RG-AP180-I Conexión inalámbrica - 1
RG-AP180-I Conexión inalámbrica - 2
RG-AP180-I Conexión inalámbrica - 3
RG-AP180-I Conexión inalámbrica - 4
RG-AP180-I Conexión inalámbrica - 5
RG-AP180-I Conexión inalámbrica - 6
RG-AP180-I Conexión inalámbrica - 7
RG-AP180-I Conexión inalámbrica - 8
RG-AP180-I Conexión inalámbrica - 9
RG-AP180-I, Wi-Fi 6 Dual-Radio 2.976 Gbps Indoor Wall Plate Access Point
Indoor scenarios covering higher education, government, general education, finance, and commerce sectors
  • 4 x 1 Gbps downlink Ethernet ports, wired and wireless integration for cost-efficient networking
  • 2.976 Gbps ultra-fast speed with Wi-Fi 6
Wi-Fi 6 Enterprise-Grade High-Performance Wall Plate AP RG-AP180-I
Maximum Data Rate 2.976 Gbps
PoE Out/DC power supply
Bluetooth 5.1
Junction box/wall-mounted
Wired and Wireless Integration, Cost-Efficient Networking
1 x 2.5 Gbps uplink port + 4 x 1 Gbps downlink ports provide high-speed wireless connectivity while fully supporting wired network scalability *
Dual-network integration, requiring fewer switches to slash networking costs
*LAN1 supports standard PoE output voltage (48V/10W).
2.976 Gbps Ultra-Fast Speed with Wi-Fi 6
2.976 Gbps
High speed:
High concurrency:
OFDMA and MU-MIMO transfer technologies, 4x more concurrent users than Wi-Fi 5
High security:
Low latency:
OFDMA technology reduces the delay to as low as 20 ms, making it easier to watch videos and download documents
PoE Power Supply, Flexible Deployment
With PoE in, each AP only requires a single network cable to transmit both data and power.
Easy deployment without external power supply.
Cloud O&M
24 h Network Optimization
Real-Time Warning
Fault Locating
Go to WIS Cloud Network
RG-AP180-I
Four spatial streams
Channels:
Two spatial streams
Channels:
Channels:
● 2.4 GHz: two built-in omnidirectional antennas, with peak antenna gain of 5.2 dBi.
● One onboard omnidirectional antenna, with peak antenna gain of 2.4 dBi
Uplink: 1 x 100/1000/2.5GBase-T port, compliant with IEEE 802.3af/at standard (PoE/PoE+).
Downlink: 4 x 10/100/1000Base-T ports, LAN 1 supports 48 V/10 W power supply to an attached device.
1 x micro USB console port
1 x Bluetooth 5.1
● CAPWAP tunnel timeout
● Specific AP locating
Dimensions (W x H x D)
Main unit: 86 mm x 170 mm x 43 mm (3.39 in. x 6.69 in. x 1.69 in.)
Shipping: 187 mm x 104 mm x 69 mm (7.37 in. x 4.10 in. x 2.72 in.)
Main unit: 0.3 kg (0.66 lbs)
Shipping: 0.54 kg (1.19 lbs)
Junction box-mount (86 mm/American-standard/European-standard junction box)
Wall-mount (delivered with a mounting bracket)
Kensington lock
● 48 V DC/0.6 A power input over DC connector: The DC connector accepts 2.1 mm/5.5 mm center-positive circular plug. A DC power supply needs to be purchased independently.
Maximum power consumption: 25 W
● DC power: 25 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2, LAN 1 for PoE supply
● 802.3at (PoE+): 25 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2, LAN 1 for PoE supply
● 802.3af (PoE): 15 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2, LAN 1 port that fail to provide power for external devices (PoE out disabled of LAN 1 port disabled)
● Idle mode: 8 W
Storage altitude: 0 m to 3,000 m (0 ft. to 9,842.52 ft.)
Operating temperature: 0°C to +40°C (32℉~104℉)
Operating altitude: 0 m to 3,000 m (0 ft. to 9,842.52 ft.)
512 MB DRAM, 128 MB flash
● Maximum transmit power: 20 dBm (100 mW)
RG-AP180-I
2.4 GHz 802.11b
1 Mbps
–96 dBm
-10 dBm
–94 dBm
-10 dBm
–93 dBm
11 Mbps
-10 dBm
2.4 GHz 802.11g
6 Mbps
19 dBm
24 Mbps
17 dBm
36 Mbps
17 dBm
54 Mbps
–74 dBm
2.4 GHz 802.11n (HT20)
19 dBm
–67 dBm
2.4 GHz 802.11n (HT40)
19 dBm
–64 dBm
2.4 GHz 802.11ax (HE20)
12 dBm
–58 dBm
2.4 GHz 802.11ax (HE40)
17 dBm
12 dBm
5 GHz 802.11a
6 Mbps
24 Mbps
17 dBm
36 Mbps
17 dBm
–78 dBm
54 Mbps
15 dBm
–72 dBm
5 GHz 802.11n (HT20)
14 dBm
–67 dBm
5 GHz 802.11n (HT40)
17 dBm
14 dBm
–64 dBm
5 GHz 802.11ac (VHT20)
13 dBm
5 GHz 802.11ac (VHT40)
17 dBm
13 dBm
–57 dBm
5 GHz 802.11ac (VHT80)
13 dBm
–56 dBm
5 GHz 802.11ax (HE20)
12 dBm
–58 dBm
5 GHz 802.11ax (HE40)
17 dBm
12 dBm
5 GHz 802.11ax (HE80)
12 dBm
–52 dBm
5 GHz 802.11ax (HE160)
15 dBm
12 dBm
–50 dBm
RG-AP180-I
RGOS11.9(6)W3B3 or later
128
Maximum number of WLAN IDs
Rate set settings
MU device locating
Application management
Dynamic Policy
CoA/DM
MAC address table size: 1,024
Jumbo frame length: 1,518
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
ARP entry aging and proxy ARP
NAT, FTP ALG and DNS ALG
NTP server and NTP client
Telnet and TFTP Management
RG-AP180-I
RG-AP180-I
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, IEC 62368-1, EN 62368-1, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, EN 50665, EN 62311, EN IEC 62311, EN 18031-1, and EN 18031-2
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP180-I] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP180-I] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
Información de pedido
RG-AP180-I
Wi-Fi 6 dual-radio wall plate access point
The power source equipment (PSE) needs to be purchased separately.
The DC power supply needs to be purchased separately, and the output voltage/current must be 48 V/0.6 A.
