                            RG-MACC can conduct configuration and manage of all AP,
                            Switches in one cloud management platform
                            RG-MACC allows you to have an all-rounded monitoring
                            on Internet usage, channel usage, traffic usage, RSSI status and etc.
                                RG-MACC performs as an easy-to-use simulation tool to generate the heat
                                map according to the imported floor plan with predictions of signal strength,
                                channel interference and speed.
