Used in Simplified Optical Ethernet solution to make distribution nodes passive and provide exclusive Gigabit/10G bandwidth for Fiber-to-The-Room (FTTR)
For example, an office building has 6 floors, with 2 ELV risers and 20 rooms on each floor, and 4 information points in each room.
1:1 bandwidth for FTTR, zero optical splitting, and no convergence. The access-side port rate is the same as the core-side port rate, implementing point-to-point transparent transmission.
| Model |
RG-DEMUX-24LC/LC |
RG-DEMUX(C)-24LC/LC |
RG-DEMUX-48LC/LC |
RG-MUX-24LC/LC |
RG-MUX(C)-24LC/LC |
RG-MUX-48LC/LC |
| Name |
Expansion module for the 24-port core demultiplexer |
24-port demultiplexer, with chassis and one reserved expansion slot |
48-port demultiplexer |
Expansion module for the 24-port transparent multiplexer |
24-port transparent multiplexer, with chassis and one reserved expansion slot |
48-port transparent multiplexer |
| Number of CWDM 16-channel demultiplexer groups |
3 groups |
3 groups |
6 groups |
3 groups |
3 groups |
3 groups |
| Installation location |
Core side |
Core side |
Core side |
Building side |
Building side |
Building side |
| Maximum number of ports supported |
24 |
24 |
48 |
24 |
24 |
48 |
| Dimension (W × D × H) |
216.4 mm * 207 mm *33 mm |
297.6 mm * 438.5 mm * 40.2 mm |
216.4 mm * 207 mm * 33 mm |
210.2 mm * 440 mm * 39.8 mm |
| Model |
RG-MUX(C)-24LC/LC |
| Description |
24-port transparent multiplexer, with 3 demultiplexing ports (number of trunk fiber-optic cables can be connected) |
| Center wavelength |
1271 nm to 1571 nm (CWDM) |
| Channel spacing |
20 nm |
| Channel bandwidth |
±6.5 nm |
| Insertion loss |
≤4dB (demultiplexer and transparent multiplexer) |
| Return loss |
> 45 dB |
| Polarization dependent loss |
< 0.3 dB |
| Adjacent channel isolation |
> 25 dB |
| Non-adjacent channel isolation |
> 35 dB |
| Connector |
LC/UPC |
| Operating temperature |
-40°C to 85°C (WDM products are not pressure sensitive and have no requirement for altitude) |
| Storage temperature |
-40°C to 85 °C |
| Operating humidity |
10% to 90% RH |
| Storage humidity |
5% to 90% RH |
| Standards |
GR-1221-Core and GR-1209-Core |
| Weight |
2.57 kg (net weight) |
