88-08 Redes para pequeñas y medianas empresas - 4
RG-CS88-08 Redes para pequeñas y medianas empresas - 5
RG-CS88-08 Redes para pequeñas y medianas empresas - 6
RG-CS88-08 Redes para pequeñas y medianas empresas - 7
RG-CS88-08 Redes para pequeñas y medianas empresas - 8
RG-CS88-08 Redes para pequeñas y medianas empresas - 9
RG-CS88-08 Redes para pequeñas y medianas empresas - 10
RG-CS88-08 Ruijie 10 RU Modular High-Performance Core Switch with Cloud Management
Fit for data center, MAN, campus, and integrated data center and campus scenarios
Serie
  • 10 RU compact size, saving space
  • Up to 288 10GE ports on high-density 10GE cards
  • 40GE and 100GE ports, achieving high speed
  • Cloud, Make Your Business Easy
Cloud Managed Modular Core Switch RG-CS88-08
10 RU compact size, saving cabinet space,high-density 1G/10G/40G/100G line cards support up to 288 10GE ports. Only one line card is required to meet networking requirements at the small- or medium-sized network core or medium-sized network aggregation layer.
Dual-Boot Backup
Two flash chips for storing boot software achieve hardware-level boot
redundancy, avoiding switch boot failures due to a flash chip fault.
1+1 Supervisor
Module Redundancy
1+1 Supervisor
Module Redundancy
N+M Power Supply Redundancy
1+1 Fan Redundancy
Two axial flow fans for factory delivery support 256-level speed regulation
and precise temperature control, reducing energy consumption and noise.
1+1 Fan Redundancy
Automatic device registration and configuration after device connection
Plug and play without commissioning, fast provisioning
Flexible replacement with no need of reconfiguration
Auto-sensing on ports, facilitating automatic O&M
RG-CS88-08
2 x supervisor module slots
6 x line card slots
4 x power module slots
Supervisor module
CM88-CM
Switch fabric module
CM88-CM (switch fabric module integrated with supervisor module)
Line card
CM88-48GT-H
CM88-48SFP-H
CM88-48XS-H
CM88-8СQ-H
RG-PA600I-F
RG-PA1600I-F
M08-FAN (pre-installed 2)
Module service port
CM88-48GT-H: 48 x 10/100/1000BASE-T ports
CM88-48SFP-H: 48 x 1GE SFP ports
CM88-48XS-H: 48 x 1GE/10GE SFP+ ports
CM88-8СQ-H: 8 x 40GE/100GE QSFP28 ports
Module management port
CM88-CM:
● 1 x RJ45 console port
● 1 x RJ45 MGMT port
CM88-CM: 2 x USB 2.0 ports
(No capacity limit. The 2G/4G/8G/16G/32G capacity is tested.)
RG-CS88-08
9.6 Tbps
7200 Mpps
CM88-CM: quad-core processor, each core with the clock speed of 1.5 GHz
Line card: quad-core processor, each core with the clock speed of 1.5 GHz
CM88-CM: 16 MB (2 flash chips for 1+1 boot redundancy)
Line card: 16MB (2 flash chips for 1+1 boot redundancy)
CM88-CM: 8 GB
Line card: 8 GB
CM88-CM: 4 GB DDR4
Line card: 2 GB DDR4
CM88-8CQ-H, CM88-48XS-H: 32 MB
CM88-48SFP-H, CM88-48GT-H: 8 MB
● CM88-48GT-H, CM88-48SFP-H: 80,000
● CM88-8CQ-H, CM88-48XS-H: 96,000
● CM88-48GT-H, CM88-48SFP-H: 4,000
● CM88-8CQ-H, CM88-48XS-H: 40,000
● underlay: 30,000
● overlay: 0
● underlay: 50,000
● overlay: 0 (default and recommended)
CM88-48GT-H, CM88-48SFP-H: 12,000 (default and recommended, shared with IPv6 routes)
CM88-8CQ-H, CM88-48XS-H: 134,000 (default and recommended, shared with IPv6 routes)
CM88-48GT-H, CM88-48SFP-H: 8,000
CM88-8CQ-H, CM88-48XS-H: 16,000
CM88-48GT-H, CM88-48SFP-H: 6,000 (shared with IPv4 routes)
CM88-8CQ-H, CM88-48XS-H: 50,000 (shared with IPv4 routes)
CM88-8CQ-H, CM88-48XS-H: 8,000
Ingress
● CM88-48GT-H, CM88-48SFP-H: 5,000
● CM88-8CQ-H, CM88-48XS-H: 4,500
Egress
● CM88-48GT-H, CM88-48SFP-H: 1,000
● CM88-8CQ-H, CM88-48XS-H: 2,000
RG-CS88-08
442 mm x 465mm x 441.7 mm (17.40 in. x 18.31 in. x 17.39 in.)
710 mm x 590 mm x 617 mm (27.95 in. x 23.23 in. x 24.29 in.)
10 RU
35.6 kg (78.48 lbs) (empty chassis with 2 fan modules)
50.20 kg (110.67 lbs) (empty chassis with 2 fan modules)
RG-CS88-08
4 x pluggable power modules
n+n power redundancy
(The type of the power supply should be identical.)
RG-PA600I-F (AC input):
● Maximum input current: 10 A
RG-PA1600I-F (AC input):
● Maximum input current: 16A
RG-PA600I-F: 600 W
RG-PA1600I-F:
Chassis RG-CS88-08 with 2 fan modules: < 176 W
Supervisor module CM88-CM: < 50 W
Line card:
● CM88-48GT-H: < 75 W
● CM88-48SFP-H: < 95 W
● CM88-48XS-H: < 160 W
● CM88-8CQ-H: < 130 W
RG-CS88-08
2 x pluggable fan modules
Supervisor module/line card: right-to-rear airflow
System power module: front-to-rear airflow
27°C (80.6°F): 70 dB
45°C (113°F): 77 dB
Supported: supervisor modules, line cards
(Switch mode power supplies support hot-swapping power cords)
All ports on line cards support hot-swapping cables.
Monitoring of the power supply model, temperature, power, and voltage
Power-on control of line cards based on the supported power
ESD contact discharge/air discharge: 6 kV/ 8kV
MGMT port : 4 kV
Service port: 4 kV
Power port: 6 kV
RG-CS88-08
EN 300386, EN 55032 Class A, EN 55035,
EN IEC 61000-3-2, EN 61000-3-3, EN 61000-4-2, EN 61000-4-3,
EN 61000-4-4, EN 61000-4-5, EN 61000-4-6, EN 61000-4-11
RG-CS88 Series
Ethernet Switching
Super VLAN, Private VLAN
MPLS IPv6
MPLS 6VPE
GRE tunnel
IP Routing
IPv4/IPv6 IS-IS
Policy-based routing (PBR)
EVPN
IGMP v1/v2/v3
IGMP proxy
IGMP snooping v1/v2/v3
MLDv1 and MLDv2
MLD v1/v2 snooping
Multicast static routing
ACL80 and IPv6 ACL
802.1p
CAR
ICMP
uRPF
VRRP for the super-VLAN
1+1 redundancy for supervisor modules and fan modules, and N+M redundancy for power modules
Hot swapping of components
GR for OSPF/IS-IS/BGP
SPAN, RSPAN, and ERSPAN
NTP
SNTP
Fault alarm and auto-recovery
Información de pedido
Switch and Supervisor Module
Select the switch and supervisor module based on the specific product model.
RG-CS88-08
RG-CS88-08 switch, which can accommodate 6 service cards and 2 supervisor modules, and with 2 fans (Purchase at least one RG-PA600I-F/RG-PA1600I-F module.)
CM88-CM
CM88-CM new generation of high-performance supervisor module.
Power Modules and Fans
Select the power module based on power supply requirements. Note that at least one power module must be selected.
RG-PA600I-F
600 W AC power module, supporting redundancy
RG-PA1600I-F
M08-FAN
CS88-08 fan: Each M08-FAN tray consists of two fan modules and one fan monitoring card. It blows air to the outside for convection. (This is a default configuration for the switches.)
Line Cards
Select the line card based on service requirements. Before ordering a line card, please contact the online customer service personnel for the details about the line card.
CM88-48GT-H
48 x10/100/1000BASE-T ports (RJ45)
CM88-48SFP-H
48 x 1GE SFP ports
CM88-48XS-H
CM88-8CQ-H
  • 48 x 1GE/10GE SFP+ ports support 1GE SFP transceivers and 10GE SFP+ transceivers.
  • 8 x 40GE/100GE QSFP28 ports support 40GE QSFP+ transceivers and 100GE QSFP28 transceivers.
